ATF compilation for imx8m mini
3,512 次查看
borisshapiro
Hi.
Can you please provide the steps to compile ATF for imx8m mini?
I tried with
make PLAT=imx8mm SPD=opteed bl31 CROSS_COMPILE=aarch64-linux-gnu-
But then I only get the SPL prompt and it never reaches u-boot.
I use imx-atf - i.MX ARM Trusted firmware  branch imx_4.9.123_imx8mm_ga
Please help!
Thank you
标记 (3)
3,093 次查看
igorpadykov
Hi Boris
it is recommended to use more new versions like L4.14.98, adjusting
it with used uboot/linux versions.
For i.MX8M Mini detailed build steps can be found on
Boundary Devices
https://developer.solid-run.com/article-categories/i-mx8m-software/
3,093 次查看
borisshapiro
Hi.
I also tried branch imx_4.14.78_1.0.0_ga and the results are the same:
When I compile without SPD=opteed then u-boot starts successfully, but I get error of 'api uid mistmatch' when the op-tee kernel driver is loaded and no tee device is created in /dev/.
When I compile with SPD=opteed then it hangs between SPL and u-boot.
