The i.MX 6 D/Q/DL/S/SL Android JB4.3_1.1.1 Patch release is now available on www.freescale.com
· Target HW boards
o i.MX6DL SABRE SD board
o i.MX6Q SABRE SD board
o i.MX6DQ SABRE AI board
o i.MX6DL SABRE AI board
o i.MX6SL EVK board
This patch release is based on the i.MX 6 Android JB 4.3_1.1.0-GA BSP release.
· Release Description
o To upgrade the GPU kernel and libraries to improve GPU stability
o To handle the Android SDK build failure
o To improve FSL OMX
The table below describes the contents of this release.
Release | Description |
Patches | Contains the patches included in this release. The patches are described in “Patch Description”. |
Documentation | Contains the following document: • i.MX 6 Android JB 4.3_1.1.1 Patch Release Notes: This document. |
· Patch Description
Please consult the release notes.
