Hello, all.
SABRE-SD board has 22uF capacitor for VDD_HIGH_CAP, NVCC_PLL_OUT pin.
But these pin are recommended a 10uF capacitor according to Design Checklist (IMX6DQ6SDLHDG_Rev1.pdf).
And it is written in checklist that operation cannot be guaranteed, if capacitance over 10uF.
Why SABRE-SD board has 22uF, and does SABRE-SD board not occurred problem so far?
Tomo
Solved! Go to Solution.
Hi Tomo
to guarantee operation in whole temperature range
and production process variations it is necessary to
follow recommendations Design Checklist IMX6DQ6SDLHDG_Rev1.pdf.
Also SABRE-SD board design was developed before all processor
documentation was prepared.
My customer pointed out to me that 24 MHz crystal has stop once before stable oscillation.
Is this waveform good for the i.MX6?
I changed to 22uF capacitor for NVCC_PLL_OUT pin, then 24 MHz oscillation stop phenomenon is not occured.
Could you tell me if this phenomenon is related to the value of the capacitor?
Hi Tomo
