About audio: how do I ensure which internal aux port is used
1,205 次查看
kainanzhu
Hi NXP:
   I'm now porting audio. I used external  aux port is aux3 from Schematic, but I don't know which internal port is used.
   How do I ensure which internal aux port is used?
Thanks.
7 回复数
1,065 次查看
diegoadrian
Are you using one of our boards? If yes, Which one?
Diego.
1,065 次查看
kainanzhu
Hi:
   Yes, I use imx6q.
1,065 次查看
kainanzhu
Yes. I'm using the SABRESD board
1,065 次查看
diegoadrian
Hello
Like you said, according to the schematic, the external aux port is connected to aud3 port. But following the schematic that audio port is connected to the CSI0_DAT (4 - 7) of the i.MX6Q - DISP CSI. Confirming with the i.MX pins tool the CSI0_DAT (4 - 7) is muxed with the AUD3_TXC, AUD3_TXD, AUD3_TXFS, AUD3_RXD respectively.
I hope this can solve your question.
Diego.
1,065 次查看
diegoadrian
Hello
Are you using the SABRESD board?
Diego.
1,065 次查看
kainanzhu
Hi Vaverka:
   we use imx6qdl.
Thanks.
1,065 次查看
TomasVaverka
Hi Kainan,
Could you please specify which NXP IC are you using? It will help us to find the correct space for your question.
Tomas
