About i.MX6 Internal LDO
2,238件の閲覧回数
okamotosatoshi
Hello.
I want to check about i.MX6Q.
Thank you to answer the following questions.
We have created a custom board of i.MX6Q.
I confirmed the voltage drop in VDDSOC_CAP at startup.
I attach the measured waveform. (VDDSOC_CAP : No load)
CH1:5V(Power-supply voltage)
CH2:2.5V(VDDHIGH_CAP)
CH3:1.1V(VDDSOC_CAP)
CH4:POR_B
Is there a way to avoid the voltage drop of VDDSOC_CAP ?
In addition, the voltage drop of VDDSOC_CAP was Would no issue ?
Start-up failure has occurred on the SATA boot.
Believes that the above reason.
(For reset release timing occurred voltage drop of VDDSOC_CAP.)
-satoshi
タグ(3)
1,472件の閲覧回数
igorpadykov
Hi okamoto
in general there is nothing wrong in these
waveforms. Transients and glitches are allowed,
during this time POR should be asserted.
①VP power supply is no issue using VDDSOC_CAP?
No issue.
②Are there any plans to improve this issue ?
No plans, because it is allowed.
③This phenomenon will not occur in SABRE Board?
SABRE Board may have incorrect waveforms because it was designed
in time when i.MX6 datasheets were not finalized.
chip
5 返答(返信)
1,472件の閲覧回数
okamotosatoshi
Hi, chip
Thank you for reply.
I was relieved at the fact that no problem waveform.
It was confirmed to I get information, but would not be applicable items.
I confirmed the similar symptoms in other substrates.
- incorrect capacitor value on VDDSOC_CAP
A)VDDSOC_CAP have placed more than capacitor of 22uF.
 No change If you place a 100uF.
- incorrect current capability on VDDSOC_IN from PMIC
- incorrect power-up sequence
A)There is no problem because you have the power generated by the PMIC.
 (As with SABRE Board.)
If you 100uF capacitor , the voltage at the first time is reduced.
Thereafter , it is a normal voltage rise for the second time.
(Discharge curve becomes gentle.)
From the above , I believe the rise of the first time that he crowded around the power of other i.MX6.
After that , it seems to be a constant load discharge.(Measured values with the calculated values match almost.)
I believe the rise of the second is correct output voltage of the LDO.
I think the issue i.MX6 series.
Are there any plans to improve this problem ?
CPU:MCIMX6Q5EYM10AC
PMIC:MMPF0100F0AEP
-satoshi
1,472件の閲覧回数
okamotosatoshi
Hi, chip
I will append the contents measured .
Please refer to the attached document for details.
・VDDSOC_CAP/VDDPU_CAP wraps around VDDHIGH_IN is supplied.
・When VDDHIGH_IN turn off, LDO is not outputted.
 (VDDHIGH_IN enabled internal LDO?)
・Rising edge of the second time changes.(VDDSOC_CAP/VDDPU_CAP)
 (You are shifting inside the output timing ?)
・Rising edge of the first have the same timing.(VDDSOC_CAP/VDDPU_CAP)
From the above, I believe that wraps around from VDDHIGH_IN.
-satoshi
1,473件の閲覧回数
igorpadykov
Hi okamoto
No issue.
chip
1,472件の閲覧回数
okamotosatoshi
Hi, chip
I will assert POR during the waveform.
Thank you for information.
Asserting the POR until normal operation.
Then use it to reset release.
-satoshi
1,472件の閲覧回数
igorpadykov
Hi okamoto
waveforms.
VDDSOC_CAP sag may be caused by several reasons:
Please check all above with Chapter 2 Design Checklist,
Chapter 4 Requirements for Power Management,
Chapter 8 Avoiding Board Bring-up Problems
IMX6DQ6SDLHDG IMX6DQ6SDLHDG, Hardware Development Guide
chip
