Dear NXP team.
I have 2 questiosns...
1. AIPTZ
There are AIPSTZ_PACRs, AIPSTZ_OPACRs registers as bellow in the reference menual(Document Number: IMX6DQRM Rev. 3, 07/2015).
but no descriptions of AIPSTZ_PACRs, it only explain AIPSTZ_OPACRs
where can i find AIPSTZ_PACRs?
13.6 Initialization Information
The AIPS bridge should be programmed before use.
The following registers should be initialized: The Master Privilege Registers
(AIPSTZ_MPRs), the Peripheral Access Control registers (AIPSTZ_PACRs), and the
Off-platform Peripheral Access Control registers (AIPSTZ_OPACRs) described in AIPSTZ Memory Map/Register Definition.
2. AIPSTZx_MPR
As bellow description, I need to control AIPSTZx_MPR register.
and i could see something wonder.
I think i could write only AIPSTZx_MPR(0x0207_C000) to control MOROT0, MOROT1, MOROT2, MOROT3
But in the u-boot source code, it write 0x0207_C000 and 0x0207_C004 to control MOROT0, MOROT1 as bellow.
It's different with the reference menual.
then I should write 0x0207_C008,0x0207_C00C to control MOROT2, MOROT3?
Please give some guide in detailed as possible.
* Set all MPROTx to be non-bufferable, trusted for R/W, | |
* not forced to user-mode. | |
writel(0x77777777, &aips1->mprot0); | |
writel(0x77777777, &aips1->mprot1); |
and the physical memory dump is that
________address|________0________4________8________C_0123456789ABCDEF
AZSD:0207C000|>77777777 77777777 ???????? ???????? wwwwwwww????????
AZSD:0207C010| ???????? ???????? ???????? ???????? ????????????????
Have a good day.
MyungJin Hwang
Below are definitions for registers offsets :
#define AIPS_MPROT0_7_OFFSET 0x00
#define AIPS_MPROT8_15_OFFSET 0x04
#define AIPS_PACR0_7_OFFSET 0x20
#define AIPS_PACR8_15_OFFSET 0x24
#define AIPS_PACR16_23_OFFSET 0x28
#define AIPS_PACR24_31_OFFSET 0x2C
#define AIPS_OPACR0_7_OFFSET 0x40
#define AIPS_OPACR8_15_OFFSET 0x44
#define AIPS_OPACR16_23_OFFSET 0x48
#define AIPS_OPACR24_31_OFFSET 0x4C
#define AIPS_OPACR32_33_OFFSET 0x50
The AIPS_PACR registers are skipped in the RM.
2.
U-boot is based on preliminary i.MX6 specs, where master’s bit fields 4-15 (MPROT4-15)
were not declared as Reserved. Please follow the recent RM.
Yuri
