About memtool support
2,289件の閲覧回数
matsumoto2
hello
I am using SC2310H to output data to MIPI of i.MX8MP, but the data does not reach the VB2 queue.
I would like to refer to the following register values to check whether the i.MX8MP can receive MIPI data.
32E4_0020: D-PHY status register (MIPI_CSI1_DPHY_STATUS)
32EC_007C: Gasket 0 ISI Pixel Count Register
But I'm trying to use memtool but the cpu hangs when I run the command.
Does memtool support i.MX8MP?
Please tell me.
4 返答(返信)
2,269件の閲覧回数
joanxie
pls give me your memtool command, let me double check it
2,264件の閲覧回数
matsumoto2
"./memtool 0x32ec007c 1"
"./memtool 0x32e40020 1"
2,246件の閲覧回数
joanxie
when you read these registers, did you connect any camera?
2,237件の閲覧回数
matsumoto2
Connected to the camera of course.
I was able to confirm the target register by dumping it from the source code.
I was able to achieve my goal without using memtool.
