ARM CORTEX M4 in Power Management
5,384 次查看
vinothkumars
Senior Contributor IV
Hi All,
I am working on IMX8QM-MEK with Android Automotive. I have some doubt regarding power management.
1. Is it possible to sleep/ wake up the head unit using from M4 ?
2. Is M4 Core have the cloud support ?
Thank You,
Vinoth S,
Vinothkumar Sekar
9 回复数
5,132 次查看
vinothkumars
Solution here,
IMX8QM-MEK Power Management difference between Linux and Android
VinothS.
Vinothkumar Sekar
5,132 次查看
chenguoyin
you may need to configure the M4's MU as a wakeup source for A core. And has simulate the power key event and send to A core.
Could you give a more detail description about your case? We may think how to add into our release.
5,132 次查看
vinothkumars
Hi chenguoyin‌
I able to put on deep sleep by using
    AP_POWER_STATE_REQ - 4, 2
Configure the timer for some of the min
And exit from Deep Sleep
   AP_POWER_STATE_REQ - 3,2
Vinoth S,
Vinothkumar Sekar
5,132 次查看
vinothkumars
Thank You chenguoyin‌ for the quick reply.
How to configure M4 is WakeUp source for A core ?
Will you please provide the configuration.
Able to suspend and wakeup by using this commands,
AP_POWER_STATE_REQ -  adb shell dumpsys activity service com.android.car inject-vhal-event 0x11410a00 4,2
Reference Link,
Power Management  |  Android Open Source Project
I have to configure user wakeup the system instead of internal timer. AP_POWER_STATE_REQ  using rtc timer to wakeup the system.
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
5,132 次查看
b36401
There is no such option. Sorry for the inconvenience.
2.
It is possible to use Ethernet on M4 core.
5,132 次查看
vinothkumars
Thank you Victor Linnik for the quick reply.
How to configure user to control the sleep and wakeup by Ethernet ?
by using mem - able to sleep and wakeup the system.
Is there any configuration USER to control the sleep and wakeup functionality from M4 ?
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
5,132 次查看
vinothkumars
Is there any documents/ reference for Power Management using ARM Cortex-M4 core ?
Vinoth S,
Vinothkumar Sekar
5,132 次查看
b36401
Sorry for the delay. I sent you some example code via direct message.
5,132 次查看
vinothkumars
Is anyone experience with M4 give some ideas ?
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
