Building QT for i.MX6
Prerequisites:
The build is verified on prebuilt rootfs(based on LTIB) which can be downloaded from freescale.com
EGL uses framebuffer backend
libEGL.so -> libEGL-fb.so
libGAL.so -> libGAL-fb.so
QT4.8
1. Download the git respository for qt4.8:
$ git clone http://git.gitorious.org/qt/qt.git qt
$ cd qt
Let us consider this as <QTDir>
2. Create /tftpboot and point your target fileystem. As like
$ mkdir -p /tftpboot
$ cd /tftpboot
$ ln -s $(ROOTFFS) rootfs
TBD:Need to work on this to use sysroot option
3. Create a build directory to install for the qt4 packages. This directory can be  in any location. For example,
$ mkdir /opt/qt4
$ sudo chown -R <username> /opt/qt4
Let us consider the the <installdir> as /opt/qt4
4. Extract the attached mkspecs(linux-imx6-g++.tar.gz) to  <QTDir>/mkspecs/qws/
5. Apply the attached cd 0001-add-i.MX6-EGL-support.patch attached to enable egl support for i.MX6
$ cd <QTDir>
$ patch -p1<0001-add-i.MX6-EGL-support.patch
6. Export CROSS-COMPILE location path to PATH
$ export PATH=$PATH:/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/
7. Enter to the <QTDir>. Do configure. You can select the options as you like. Here is an example
$ cd <QTDir>
$ ./configure -qpa -arch arm -xplatform qws/linux-imx6-g++ -no-largefile -no-accessibility \
-opensource -verbose -system-libpng -system-libjpeg -system-freetype -fast -opengl es2 -egl -confirm-license \
-qt-zlib  -qt-libpng  -no-webkit -no-multimedia \
-make examples -make demos \
-release -make libs -exceptions -no-qt3support -prefix <installdir>
8. When the configure summary is shown make sure the Qt has OpenGL ES 2.0 support. Do build
$ make
$ make install
9. Now need to build eglfs plugin
$ cd <QTDir>/src/plugins/platforms/eglfs
$ make
$ make install
    Now the eglfs will be installed to the QT Install directory.
10. By now all required QT files are in <install directory>
11. Copy the install directory to target filesystem
$ cp -rf /opt/qt4 /tftpboot/rootfs/opt/.
12. Running Qt apps on target
    - Boot the target either with NFS or SD Image
    - Ensure that folder <installdir> is copied on target file system at “/usr/local”.
    - Launch application using
$ cd /opt/qt4/examples/opengl/hellogl_es2
$ ./hellogl_es2 -platform eglfs
QT5
These steps are performed on the host
1. Download the git respository for qt5:
$ git clone git://gitorious.org/qt/qt5.git qt5
$ cd qt5
2. Create a build directory to install for the qt5 packages. This directory can be  in any loctation. For example,
$ sudo mkdir /opt/qt5
$ sudo chown -R <username> /opt/qt5
Let us consider the the installdir as /opt/qt5
3. Enter the Qt5 directory and run the init-repository script to download all the source code for
   Qt5. To download all the source code will take about an hour.
$ ./init-repository
Update:  In the latest Qt5 release the webkit library is included by default and there are some issues trying to compile it.
use the next line to avoid problems if not desired to use webkit.
$ ./init-repository --no-webkit
4. From the following path
$ gedit qtbase/mkspecs/devices/linux-imx6-g++/qmake.conf
5. At the top of the qmake.conf, there is a configure line. Copy and paste the configure line into a text file located
   in your build build directory. Edit the configure line to find your toolchain and filesystem. Also make sure to
   include the options -no-pch, -no-opengl, -opengl es2, Here is an example of
   a configure line.
Update: In the latest Qt5 stable, the option to compile the examples/demos is -compile-examples, instead of -make examples -make demos
If you are running into problems with webkit,  use the option -no-icu, this will disable the webkit.
$ cd <QTDir>
$ cd qtbase
$ ./configure -v -opensource -confirm-license -no-pch -no-xcb -no-opengl -opengl es2  \
        -make libs -device imx6 \
       -compile-examples \
      -device-option CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi- \
       -sysroot <rootfs> -no-gcc-sysroot \
7. Make the textfile that has the configure line and executable and run it. When the configure summary is shown make sure the Qt5 has openGL ES 2.0 support. Do build
$ make
$ sudo make install
   When Qt5 has finished building, Qt5 will be installed in two places:
           1. <location of rootfs>/<installdir>
           2. <HOST Machine>/<install dir>
This is good because now all the libraries and binaries for Qt5 are installed on the host and the target filesystem. Therefore, the target already has all the libraries and  binaries needed to run Qt5.
8. Also need to build qtjsbackend and qtdeclarative.
$ cd <location to Qt5 git>
$ cd qtjsbackend
$ ../qtbase/bin/qmake -r
$ make && sudo make install
$ cd qtdeclarative
$ make && sudo sudo make install
9. Running Qt apps on target
$ cd /opt/qt5/examples/opengl/hellowindow
$ ./hellowindow -platform eglfs
FAQ:
On the target file system, the location of target libaries and includes may present in arm-linux-gnueabi directory. Make sure to create soflinks to QT can find. For example
$ cd $(ROOTFS)/usr/lib
$ ln -s arm-linux-gnueabi/libffi.so.6 libffi.so.6
While building QT5, you may see a build error that libQt5V8.so.5 is not found. This might be some problem to be addressed in QT. Workaround is to
copy all the binaries to correct path as like this
$ cp  <ROOTFS>/<installdir>/lib/* <HOST Machine>/<installdir>/.
What is coming up next:
1. QT on X is already available on Yocto filesystem. Steps to enable GPU Acceleration TDB.
2. QT with Wayland support.
标签 (1)
附件
评论
Works like a charm. Thank you!
My only issue is that my mouse or keyboard doesn't work when running with eglfs. does eglfs support user input?
After running the configure command,  in the summary of supported features, OpenVG appears as not supported, is this normal or it means some library is missing on my side?
FAQ:
Question:
But I can not build qtdeclarative…
Project WARNING: Unknown build part(s): demos
Reading /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtdeclarative/src/src.pro
Reading /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtdeclarative/src/qml/qml.pro
Project MESSAGE: /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtbase/bin/syncqt -module QtQml -version 5.1.0 -outdir /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtdeclarative /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtdeclarative
<srcbase> = /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtdeclarative
<outbase> = /home/hp-lablinux/ltib_imx6solo_duallite/qt5/qtdeclarative
Project ERROR: Unknown module(s) in QT_PRIVATE: v8
Not sure what the problem is? I have looked around but not find any useful hints. Do you have an idea?
Solution:
“modify this file qtbase/bin/qt.conf
and add the correct prefix, the one given on cofigure
*configure
Question:
I follow the instruction as above to build QT5,
but I found the configure command is incorrect to my environment.
so I change the configure command as below:
./configure -v -opensource -confirm-license -system-sqlite -no-sse2 -no-sse3 -no-ssse3 -no-sse4.1 -no-sse4.2 -no-avx -no-xcb -no-sql-mysql -no-sql-db2 -no-sql-ibase -no-sql-oci -no-sql-odbc -no-sql-tds -no-sql-sqlite2  -no-pch -no-opengl -opengl es2  -wayland -make libs -device imx6 -make examples -make demos -device-option CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi- -sysroot /media/new-version/build/L3.0.35_4.0.0/ltib/rootfs -no-gcc-sysroot -prefix /usr/local/Trolltech/Qt5-imx6-1
It pass but I got problem when I run 'make'
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi-g++ -Wl,-rpath-link,/media/new-version/build/L3.0.35_4.0.0/ltib/rootfs/usr/lib -Wl,--no-undefined -Wl,-O1 -Wl,-rpath,/usr/local/Qt-5.0.0/Qt5-imx6-1/lib -shared -o libqsqlmysql.so .obj/release-shared/main.o .obj/release-shared/qsql_mysql.o .obj/release-shared/moc_qsql_mysql_p.o  -L/media/new-version/build/L3.0.35_4.0.0/ltib/rootfs/usr/lib -L/usr/lib -Wl,-Bsymbolic-functions -rdynamic -L/usr/lib/mysql -lmysqlclient_r -L/media/new-version/build/ltib/rpm/BUILD/qt5/qtbase/lib -lQt5Sql -lQt5Core -lpthread
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: skipping incompatible /usr/lib/libpthread_nonshared.a when searching for libpthread_nonshared.a
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: skipping incompatible /usr/lib/libc_nonshared.a when searching for libc_nonshared.a
.obj/release-shared/qsql_mysql.o: In function `QMYSQLDriver::open(QString const&, QString const&, QString const&, QString const&, int, QString const&)':
qsql_mysql.cpp:(.text+0x2cb4): undefined reference to `mysql_set_character_set'
collect2: ld returned 1 exit status
I have cancel the option of the mysql when configure the QT5!
How to solve this problem?
thanks!
Here's my configure script:
#!/bin/sh
./configure -v -opensource -confirm-license -no-pch -no-xcb -opengl es2 \
  -device-option CROSS_COMPILE=/home/squirem/Desktop/poky-dylan-9.0.0/build/tmp/sysroots/x86_64-linux/usr/bin/armv7a-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi- \
  -sysroot /home/squirem/Desktop/poky-dylan-9.0.0/build/tmp/deploy/images/mountpoint \
  -prefix /opt/qt5
Notice I removed the -no-opengl and -no-gcc-sysroot options. I think the -no-opengl option conflicts with the -opengl es2 option and the -no-gcc-sysroot option conflicts with the -sysroot <dir> option. You may also notice I added the -no-xcb option since xcb wasn't working for me.
As a side note, I think you can add more options to remove SQL support. Run ./configure -h to look at your options.
what is the meaning of "The build is verified on prebuilt rootfs(based on LTIB) which can be downloaded from freescale.com"  I have to build it with ltib or can i download it?  When I can download it, please explain how to use it on host.
To use LTIB makes little sense, because Yocto is preferred.
I try now to do LTIB for a couple of days without success.
regards
Joerg
He is referring to the prebuilt images which can be found under the "Operating System Software - Board Support Packages" section of whatever chip you're using. In my case, for the SabreSD board: L3.0.35_4.0.0_DEMO_IMAGE
You are right about LTIB and Yocto. Freescale is moving towards Yocto and the LTIB platform can be buggy. Use the Freescale community BSP instead: Freescale/fsl-community-bsp-platform · GitHub
The instructions are in the link. After compilation, an SD card image is generated that can be directly copied to an actual SD card and will run on whatever board you're using. There is already full Qt4 support and Qt5 support is only recently being added (added about a week ago).
So I can use a Image build with yocto? like fsl-image-gui-nitrogen6x.sdcard
I just checked what machines are supported in the BSP I linked to. It seems that your board nitrogen6x is supported, and there does appear to be a set of Qt4 recipes for the demo image you are referring to: Photo Album - Imgur
I have downloaded the Image (L3.0.35_4.0.0_130424_images_MX6)  How to put it on SD?
Follow the instructions that are in the documentation.  You can download the documentation package from freescale site.
sure that Qt5 is added?  Witch repo to check out? dylan  and what to build?
Joerg
It's on the master-next branch, so it's not ready quite yet.
I am trying to build Qt4 as per the instructions above.
In Step #2 is this command:
When I try to run it, it states that the variable "ROOTFFS: command not found."
Any idea why this failed?  I tried ROOTFS and still had the same error.
Is ROOTFFS the qt install directory?  Where is it defined?  It's not in my environment.
you  have to place  "/media/NameOfMountedRootFs"  as ROOTFFS
OK.  I used a link to ~/imx6/ltib/rootfs since I'm only doing NFS boot and I've already created a rootfs with LTIB.
Running configure generates several errors.
However, I am able to make and make install most of the files into /opt/qt4.
But the second bullet in Step #12 makes no sense.
Furthermore, there is no opt/qt4/examples directory.
Here is what is what is there:
root@freescale /$ ls opt/qt4
bin      include  lib      plugins
Any ideas of where I might be having problems.  I've followed the directions very carefully.
Brad
Hello Brad,
I will be the best someone who knows write a new Howto "Setup QT Creator" with Yocto based QT, rootfs and toolchain. But slowly I believe that no one really knows how to do that ;-)
Joerg
I was recently trying to build QT5 for iMX6 board using the instructions above.
rootfs: L3.0.35_4.0.0_UBUNTU_RFS
configure:
./configure -v -opensource -confirm-license -no-pch -no-xcb -no-opengl -opengl es2 -make libs -device imx6 -device-option CROSS_COMPILE=/opt/gcc-linaro-arm-linux-gnueabihf-4.8-2013.06_linux/bin/arm-linux-gnueabihf- -sysroot /home/max/Dev/rootfs -no-gcc-sysroot -prefix /opt/Qt5-imx6
unfortunately I have the following error:
/opt/gcc-linaro-arm-linux-gnueabihf-4.8-2013.06_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/../../../../arm-linux-gnueabihf/bin/ld: error: opengles2 uses VFP register arguments, opengles2.o does not
/opt/gcc-linaro-arm-linux-gnueabihf-4.8-2013.06_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file opengles2.o
/home/max/Dev/rootfs/usr/lib/libGAL.so: undefined reference to `XMapRaised'
/home/max/Dev/rootfs/usr/lib/libGAL.so: undefined reference to `pthread_setspecific@GLIBC_2.4'
/home/max/Dev/rootfs/usr/lib/libGAL.so: undefined reference to `_XReadPad'
/home/max/Dev/rootfs/usr/lib/libGAL.so: undefined reference to `dlopen@GLIBC_2.4'
/home/max/Dev/rootfs/usr/lib/libGAL.so: undefined reference to `pthread_key_delete@GLIBC_2.4'
/home/max/Dev/rootfs/usr/lib/libGAL.so: undefined reference to `XPending'
collect2: error: ld returned 1 exit status
make: *** [opengles2] Error 1
OpenGL ES 2.x disabled.
The OpenGL ES 2.0 functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_OPENGL_ES2, QMAKE_LIBDIR_OPENGL_ES2 and QMAKE_LIBS_OPENGL_ES2 in
/home/max/Dev/repository/qt5/qtbase/mkspecs/devices/linux-imx6-g++.
Then if I take out ES, I have: "Could not determine the target architecture!"
Can somebody comment on this? Any help?
Does the attached patch suppose to fix that?
Thanks!
Max
I followed the instructions to build QT4.8 for my target, Boundary's Nitrogen6x board. Unfortunately, in step 8, when it was building, I got the compiling error "fatal error: jpeglib.h: No such file or directory". I wonder if you guys have any comment about the error listing below.
cd "/home/byang/qt/./src/plugins/imageformats/jpeg"
make Makefile
make[4]: Entering directory `/home/byang/qt/src/plugins/imageformats/jpeg'
make[4]: `Makefile' is up to date.
make[4]: Leaving directory `/home/byang/qt/src/plugins/imageformats/jpeg'
make[3]: Leaving directory `/home/byang/qt/src/plugins/imageformats/jpeg'
make[3]: Entering directory `/home/byang/qt/src/plugins/imageformats/jpeg'
arm-fsl-linux-gnueabi-g++ -c -pipe -O2 -O2 -march=armv7-a -mfpu=neon -DLINUX=1 -DEGL_API_FB=1 -fvisibility=hidden -fvisibility-inlines-hidden -D_REENTRANT -Wall -W -fPIC -DQT_NO_DEBUG -DQT_PLUGIN -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I../../../../mkspecs/qws/linux-imx6-g++ -I. -I../../../../include/QtCore -I../../../../include/QtNetwork -I../../../../include/QtGui -I../../../../include -I../../../gui/image -I.moc/release-shared -I/home/byang/ltib/rootfs/usr/include -I/tftpboot/rootfs/usr/include/arm-linux-gnueabi/ -o .obj/release-shared/qjpeghandler.o ../../../gui/image/qjpeghandler.cpp
../../../gui/image/qjpeghandler.cpp:71:21: fatal error: jpeglib.h: No such file or directory
compilation terminated.
make[3]: *** [.obj/release-shared/qjpeghandler.o] Error 1
Hallo Bill,
no need to do that for 4.8
Have a look at this
https://community.freescale.com/message/339555#339555
Joerg
Hi Joerg,
Thanks for your replying my question. Currently I need to build QT4.8 on my image in LTIB. We shall late on consider the Yocto image since it has QT built in.
I googled and looked at the relate posts that mentioned needing to install libjpeg-dev. I wonder if any one in this thread knows how to fix?
No @ -no-gcc-sysroot vs. -sysroot
This was made for the freescale-linaro toolchain from ltib, because it doesn't allow you to set -sysroot as all the basic posix building-blooks were located within the toolchain and setting -sysroot in for gcc ruins it.
So the combination  of '-sysroot' and '-no-gcc-sysroot' results in Qt5 to do some magic in the background (e.g. PKG variables) but doesn't result in adding '--sysroot' to the gnu flags
Hi Zoltan,
i am having the same issue, also with another MPUs from several vendors. I have not solved it yet, but it looks like its a problem related with the rootfs, specifically with simlinks and lib paths.
There is a nice guide for a raspberry-pi device which i tried, and worked nice, but only with the rootfs image they specified (raspbian wheezy image): http://qt-project.org/wiki/RaspberryPi_Beginners_guide
When i tried to use my own rootfs, i have the problem you have had. Looks like the fix they propose could be the solution. That is to run a script to fix symlinks and libpaths, included in the croos-compiled-tools they provide.
I tried that but with no succes. Eventhough, everywhere in the web looks like that old configures files, can be a really headache, so it's really important to clean the files generated in the configure. Here it's very important to say, that the only actual way to do that, is cleaning the repository with:
    git submodule foreach --recursive "git clean -dfx"
because "make confclean" doesn't really work in Qt5 and "make clean" only cleans ol the .o and others files, but no all the configurations generated with ./configure. So, to download a tar.gz and use this a source code, should not be an option for Qt5.
Would really love to solve this problem with the imx6, using my own rootfs generated with buildroot (in my case). Any help?
Santiago
I followed the instructions and when I ran "bitbake core-image-minimal". It pop up following error.
Pseudo is not present but is required, building this first before the main build
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Please install the following missing utilities: gawk,chrpath
Then I ran "apt-get install gawk  chrpath". It pop up info as below.
The following packages were automatically installed and are no longer required:
libp11-kit-dev libgpg-error-dev comerr-dev libqt3-headers libgnutls-openssl27
libkrb5-dev liblcms1-dev libgnutlsxx27 libgssrpc4 libxt-dev libxmu-dev
libtasn1-3-dev libcups2-dev libqt3-compat-headers qt3-dev-tools libgcrypt11-dev
libkadm5clnt-mit8 libaudio-dev libkadm5srv-mit8 libxmu-headers libkdb5-6
libgnutls-dev krb5-multidev
Do I have to remove them using "apt-get autoremove     ......."?
Are you sure you followed the steps outlined here: https://github.com/Freescale/fsl-community-bsp-platform
Also, are you sure you have all the necessary software installed on your system. See the Yocto Project Quick Start Guide and look under packages: https://www.yoctoproject.org/docs/current/yocto-project-qs/yocto-project-qs.html
I'm guessing you're running Ubuntu, which means this command would install the software you need:
sudo apt-get install gawk wget git-core diffstat unzip texinfo \
  build-essential chrpath libsdl1.2-dev xterm
Hi squirem,
I got run bitbake fsl-image-gui, but I found the MACHINE=imx6qsabresd is not I wanted. My board is Nitrogen6x board from Boundary. How to change it to MACHINE=nitrogen6x? Could you please help?
By the way, I need Qt4.8.4 libraries on the image. Does the building image has been added Qt4.8.4?
Thanks.
Yes, I am running Ubuntu. I followed the article from the "Yocto With Boundary Device's Nitrogen6x: 5 steps only!" . I did not install all the necessary software on my system. I will do the installation as you point to me. Thanks again.
edit the build/conf/local.conf
I also have the same problem, Did U find any solution ragarding this
Hi I found some libs,
https://github.com/zOrg1331/fsl-gpu-viv-mx6q/tree/master/usr/lib, but
those are old,
and unfortunately they didn't solve all the problems. Incompatibility
issues remain.
with Regards,
Zoltan
U mean you also had that input issue.. The issue I am facing is once after I run the demo application ./hellowindow -platform eglfs.. i cant give any input(I want to use touch). Nothing is working regarding touch.. I exported all the necessary Tslib variables and all.
Did the library files which u found is anything to do with the touch issue..
You also mentioned "unfortunately they didn't solve all the problems"
No, I don't have those solved yet unfortunately...
with Regards,
Zoltan
Anyway thanks for the replay Zoltan :smileyhappy:
Oh.. you have any idea regarding that.
With Regards,
Sarjoon
Sorry, no, hopefully there will be an update with build in QT5 support...
I also tried to work out things with Qt4, but not much success there
either... = (
with Regards,
Zoltan
Yeah, I am also thinking to build it using QT5 now, Anyway thanks for your replies :smileyhappy:
cheers
Sarjoon
Hi all!
I followed the instructions to build QT4.8 for my target, Boundary's SABRElite board. Unexpectedly, in step 9 (Now need to build eglfs plugin), I got the compiling error
qeglfsscreen.cpp: In constructor 'QEglFSScreen::QEglFSScreen(EGLNativeDisplayType)':
qeglfsscreen.cpp:109:43: error: 'fbGetDisplayByIndex' was not declared in this scope
qeglfsscreen.cpp:110:57: error: 'fbGetDisplayGeometry' was not declared in this scope
qeglfsscreen.cpp: In member function 'void QEglFSScreen::createAndSetPlatformContext()':
qeglfsscreen.cpp:181:95: error: 'fbCreateWindow' was not declared in this scope
make: *** [.obj/release-shared/qeglfsscreen.o] Error 1
Any help?
Regards, Michael
Hi Michael,
These declarations should be in EGL/eglvivante.h:
~/ltib4-nox/rootfs/usr/include$ grep -r fbGetDisplayByIndex *
EGL/eglvivante.h:fbGetDisplayByIndex(
Did you include gpu-viv-bin-mx6q in your LTIB configuration?
Hi Eric!
Thanks for your answer.
Yes, I have these declarations in  EGL/eglvivante.h, but in my qt-4.8.4/src/plugins/platforms/eglfs/qeglfsscreen.cpp (after EGL support patch) I have no link to EGL/eglvivante.h
Where I need to add the reference to EGL/eglvivante.h, in qeglfsscreen.cpp, in qeglfsscreen.h or in eglfs.pro?
I added everywhere, but the effect isn't present, there is the same compilation error.
I don't use a LTIB, I use a ready freescale Ubuntu rootfs image L3.0.35_4.0.0_UBUNTU_RFS from https://community.freescale.com/docs/DOC-94809
Thanks again!
Regards, Michael
Eric, still question:
I have a SABRElite board, which runs freescale Ubuntu image with X-window desktop.
Now I want to run a QT application on X-window of my devboard.
This manual (Building QT for i.MX6) Is suitable for my task?
Thanks!
Regards, Michael
Hi Michael,
eglvivante.h is included by eglplatform.h, which is included by egl.h.
Do you have the configuration patches:
     qt4: Enable OpenGL ES2 support for i.MX6 · edcd4a6 · Freescale/meta-fsl-arm · GitHub
Hi Michael,
If you're running under X, you really want X to be accelerated, not Qt, and you should probably just use apt-get to install it.
Hi, all.
When i test qt5 example on target board, (./hellogl_es2) I have below error.
"This application failed to start because it could not find or load the Qt platform plugin "eglfs"."
Please share any tip about this eglfs error.
thank you.
jessie.
Building seems to work fine for me but when I try to start one of the example project I get this error:
root@freescale /opt/qt5/examples/opengl/hellowindow$ ./hellowindow -platform eglfs
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
idr_remove called for id=2126092104 which is not allocated.
[<8004f72c>] (unwind_backtrace+0x0/0x138) from [<8024d930>] (idr_remove+0x1f8/0x208)
[<8024d930>] (idr_remove+0x1f8/0x208) from [<802bb51c>] (drm_ctxbitmap_free+0x24/0x30)
[<802bb51c>] (drm_ctxbitmap_free+0x24/0x30) from [<802bba28>] (drm_rmctx+0x5c/0x10c)
[<802bba28>] (drm_rmctx+0x5c/0x10c) from [<802bc064>] (drm_ioctl+0x2d0/0x3b4)
[<802bc064>] (drm_ioctl+0x2d0/0x3b4) from [<8010b344>] (do_vfs_ioctl+0x80/0x558)
[<8010b344>] (do_vfs_ioctl+0x80/0x558) from [<8010b854>] (sys_ioctl+0x38/0x5c)
[<8010b854>] (sys_ioctl+0x38/0x5c) from [<80048600>] (ret_fast_syscall+0x0/0x30)
Segmentation fault
Any clue about what this can be?
   My QT4.8 had been built success,but when I test the example in my target board,it shows error:
   root@freescale /opt/qt4.8-arm-elink/examples/opengl/hellogl_es2$ ./hellogl_es2 -platform eglfs
./hellogl_es2: error while loading shared libraries: libQtOpenGL.so.4: cannot open shared object file: No such file or directory
   what can I do to solve it?
rds
I have following problem during build of latest Qt5.1
compiler/qv4isel_masm_p.h: In member function 'void QQmlJS::MASM::Assembler::storeUInt32(JSC::AbstractMacroAssembler<JSC::ARMAssembler>::RegisterID, QQmlJS::MASM::Assembler::Pointer)':
compiler/qv4isel_masm_p.h:1212:63: error: 'convertUInt32ToDouble' was not declared in this scope
compiler/qv4isel_masm_p.h: In member function 'void QQmlJS::MASM::InstructionSelection::convertUIntToDouble(QQmlJS::V4IR::Temp*, QQmlJS::V4IR::Temp*)':
compiler/qv4isel_masm_p.h:1491:18: error: 'class QQmlJS::MASM::Assembler' has no member named 'convertUInt32ToDouble'
compiler/qv4isel_masm_p.h:1493:18: error: 'class QQmlJS::MASM::Assembler' has no member named 'convertUInt32ToDouble'
compiler/qv4isel_masm.cpp: In member function 'virtual void QQmlJS::MASM::InstructionSelection::visitRet(QQmlJS::V4IR::Ret*)':
compiler/qv4isel_masm.cpp:1978:22: error: 'class QQmlJS::MASM::Assembler' has no member named 'convertUInt32ToDouble'
compiler/qv4isel_masm.cpp: In member function 'JSC::AbstractMacroAssembler<JSC::ARMAssembler>::Jump QQmlJS::MASM::InstructionSelection::genTryDoubleConversion(QQmlJS::V4IR::Expr*, JSC::MacroAssemblerARM::FPRegisterID)':
compiler/qv4isel_masm.cpp:2172:14: error: 'class QQmlJS::MASM::Assembler' has no member named 'convertUInt32ToDouble'
Qt5 git version
commit cb2d850b479fed9fed3c4a9fea698f924be942ef
Author: Qt Submodule Update Bot <qt_submodule_update_bot@ovi.com>
Date:   Tue Oct 15 22:00:06 2013 +0300
LTIB 4.
Kindly let me know if you have solution?
Thanks & Regards
That's a real bug in Qt, see workaround in: https://bugreports.qt-project.org/browse/QTBUG-34065
(I would guess you are actually compiling post 5.1 version, 5.1.1 should compile just fine. If you cloned the qt5 sources remember to checkout the appropriate git tag to get 5.1.1)
rds
Thanks Juha,
It seems with latest version of qtdeclarative this issue is fixed :smileyhappy:
Thanks again
I would like to cross compile tool chain and prebuilt rootfs based on ltib to cross compile Qt5.x for IMX6 Sabre AI board. Please let me know where can I download the same so that I can use the same cross compiler tool chain and rootfs used in this thread.
Ramakanth
%3CLINGO-SUB%20id%3D%22lingo-sub-1111319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%BA%20i.MX6%20%E6%9E%84%E5%BB%BA%20QT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%E5%85%88%E5%86%B3%E6%9D%A1%E4%BB%B6%3C%2FSTRONG%3E%3C%2FSPAN%3E%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E8%AF%A5%E6%9E%84%E5%BB%BA%E5%B7%B2%E5%9C%A8%E9%A2%84%E6%9E%84%E5%BB%BA%E7%9A%84%20rootfs%EF%BC%88%E5%9F%BA%E4%BA%8E%20LTIB%EF%BC%89%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%AA%8C%E8%AF%81%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BB%8E%20freescale.com%20%E4%B8%8B%E8%BD%BD%3C%2FP%3E%3CP%3EEGL%20%E4%BD%BF%E7%94%A8%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E5%90%8E%E7%AB%AF%3CBR%20%2F%3ElibEGL.so%20-%26gt%3B%20libEGL-fb.so%3CBR%20%2F%3ElibGAL.so%20-%26gt%3B%20libGAL-fb.so%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3EQT4.8%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E1.%E4%B8%8B%E8%BD%BDqt4.8%E7%9A%84git%E4%BB%93%E5%BA%93%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20git%20clone%20%3CA%20href%3D%22http%3A%2F%2Fgit.gitorious.org%2Fqt%2Fqt.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.gitorious.org%2Fqt%2Fqt.git%3C%2FA%3E%20qt%3CBR%20%2F%3E%24%20cd%20qt%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E5%B0%86%E5%85%B6%E8%A7%86%E4%B8%BA%20%26lt%3B%20%3CEM%3EQTDir%3C%2FEM%3E%20%26gt%3B%3C%2FP%3E%3CP%3E2.%E5%88%9B%E5%BB%BA%2F%20%3CEM%3Etftpboot%3C%2FEM%3E%E5%B9%B6%E6%8C%87%E5%90%91%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%E5%B0%B1%E5%83%8F%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20mkdir%20-p%20%2Ftftpboot%3C%2FP%3E%0A%3CP%3E%24%20cd%20%2Ftftpboot%3C%2FP%3E%0A%3CP%3E%24%20ln%20-s%20%24(ROOTFFS)%20%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%BE%85%E5%AE%9A%EF%BC%9A%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E6%AD%A4%E9%A1%B9%E5%B7%A5%E4%BD%9C%E6%89%8D%E8%83%BD%E4%BD%BF%E7%94%A8%20sysroot%20%E9%80%89%E9%A1%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E6%9D%A5%E5%AE%89%E8%A3%85%20qt4%20%E5%8C%85%E3%80%82%E8%AF%A5%E7%9B%AE%E5%BD%95%E5%8F%AF%E4%BB%A5%E4%BD%8D%E4%BA%8E%E4%BB%BB%E4%BD%95%E4%BD%8D%E7%BD%AE%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20mkdir%20%2Fopt%2Fqt4%3CBR%20%2F%3E%24%20sudo%20chown%20-R%20%3CUSERNAME%3E%20%2Fopt%2Fqt4%3C%2FUSERNAME%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%20%3CINSTALLDIR%3E%20%E8%A7%86%E4%B8%BA%3CEM%3E%2Fopt%2Fqt4%3C%2FEM%3E%3C%2FINSTALLDIR%3E%3C%2FP%3E%3CP%3E4.%20%E6%8F%90%E5%8F%96%E9%99%84%E4%BB%B6%E7%9A%84%20mkspecs(%20%3CEM%3Elinux-imx6-g%2B%2B.tar.gz%3C%2FEM%3E%20)%E5%88%B0%3CEM%3E%3CQTDIR%3E%2Fmkspecs%2Fqws%2F%3C%2FQTDIR%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E5.%20%E5%BA%94%E7%94%A8%E9%9A%8F%E9%99%84%E7%9A%84%20cd%20%3CEM%3E0001-add-i.MX6-EGL-support.patc%3C%2FEM%3E%20h%20%E4%BB%A5%E5%90%AF%E7%94%A8%20i.MX6%20%E7%9A%84%20egl%20%E6%94%AF%E6%8C%81%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%3CQTDIR%3E%3CBR%20%2F%3E%20%24%E8%A1%A5%E4%B8%81-p1%26lt%3B0001-add-i.MX6-EGL-support.patch%3C%2FQTDIR%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E6.%20%E5%B0%86%3CEM%3ECROSS-COMPILE%3C%2FEM%3E%E4%BD%8D%E7%BD%AE%E8%B7%AF%E5%BE%84%E5%AF%BC%E5%87%BA%E5%88%B0%3CEM%3EPATH%3C%2FEM%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%E5%AF%BC%E5%87%BA%E8%B7%AF%E5%BE%84%3D%24%E8%B7%AF%E5%BE%84%EF%BC%9A%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2F%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E7.%E8%BF%9B%E5%85%A5%3CEM%3E%3C%2FEM%3E%20%E3%80%82%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E9%80%89%E6%8B%A9%E9%80%89%E9%A1%B9%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E4%BE%8B%E5%AD%90%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%3CQTDIR%3E%3C%2FQTDIR%3E%3C%2FP%3E%0A%3CP%3E%24.%2Fconfigure-qpa%20-arch%20arm%20-xplatform%20qws%2Flinux-imx6-g%2B%2B%20-no-largefile%20-no-accessibility%20%5C%3CBR%20%2F%3E%20-%E5%BC%80%E6%BA%90-%E8%AF%A6%E7%BB%86-%E7%B3%BB%E7%BB%9F-libpng-%E7%B3%BB%E7%BB%9F-libjpeg-%E7%B3%BB%E7%BB%9F-freetype-%E5%BF%AB%E9%80%9F-OpenGL%20ES2-EGL-%E7%A1%AE%E8%AE%A4%E8%AE%B8%E5%8F%AF%E8%AF%81%5C%3CBR%20%2F%3E%20-qt-zlib%20-qt-libpng%20-no-webkit%20-no-%E5%A4%9A%E5%AA%92%E4%BD%93%20%5C%3CBR%20%2F%3E%20-make%20%E7%A4%BA%E4%BE%8B%20-make%3CBR%20%2F%3E%20%E6%BC%94%E7%A4%BA%20%5C%20-release%20-make%20libs%20-exceptions%20-no-qt3support%20-prefix%3CINSTALLDIR%3E%3C%2FINSTALLDIR%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E8.%20%E5%BD%93%E6%98%BE%E7%A4%BA%E9%85%8D%E7%BD%AE%E6%91%98%E8%A6%81%E6%97%B6%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%20Qt%20%E5%85%B7%E6%9C%89%3CEM%3EOpenGL%20ES%202.0%3C%2FEM%3E%E6%94%AF%E6%8C%81%E3%80%82%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20make%3CBR%20%2F%3E%20%24%20make%20install%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E9.%E7%8E%B0%E5%9C%A8%E9%9C%80%E8%A6%81%E6%9E%84%E5%BB%BA%3CEM%3Eeglfs%3C%2FEM%3E%E6%8F%92%E4%BB%B6%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%3CQTDIR%3E%2Fsrc%2Fplugins%2Fplatforms%2Feglfs%3CBR%20%2F%3E%20%24%20make%3CBR%20%2F%3E%20%24%20make%20install%3C%2FQTDIR%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%E7%8E%B0%E5%9C%A8%20eglfs%20%E5%B0%86%E5%AE%89%E8%A3%85%E5%88%B0%20QT%20%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E10.%E7%8E%B0%E5%9C%A8%E6%89%80%E6%9C%89%E5%BF%85%E9%9C%80%E7%9A%84%20QT%20%E6%96%87%E4%BB%B6%E9%83%BD%E5%9C%A8%3CINSTALL%20directory%3D%22%22%3E%3C%2FINSTALL%3E%3C%2FP%3E%3CP%3E11.%20%E5%B0%86%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%E5%A4%8D%E5%88%B6%E5%88%B0%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cp%20-rf%20%2Fopt%2Fqt4%20%2Ftftpboot%2Frootfs%2Fopt%2F%E3%80%82%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E12.%20%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%E8%BF%90%E8%A1%8C%20Qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E-%20%E4%BD%BF%E7%94%A8%20NFS%20%E6%88%96%20SD%20%E6%98%A0%E5%83%8F%E5%90%AF%E5%8A%A8%E7%9B%AE%E6%A0%87%3CBR%20%2F%3E-%20%E7%A1%AE%E4%BF%9D%E6%96%87%E4%BB%B6%E5%A4%B9%20%3CINSTALLDIR%3E%20%E8%A2%AB%E5%A4%8D%E5%88%B6%E5%88%B0%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E2%80%9C%2Fusr%2Flocal%E2%80%9D%E3%80%82%3CBR%20%2F%3E-%20%E4%BD%BF%E7%94%A8%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FINSTALLDIR%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%2Fopt%2Fqt4%2Fexamples%2Fopengl%2Fhellogl_es2%3CBR%20%2F%3E%20%24.%2Fhellogl_es2-%E5%B9%B3%E5%8F%B0%20eglfs%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSTRONG%3EQT5%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E6%89%A7%E8%A1%8C%3C%2FP%3E%3CP%3E1.%E4%B8%8B%E8%BD%BD%20qt5%20%E7%9A%84%20git%20%E4%BB%93%E5%BA%93%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20git%20clone%20git%3A%2F%2Fgitorious.org%2Fqt%2Fqt5.git%20qt5%3C%2FP%3E%0A%3CP%3E%24%20cd%20qt5%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E5%B0%86%E5%85%B6%E8%A7%86%E4%B8%BA%20%3CQTDIR%3E%3C%2FQTDIR%3E%3C%2FP%3E%3CP%3E2.%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E6%9D%A5%E5%AE%89%E8%A3%85%20qt5%20%E5%8C%85%E3%80%82%E8%AF%A5%E7%9B%AE%E5%BD%95%E5%8F%AF%E4%BB%A5%E4%BD%8D%E4%BA%8E%E4%BB%BB%E4%BD%95%E4%BD%8D%E7%BD%AE%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20sudo%20mkdir%20%2Fopt%2Fqt5%3C%2FP%3E%0A%3CP%3E%24%20sudo%20chown%20-R%3CUSERNAME%3E%20%2Fopt%2Fqt5%3C%2FUSERNAME%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%E8%A7%86%E4%B8%BA%20%2Fopt%2Fqt5%3C%2FP%3E%3CP%3E3.%E8%BF%9B%E5%85%A5Qt5%E7%9B%AE%E5%BD%95%EF%BC%8C%E8%BF%90%E8%A1%8Cinit-repository%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%B8%8B%E8%BD%BD%E6%89%80%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%3CBR%20%2F%3EQt5%E3%80%82%E4%B8%8B%E8%BD%BD%E6%89%80%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%E5%A4%A7%E7%BA%A6%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E5%B0%8F%E6%97%B6%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24.%2Finit-repository%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E6%9B%B4%E6%96%B0%EF%BC%9A%E5%9C%A8%E6%9C%80%E6%96%B0%E7%9A%84%20Qt5%20%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E9%BB%98%E8%AE%A4%E5%8C%85%E5%90%AB%20webkit%20%E5%BA%93%EF%BC%8C%E5%B0%9D%E8%AF%95%E7%BC%96%E8%AF%91%E5%AE%83%E6%97%B6%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%83%B3%E4%BD%BF%E7%94%A8%20webkit%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%B8%8B%E4%B8%80%E8%A1%8C%E6%9D%A5%E9%81%BF%E5%85%8D%E9%97%AE%E9%A2%98%E3%80%82%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%24%20.%2Finit-repository%20--no-webkit%20%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E4.%E4%BB%8E%E4%BB%A5%E4%B8%8B%E8%B7%AF%E5%BE%84%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20gedit%20qtbase%2Fmkspecs%2F%E8%AE%BE%E5%A4%87%2Flinux-imx6-g%2B%2B%2Fqmake.conf%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E5.%20%E5%9C%A8%20qmake.conf%20%E7%9A%84%E9%A1%B6%E9%83%A8%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E9%85%8D%E7%BD%AE%E8%A1%8C%E3%80%82%E5%A4%8D%E5%88%B6%E9%85%8D%E7%BD%AE%E8%A1%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E7%B2%98%E8%B4%B4%E5%88%B0%E4%BD%8D%E4%BA%8E%3CBR%20%2F%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%E3%80%82%E7%BC%96%E8%BE%91%E9%85%8D%E7%BD%AE%E8%A1%8C%E4%BB%A5%E6%89%BE%E5%88%B0%E6%82%A8%E7%9A%84%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%E8%BF%98%E8%A6%81%E7%A1%AE%E4%BF%9D%3CBR%20%2F%3E%E5%8C%85%E6%8B%AC%E9%80%89%E9%A1%B9%20-no-pch%E3%80%81-no-opengl%E3%80%81-opengl%20es2%EF%BC%8C%E4%B8%8B%E9%9D%A2%E6%98%AF%E7%A4%BA%E4%BE%8B%3CBR%20%2F%3E%E9%85%8D%E7%BD%AE%E8%A1%8C%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%3CEM%3E%E6%9B%B4%E6%96%B0%EF%BC%9A%E5%9C%A8%E6%9C%80%E6%96%B0%E7%9A%84%20Qt5%20%E7%A8%B3%E5%AE%9A%E7%89%88%E4%B8%AD%EF%BC%8C%E7%BC%96%E8%AF%91%E7%A4%BA%E4%BE%8B%2F%E6%BC%94%E7%A4%BA%E7%9A%84%E9%80%89%E9%A1%B9%E6%98%AF%20-compile-examples%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20-make%20examples%20-make%20demos%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%81%87%E5%88%B0%20webkit%20%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E9%80%89%E9%A1%B9%20-no-icu%EF%BC%8C%E8%BF%99%E5%B0%86%E7%A6%81%E7%94%A8%20webkit%E3%80%82%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%24%20cd%20%3CQTDIR%3E%3CBR%20%2F%3E%20%24%20cd%20qtbase%3CBR%20%2F%3E%20%24.%2Fconfigure-v%20-%E5%BC%80%E6%BA%90-%E7%A1%AE%E8%AE%A4%E8%AE%B8%E5%8F%AF%E8%AF%81-%E6%97%A0pch-%E6%97%A0xcb-%E6%97%A0opengl-opengl%20es2%20%5C%3CBR%20%2F%3E%20-%E5%88%B6%E4%BD%9C%E5%BA%93-%E8%AE%BE%E5%A4%87imx6%20%5C%3CBR%20%2F%3E%20-%E7%BC%96%E8%AF%91%E7%A4%BA%E4%BE%8B%20%5C%3CBR%20%2F%3E%20-%E8%AE%BE%E5%A4%87%E9%80%89%E9%A1%B9CROSS_COMPILE%20%3D%20%2F%20opt%20%2F%20freescale%20%2F%20usr%20%2F%20local%20%2F%20gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%20%2F%20fsl-linaro-toolchain%20%2F%20bin%20%2F%20arm-fsl-linux-gnueabi-%20%5C%3CBR%20%2F%3E%20-sysroot%3CROOTFS%3E%20-no-gcc-sysroot%20%5C%3CBR%20%2F%3E%20-prefix%3CINSTALLDIR%3E%3C%2FINSTALLDIR%3E%3C%2FROOTFS%3E%3C%2FQTDIR%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E7.%20%E5%88%B6%E4%BD%9C%E5%8C%85%E5%90%AB%E9%85%8D%E7%BD%AE%E8%A1%8C%E5%92%8C%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%E7%9A%84%E6%96%87%E6%9C%AC%E6%96%87%E4%BB%B6%E5%B9%B6%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%E5%BD%93%E6%98%BE%E7%A4%BA%E9%85%8D%E7%BD%AE%E6%91%98%E8%A6%81%E6%97%B6%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%20Qt5%20%E5%85%B7%E6%9C%89%20openGL%20ES%202.0%20%E6%94%AF%E6%8C%81%E3%80%82%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20make%3CBR%20%2F%3E%20%24%20sudo%20make%20install%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%20Qt5%20%E5%AE%8C%E6%88%90%E6%9E%84%E5%BB%BA%E5%90%8E%EF%BC%8CQt5%20%E5%B0%86%E5%AE%89%E8%A3%85%E5%9C%A8%E4%B8%A4%E4%B8%AA%E5%9C%B0%E6%96%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.%20%3CLOCATION%20of%3D%22%22%20rootfs%3D%22%22%3E%2F%3CINSTALLDIR%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.%20%3CHOST%20machine%3D%22%22%3E%2F%3CINSTALL%20dir%3D%22%22%3E%3C%2FINSTALL%3E%3C%2FHOST%3E%3C%2FINSTALLDIR%3E%3C%2FLOCATION%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%BE%88%E5%A5%BD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%8E%B0%E5%9C%A8%20Qt5%20%E7%9A%84%E6%89%80%E6%9C%89%E5%BA%93%E5%92%8C%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%83%BD%E5%AE%89%E8%A3%85%E5%9C%A8%E4%B8%BB%E6%9C%BA%E5%92%8C%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E4%B8%8A%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E7%9B%AE%E6%A0%87%E5%B7%B2%E7%BB%8F%E6%8B%A5%E6%9C%89%E8%BF%90%E8%A1%8C%20Qt5%20%E6%89%80%E9%9C%80%E7%9A%84%E6%89%80%E6%9C%89%E5%BA%93%E5%92%8C%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E8.%E8%BF%98%E9%9C%80%E8%A6%81%E6%9E%84%E5%BB%BAqtjsbackend%E5%92%8Cqtdeclarative%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%3CLOCATION%20to%3D%22%22%20qt5%3D%22%22%20git%3D%22%22%3E%3CBR%20%2F%3E%20%24%20cd%20qtjsbackend%3CBR%20%2F%3E%20%24%20..%2Fqtbase%2Fbin%2Fqmake%20-r%3CBR%20%2F%3E%20%24%20make%20%26amp%3B%26amp%3B%20sudo%20make%20install%3C%2FLOCATION%3E%3C%2FP%3E%0A%3CP%3E%24%20cd%3CLOCATION%20to%3D%22%22%20qt5%3D%22%22%20git%3D%22%22%3E%3CBR%20%2F%3E%20%24%20cd%20qtdeclarative%3CBR%20%2F%3E%20%24%20..%2Fqtbase%2Fbin%2Fqmake%20-r%3CBR%20%2F%3E%20%24%20make%20%26amp%3B%26amp%3B%20sudo%20sudo%20make%20install%3C%2FLOCATION%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E9.%20%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%E8%BF%90%E8%A1%8C%20Qt%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E-%20%E4%BD%BF%E7%94%A8%20NFS%20%E6%88%96%20SD%20%E6%98%A0%E5%83%8F%E5%90%AF%E5%8A%A8%E7%9B%AE%E6%A0%87%3CBR%20%2F%3E-%20%E7%A1%AE%E4%BF%9D%E6%96%87%E4%BB%B6%E5%A4%B9%20%3CINSTALLDIR%3E%20%E8%A2%AB%E5%A4%8D%E5%88%B6%E5%88%B0%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E2%80%9C%2Fusr%2Flocal%E2%80%9D%E3%80%82%3CBR%20%2F%3E-%20%E4%BD%BF%E7%94%A8%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FINSTALLDIR%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%2Fopt%2Fqt5%2Fexamples%2Fopengl%2Fhellowindow%3CBR%20%2F%3E%20%24.%2Fhellowindow-%E5%B9%B3%E5%8F%B0%20eglfs%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%B8%B8%E9%97%AE%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%9C%A8%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E7%9B%AE%E6%A0%87%E5%BA%93%E5%92%8C%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E7%9A%84%E4%BD%8D%E7%BD%AE%E5%8F%AF%E8%83%BD%E4%BD%8D%E4%BA%8E%20arm-linux-gnueabi%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E3%80%82%E7%A1%AE%E4%BF%9D%E5%88%9B%E5%BB%BA%20QT%20%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%9A%84%E8%BD%AF%E9%93%BE%E6%8E%A5%E3%80%82%E4%BE%8B%E5%A6%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20%24(ROOTFS)%2Fusr%2Flib%3CBR%20%2F%3E%20%24%20ln%20-s%20arm-linux-gnueabi%2Flibffi.so.6%20libffi.so.6%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%9E%84%E5%BB%BA%20QT5%20%E6%97%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E7%9C%8B%E5%88%B0%E6%9C%AA%E6%89%BE%E5%88%B0%20libQt5V8.so.5%20%E7%9A%84%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%20QT%20%E4%B8%AD%E9%9C%80%E8%A6%81%E8%A7%A3%E5%86%B3%E7%9A%84%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%98%AF%3CBR%20%2F%3E%E5%B0%86%E6%89%80%E6%9C%89%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%B7%AF%E5%BE%84%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cp%26nbsp%3B%20%3CROOTFS%3E%2F%3CINSTALLDIR%3E%2Flib%2F*%20%3CHOST%20machine%3D%22%22%3E%2F%3CINSTALLDIR%3E%2F.%3C%2FINSTALLDIR%3E%3C%2FHOST%3E%3C%2FINSTALLDIR%3E%3C%2FROOTFS%3E%3C%2FP%3E%0A%0A%0A%0A%0A%0A%0A%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%201.%20X%20%E4%B8%8A%E7%9A%84%20QT%20%E5%B7%B2%E5%9C%A8%20Yocto%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%8F%AF%E7%94%A8%E3%80%82%E5%90%AF%E7%94%A8%20GPU%20%E5%8A%A0%E9%80%9F%20TDB%20%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3CBR%20%2F%3E%202.%20%E6%94%AF%E6%8C%81%20Wayland%20%E7%9A%84%20QT%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1111319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E5%85%A8%E9%83%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2016%20%E5%B9%B4%208%20%E6%9C%88%2012%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%94%E4%B8%8A%E5%8D%88%2010%3A43%EF%BC%8Caravinthkumarjayaprakasam%20%26lt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E5%9C%A8%20Qt%20Form%20%E4%B8%AD%E5%8F%91%E5%B8%83%E6%82%A8%E7%9A%84%E6%9F%A5%E8%AF%A2%E3%80%82%E4%BB%96%E4%BB%AC%E4%BC%9A%E7%BB%99%E4%BA%88%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fforum.qt.io%2F%22%20title%3D%22https%3A%2F%2Fforum.qt.io%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%B8%BB%E9%A1%B5%20%7C%20Qt%20%E8%AE%BA%E5%9D%9B%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E9%98%BF%E6%8B%89%E6%96%87%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20aravinth%2C%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E6%98%8E%E7%99%BD%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E4%BA%86%E3%80%82INTEGRITY%20%E6%B2%A1%E6%9C%89%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E5%B9%B3%E5%8F%B0%3C%2FP%3E%3CP%3Eqt5.5%2Fqtbase%2Fmkspecs%2Fdevices%2F.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%3C%2FP%3E%3CP%3Eqt5.5%2Fqtbase%2Fmkspecs%2Fdevices%2F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%87%AA%E5%B7%B1%E7%9A%84%EF%BC%9F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%94%A8%E6%9D%A5%E9%85%8D%E7%BD%AE%E7%9B%AE%E6%A0%87%E7%9A%84%E5%AE%8C%E6%95%B4%E5%91%BD%E4%BB%A4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%85%8D%E7%BD%AE-embedded-xplatform%20qws%2Fintegrity-arm-cxarm-prefix%2F%3C%2FP%3E%3CP%3E-qt-sql-sqlite%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-embedded%20-%20%E6%9E%84%E5%BB%BA%20Qt%20%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-xplatform%20qws%2Fintegrity-arm-cxarm%20-%20%E9%80%89%E6%8B%A9%20arm-cxarm%20mkspec%3C%2FP%3E%3CP%3EINTEGRITY%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-qt-sql-sqlite%20-%20%E5%B0%86%20sqlite%20%E7%9B%B4%E6%8E%A5%E9%93%BE%E6%8E%A5%E5%88%B0%20Qt%20%E5%BA%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E4%BB%BB%E5%8A%A1%EF%BC%8C%E7%9B%AE%E6%A0%87%E5%BA%94%E8%AF%A5%E6%98%AFintegrity-arm-cxarm%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2016%20%E5%B9%B4%208%20%E6%9C%88%2012%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%94%E4%B8%8A%E5%8D%88%207%3A50%EF%BC%8Caravinthkumar%20jayaprakasam%20%26lt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fbharathadwajakodanda%22%20target%3D%22_blank%22%3Ebharathadwajakodanda%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%20Qt%20%E6%BA%90%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%9A%3C%2FP%3E%3CP%3E~%2Fqt5.5%2Fqtbase%2Fmkspecs%2Fdevices%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%8B%E5%90%8E%E6%88%91%E4%BC%9A%E7%BB%99%E4%BA%88%E4%BD%A0%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%B8%BA%20INTEGRITY%20RTOS%20%E9%85%8D%E7%BD%AE%E5%92%8C%E6%9E%84%E5%BB%BA%20Qt5.5%3F%3F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fpeterchiu%22%20target%3D%22_blank%22%3Epeterchiu%3C%2FA%3E%E2%80%8B%3C%2FP%3E%3CP%3EQt%205.5%20%E4%B8%AD%E6%B2%A1%E6%9C%89%20qws%E3%80%82%E5%B9%B6%E4%B8%94%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E6%88%91%E4%B9%9F%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E9%98%BF%E6%8B%89%E6%96%87%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8Caravinthkumar%20jayaprakasam%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%A4%8D%E5%88%B6%20qt4%20%E4%B8%8A%E7%9A%84%20qws.conf%EF%BC%8C%20%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%B0%86%20qws.conf%20%E6%94%BE%E5%85%A5%20qt-everywhere-opensource-src-xxx%2Fqtbase%2Fmkspecs%2Fcommon%2F%EF%BC%88xxx%20%E6%98%AF%E6%82%A8%E7%9A%84%20qt%20%E7%89%88%E6%9C%AC%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%20QT5.5.0%EF%BC%8C%E6%88%91%E6%83%B3%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%88%B0%20imx6-linux%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%2Fconfigure%20-v%20-opensource%20-confirm-license%20-no-pch%20-no-xcb%20-no-opengl%20-opengl%20es2%20%5C%3C%2FP%3E%3CP%3E-%E5%88%B6%E4%BD%9C%E5%BA%93-%E8%AE%BE%E5%A4%87imx6%20%5C%3C%2FP%3E%3CP%3E-%E7%BC%96%E8%AF%91%E7%A4%BA%E4%BE%8B%20%5C%3C%2FP%3E%3CP%3E-%E8%AE%BE%E5%A4%87%E9%80%89%E9%A1%B9CROSS_COMPILE%20%3D%20%2F%20opt%20%2F%20freescale%20%2F%20usr%20%2F%20local%20%2F%20gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%20%2F%20fsl-linaro-toolchain%20%2F%20bin%20%2F%20arm-fsl-linux-gnueabi-%20%5C%3C%2FP%3E%3CP%3E-sysroot%20%2Fhome%2Fzumi%2FProject%2FImx6q%2Frootfs%2FL3.0.35_4.1.0_130816_images_MX6%2FRootfs%2Fopt%2Fqt-no-gcc-sysroot%20%5C%3C%2FP%3E%3CP%3E-prefix%20%2Fopt%2Fqt-vision%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecc1plus%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%80%89%E9%A1%B9%E2%80%9C-fuse-ld%3Dgold%E2%80%9D%3C%2FP%3E%3CP%3Earm-fsl-linux-gnueabi-g%2B%2B%20-o%20libtest.so%20-shared%20-Wl%2C-Bsymbolic-functions%20-fPIC%20bsymbolic_functions.c%3C%2FP%3E%3CP%3Ebsymbolic_functions.c%3A2%3A2%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%23error%E2%80%9C%E6%AD%A4%E6%9E%B6%E6%9E%84%E4%B8%8A%E7%9A%84%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%8F%AF%E8%83%BD%E5%B7%B2%E6%8D%9F%E5%9D%8F%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%85%B6%E7%A6%81%E7%94%A8%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20QTBUG-36129%EF%BC%89%E3%80%82%E2%80%9D%3C%2FP%3E%3CP%3E%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%BB%B6%E4%BA%8B%EF%BC%8C%3C%2FP%3E%3CP%3EQT5.5.0%E6%B2%A1%E6%9C%89qws.conf%E6%96%87%E4%BB%B6%E3%80%82%E5%9B%A0%E6%AD%A4%E5%9C%A8%E6%82%A8%E9%99%84%E5%8A%A0%E7%9A%84%20qmake.conf%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%3CSPAN%20style%3D%22text-decoration%3A%20line-through%3B%22%3Einclude(..%2F..%2Fcommon%2Fqws.conf)%3C%2FSPAN%3E%E7%BA%BF%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%B8%8D%E5%88%A0%E9%99%A4%E8%AF%A5%E8%A1%8C%EF%BC%8C%E5%AE%83%E4%BC%9A%E6%98%BE%E7%A4%BA%E2%80%9C%3CEM%3E%E6%9C%AA%E6%89%BE%E5%88%B0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%E2%80%9D%E9%94%99%E8%AF%AF%3C%2FEM%3E%E3%80%82%E5%88%A0%E9%99%A4%E5%90%8E%E6%88%91%E6%94%B6%E5%88%B0%E4%B8%8A%E8%BF%B0%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E9%98%BF%E6%8B%89%E6%96%87%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Enishad%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E4%B8%BA%20imx6%20%E6%9E%84%E5%BB%BA%E4%BA%86%20Qt4.8.5%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40freescale%20%2Fopt%2Fqt4.8.5-arm-opengl%24%20cd%20examples%2Fopengl%2Fhellogl_es2%2F%3C%2FP%3E%3CP%3Eroot%40freescale%2Fopt%2Fqt4.8.5-arm-opengl%2Fexamples%2Fopengl%2Fhellogl_es2%24%20ls%3C%2FP%3E%3CP%3E%E6%B0%94%E6%B3%A1.cpp%20glwidget.h%E4%B8%BB%E7%A8%8B%E5%BA%8F%E7%BA%B9%E7%90%86.qrc%3C%2FP%3E%3CP%3Ebubble.h%20hellogl_es2%20%E4%B8%BB%E7%AA%97%E5%8F%A3.cpp%3C%2FP%3E%3CP%3Eglwidget.cpphellogl_es2.pro%E4%B8%BB%E7%AA%97%E5%8F%A3%3C%2FP%3E%3CP%3E%26lt%3B-opengl%2Fexamples%2Fopengl%2Fhellogl_es2%24%20.%2Fhellogl_es2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E6%B0%94%E6%B3%A1.cpp%20glwidget.h%E4%B8%BB%E7%A8%8B%E5%BA%8F%E7%BA%B9%E7%90%86.qrc%3C%2FP%3E%3CP%3Ebubble.h%20hellogl_es2%20%E4%B8%BB%E7%AA%97%E5%8F%A3.cpp%20%3C%2FP%3E%3CP%3Eglwidget.cpphellogl_es2.pro%E4%B8%BB%E7%AA%97%E5%8F%A3%20%3C%2FP%3E%3CP%3E%26lt%3B-opengl%2Fexamples%2Fopengl%2Fhellogl_es2%24%20.%2Fhellogl_es2-%E5%B9%B3%E5%8F%B0%20eglfs%3C%2FP%3E%3CP%3E%E5%88%86%E6%AE%B5%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3Eroot%40freescale%2Fopt%2Fqt4.8.5-arm-opengl%2Fexamples%2Fopengl%2Fhellogl_es2%24%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%A4%9F%E4%B8%BA%20imx6q%20%E7%BC%96%E8%AF%91%20QT5.5%20%E6%88%96%20QT%205.6%20%E5%90%97%EF%BC%9F%E8%AF%A5%E9%A1%B5%E9%9D%A2%E5%AF%B9%E6%88%91%E6%B2%A1%E6%9C%89%E5%A4%AA%E5%A4%A7%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%20QT%205%20%E7%BC%96%E8%AF%91%E9%83%A8%E5%88%86%E5%BC%95%E7%94%A8%E4%BA%86%20gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%20fsl%20%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E7%94%B1%E4%BA%8E%E5%AE%83%E7%9B%B8%E5%BD%93%E6%97%A7%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E4%B8%8B%E8%BD%BD%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%20linaro%20%E6%9C%80%E6%96%B0%E7%9A%84%20tolchain%204.8%20%E6%88%96%204.7%20QT%20%E5%88%99%E6%97%A0%E6%B3%95%E7%BC%96%E8%AF%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%93%AA%E4%B8%AA%E6%98%AF%E5%9C%A8%20imx6%20%E4%B8%8A%E7%BC%96%E8%AF%91%20QT%205.5%20%E6%88%96%20QT%205.6%20%E7%89%88%E6%9C%AC%E7%9A%84%E6%AD%A3%E7%A1%AE%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3CSPAN%20style%3D%22color%3A%20%239aa9af%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FPrabhuSundararaj%22%20target%3D%22_blank%22%3E%E5%B8%95%E5%B8%83%C2%B7%E6%A1%91%E8%BE%BE%E6%8B%89%E6%8B%89%E6%9D%B0%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3Egit%20url%E2%80%9Cgit%3A%2F%2Fgitorious.org%2Fqt%2Fqt5.git%20qt5%E2%80%9D%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%20qt5%20%E7%9A%84%E6%96%B0%20git%20url%20%E5%90%97%EF%BC%9F%E5%9B%A0%E4%B8%BA%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8LTIB%E7%A7%BB%E6%A4%8DQt5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%EF%BC%8C%E8%B0%A2%E8%B0%A2%E5%A4%A7%E5%AE%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%BA%9B%E8%A1%A5%E4%B8%81%E6%98%AF%E9%92%88%E5%AF%B9%20Qt4%20%E7%9A%84%EF%BC%8C%E4%B8%8D%E6%98%AF%E9%92%88%E5%AF%B9%20Qt5%20%E7%9A%84%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CNishad%EF%BC%8C%3C%2FP%3E%3CP%3E%20%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20LTIB%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E6%88%91%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%8C%89%E7%85%A7%E6%9C%AC%E9%A1%B5%E4%B8%8A%E6%8F%90%E5%88%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%89%8B%E5%8A%A8%E6%9E%84%E5%BB%BA%E4%BA%86%20QT4.8%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E9%85%8D%E7%BD%AE%E8%84%9A%E6%9C%AC%E4%B8%8E%E6%AD%A4%E5%A4%84%E7%BB%99%E5%87%BA%E7%9A%84%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%2Fconfigure%20-qpa%20-arch%20arm%20-xplatform%20qws%2Flinux-imx6-g%2B%2B%20-no-largefile%20-no-accessibility%20%5C%3C%2FP%3E%3CP%3E-%E5%BC%80%E6%BA%90-%E8%AF%A6%E7%BB%86-%E7%B3%BB%E7%BB%9F-libpng-%E7%B3%BB%E7%BB%9F-libjpeg-%E7%B3%BB%E7%BB%9F-freetype-%E5%BF%AB%E9%80%9F-OpenGL%20ES2-EGL-%E7%A1%AE%E8%AE%A4%E8%AE%B8%E5%8F%AF%E8%AF%81%5C%3C%2FP%3E%3CP%3E-qt-zlib%26nbsp%3B%20-qt-libpng%26nbsp%3B%20-no-webkit%20-no-multimedia%20%5C%3C%2FP%3E%3CP%3E-make%20examples%20-make%20demos%20%5C%3C%2FP%3E%3CP%3E-release%20-make%20libs%20-exceptions%20-no-qt3support%20-prefix%20%2Fopt%2Fqt4%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%B8%95%E9%87%8C%E6%89%98%E4%BB%80%C2%B7%E8%BE%9B%E6%A0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E6%9B%B4%E5%A4%9A%E6%9C%89%E5%85%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%20LTIB%20%E8%BF%98%E6%98%AF%20Yocto%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E6%82%A8%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%89%8B%E5%8A%A8%E6%9E%84%E5%BB%BA%E4%BA%86%20QT%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E8%84%9A%E6%9C%AC%E5%8F%91%E9%80%81%E7%BB%99%E6%88%91%E5%90%97%EF%BC%9F%E6%9C%89%E5%8F%AF%E8%83%BD%20QT%20%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B0%BC%E6%B2%99%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111388%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E4%B8%BA%20imx6%20%E6%9E%84%E5%BB%BA%E4%BA%86%20Qt4.8%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%80%9C%E6%97%A0%E6%B3%95%E5%88%9B%E5%BB%BA%20egl%20%E8%A1%A8%E9%9D%A2%EF%BC%9A%E9%94%99%E8%AF%AF%20%3D%200x300b%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E6%91%86%E8%84%B1%E8%BF%99%E4%B8%80%E5%9B%B0%E5%A2%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EParitosh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%BE%88%E6%A3%92%E7%9A%84%E6%95%99%E7%A8%8B...%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E7%BB%99%E6%88%91%E8%AE%B2%E8%AE%B2%20qt%20webkit%20%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E6%B8%B2%E6%9F%93%E5%9F%BA%E4%BA%8E%20HTML5%20%E7%9A%84%E5%85%A8%E5%B1%8F%E7%BD%91%E9%A1%B5...%E6%88%91%E5%AF%B9%20qt%20%E8%BF%98%E5%BE%88%E9%99%8C%E7%94%9F...%E8%AF%B7%E6%8C%87%E5%AF%BC%E6%88%91%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E6%9C%AC%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%E6%96%B9%E6%B3%95%E6%9E%84%E5%BB%BA%20qt5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E5%91%BD%E4%BB%A4%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%2Fconfigure%20-v%20-opensource%20-confirm-license%20-make%20libs%20-device%20imx6%20-device-option%20CROSS_COMPILE%3D%2Fhome%2Fx0158990%2Fhdd%2Ftools%2Fpoky%2F1.7%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-%20-sysroot%20%2Fhome%2Fx0158990%2Fhdd%2Ftools%2Fpoky%2F1.7%2Fsysroots%2Fx86_64-pokysdk-linux-no-gcc-sysroot%20-prefix%20%2Fhome%2Fx0158990%2Fwork%2Ftools%2FQT5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%E9%A2%84%E7%BC%96%E8%AF%91%E5%A4%B4%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%2Fhome%2Fx0158990%2Fhdd%2Ftools%2Fpoky%2F1.7%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-g%2B%2B%20-c%20-fvisibility%3Dhidden%20fvisibility.c%3C%2FP%3E%3CP%3E%E5%B7%B2%E5%90%AF%E7%94%A8%E7%AC%A6%E5%8F%B7%E5%8F%AF%E8%A7%81%E6%80%A7%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%2Fhome%2Fx0158990%2Fhdd%2Ftools%2Fpoky%2F1.7%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%2Fbin%2Farm-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-g%2B%2B%20-o%20libtest.so%20-shared%20-Wl%2C-Bsymbolic-functions%20-fPIC%20bsymbolic_functions.c%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebsymbolic_functions.c%3A2%3A2%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%23error%E2%80%9C%E6%AD%A4%E6%9E%B6%E6%9E%84%E4%B8%8A%E7%9A%84%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%8F%AF%E8%83%BD%E5%B7%B2%E6%8D%9F%E5%9D%8F%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%85%B6%E7%A6%81%E7%94%A8%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20QTBUG-36129%EF%BC%89%E3%80%82%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%20%23error%E2%80%9C%E6%AD%A4%E6%9E%B6%E6%9E%84%E4%B8%8A%E7%9A%84%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%8F%AF%E8%83%BD%E5%B7%B2%E6%8D%9F%E5%9D%8F%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%85%B6%E7%A6%81%E7%94%A8%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20QTBUG-36129%EF%BC%89%E3%80%82%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%5E%3C%2FP%3E%3CP%3E%E7%AC%A6%E5%8F%B7%E5%87%BD%E6%95%B0%E7%BB%91%E5%AE%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%3CSTRONG%3EQTBUG-36129%3C%2FSTRONG%3E%20bug%E7%9A%84%E6%8F%8F%E8%BF%B0%E4%B8%AD%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E9%80%82%E7%94%A8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E8%84%9A%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%2Fconfigure%20-v%20-opensource%20-confirm-license%20-no-sse2%20-no-sse3%20-no-ssse3%3C%2FP%3E%3CP%3E-no-sse4.1%20-no-sse4.2%20-no-avx%20-no-xcb%20-no-sql-mysql%20-no-sql-db2%3C%2FP%3E%3CP%3E-no-sql-ibase%20-no-sql-oci%20-no-sql-odbc%20-no-sql-tds%20-no-sql-sqlite2%20%3C%2FP%3E%3CP%3E-no-pch%20-no-opengl%20-opengl%20es2%20-wayland%20-make%20libs%20-device%20imx6%20-make%3C%2FP%3E%3CP%3E%E7%A4%BA%E4%BE%8B-%E8%AE%BE%E5%A4%87%E9%80%89%E9%A1%B9%3C%2FP%3E%3CP%3ECROSS_COMPILE%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-fsl-linux-gnueabi-%3C%2FP%3E%3CP%3E-sysroot%20%2Fhome%2Fsumeet%2Fltib%2Frootfs%20-no-gcc-sysroot%20-prefix%20%2Fusr%2Flocal%2FQT_5%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E4%BB%94%E7%BB%86%E9%81%B5%E5%BE%AA%E9%93%BE%E6%8E%A5%E4%BB%A5%E5%8F%8A%E7%BB%99%E5%87%BA%E7%9A%84%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E4%B8%8A%E9%9D%A2%E7%9A%84%E5%BD%93%E5%89%8D%E9%93%BE%E6%8E%A5%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fqt-project.org%2Fwiki%2FRaspberryPi_Beginners_guide%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fqt-project.org%2Fwiki%2FRaspberryPi_Beginners_guide%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E2%80%9C%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%B7%A5%E5%85%B7%E2%80%9D%E6%9D%A5%E7%BC%96%E8%AF%91%20QT-5%20%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%BD%BF%E7%94%A8%E8%AF%A5%E9%93%BE%E6%8E%A5%E6%9E%84%E5%BB%BA%E5%8D%95%E7%8B%AC%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%8B%E8%BD%BD%E5%AE%83%E5%B9%B6%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%BB%99%E5%87%BA%E7%9A%84%E8%84%9A%E6%9C%AC%E6%9D%A5%E8%AE%BE%E7%BD%AE%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E6%B8%85%E7%90%86%3C%2FSTRONG%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3Ea_config_if_compile_wrong%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Esudo%20git%20%E5%AD%90%E6%A8%A1%E5%9D%97%20foreach%20--recursive%20%E2%80%9Cgit%20clean%20-dfx%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E8%AE%BE%E7%BD%AE%E8%B7%AF%E5%BE%84%E7%9A%84%E8%84%9A%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E.%2FfixQualifiedLibraryPaths%20%2Fhome%2Fsumeet%2Fltib%2Frootfs%3C%2FP%3E%3CP%3E%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-fsl-linux-gnueabi-g%2B%2B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%94%B6%E5%88%B0%E5%AD%97%E4%BD%93%E9%85%8D%E7%BD%AE%E9%94%99%E8%AF%AF%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%E5%88%86%E6%9E%90%E6%9D%A5%E8%A7%A3%E5%86%B3%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%99%BD%E7%84%B6%E6%88%91%E8%83%BD%E5%A4%9F%E5%AE%89%E8%A3%85%20QT5%EF%BC%8C%E4%BD%86%E5%AD%97%E4%BD%93%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E5%9C%A8%20GUI%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E5%AD%97%E4%BD%93%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8A%AA%E5%8A%9B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E5%B0%BC%E6%B2%99%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%20nishad%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E7%AD%89%E5%BE%85%E4%BD%A0%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%81%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%20%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%88%90%E5%8A%9F%E5%9C%B0%E4%B8%BA%E6%88%91%E7%9A%84%E5%AE%9A%E5%88%B6%20iMX6Q%20%E6%9D%BF%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E4%BA%86%20QT5%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20LTIB%203.0.35_4.1.0%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%E6%88%91%E7%9A%84%20u-boot%E3%80%81%E5%86%85%E6%A0%B8%E5%92%8C%20rootfs%20%E7%9A%84%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%88%91%E5%87%86%E5%A4%87%E7%9A%84%E6%96%87%E6%A1%A3%E5%92%8C%E9%93%BE%E6%8E%A5%EF%BC%8C%E4%BB%A5%E5%B8%AE%E5%8A%A9%E4%BB%BB%E4%BD%95%E4%BA%BA%20%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E6%9E%84%E5%BB%BA%20QT5%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E4%B8%8D%E4%BC%9A%E7%9B%B4%E6%8E%A5%E5%B8%AE%E5%8A%A9%E4%BD%A0%EF%BC%8C%E4%BD%86%E6%98%AF%E8%AF%A5%E7%A8%8B%E5%BA%8F%20%3C%2FP%3E%3CP%3E%E5%BA%94%E8%AF%A5%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%B0%BC%E6%B2%99%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CEM%3E%3CSTRONG%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%BA%20udoo%20%E5%9B%9B%E6%A0%B8%E4%B8%BB%E6%9D%BF%E6%9E%84%E5%BB%BA%20qt5%EF%BC%88%E4%BD%BF%E7%94%A8%20imx6%20%E5%9B%9B%E6%A0%B8%3CA%20href%3D%22http%3A%2F%2Fwww.udoo.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.udoo.org%2F%3C%2FA%3E%20%EF%BC%89%E4%BD%86%E6%88%91%E5%9C%A8.%2Fconfigure%E5%A4%84%E8%A2%AB%E9%98%BB%E6%AD%A2%E4%BA%86%E3%80%82%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E%3CEM%3E%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Ffsl-linaro-toolchain%2Farm-fsl-linux-gnueabi%2Fbin%2Fg%2B%2B%20-c%20-pipe%20-march%3Darmv7-a%20-mfpu%3Dneon%20-DLINUX%3D1%20-DEGL_API_FB%3D1%20-mfloat-abi%3Dsoftfp%20-g%20-Wall%20-W%20-fPIE%20-I..%2F..%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B%20-I.%20-I..%2F..%2F..%2F..%2Fusr%2Finclude%20-I..%2F..%2F..%2F..%2Fusr%2Fbin%20-o%20arch.o%20arch.cpp%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eg%2B%2B%EF%BC%9A%E5%B0%9D%E8%AF%95%E6%89%A7%E8%A1%8C%E2%80%9Ccc1plus%E2%80%9D%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9Aexecvp%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E9%80%89%E9%A1%B9%20-march%3D%20invalide%EF%BC%9A%E3%80%8Aarmv7-a%E3%80%8B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Egmake%EF%BC%9A***%20%5Barch.o%5D%20%E9%94%99%E8%AF%AF%201%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E6%9E%B6%E6%9E%84%EF%BC%81%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3E%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%9E%B6%E6%9E%84%EF%BC%81%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%89%93%E5%BC%80%E8%AF%A6%E7%BB%86%E6%B6%88%E6%81%AF%E4%BC%A0%E9%80%92%EF%BC%88-v%EF%BC%89%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%9C%80%E7%BB%88%E6%8A%A5%E5%91%8A%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E7%A1%AE%E5%AE%9A%E6%9E%B6%E6%9E%84...()%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eg%2B%2B%20-c%20-pipe%20-g%20-Wall%20-W%20-fPIE%20-I..%2F..%2Fmkspecs%2Flinux-g%2B%2B%20-I.%20-o%20arch.o%20arch.cpp%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eg%2B%2B%20-o%20arch%20arch.o%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E4%BB%A5%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%BD%A2%E5%BC%8F%E6%89%BE%E5%88%B0%E6%9E%B6%E6%9E%84%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ECFG_HOST_ARCH%3D%22i386%22%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3ECFG_HOST_CPUFEATURES%3D%22%22%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E7%B3%BB%E7%BB%9F%E6%9E%B6%E6%9E%84%EF%BC%9A%E6%9C%AA%E7%9F%A5%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E4%B8%BB%E6%9C%BA%E6%9E%B6%E6%9E%84%EF%BC%9A'i386'%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EC%2B%2B11%20%E8%87%AA%E5%8A%A8%E6%A3%80%E6%B5%8B...()%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Ffsl-linaro-toolchain%2Farm-fsl-linux-gnueabi%2Fbin%2Fg%2B%2B%20-c%20-pipe%20-march%3Darmv7-a%20-mfpu%3Dneon%20-DLINUX%3D1%20-DEGL_API_FB%3D1%20-mfloat-abi%3Dsoftfp%20-O2%20-std%3Dc%2B%2B0x%20-Wall%20-W%20-fPIE%20-I..%2F..%2F..%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B%20-I.%20-I%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Finclude%20-I%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Fbin%20-o%20c%2B%2B11.o%20c%2B%2B11.cpp%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eg%2B%2B%EF%BC%9A%E5%B0%9D%E8%AF%95%E6%89%A7%E8%A1%8C%E2%80%9Ccc1plus%E2%80%9D%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9Aexecvp%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E9%80%89%E9%A1%B9%20-march%3D%20invalide%EF%BC%9A%E3%80%8Aarmv7-a%E3%80%8B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Egmake%EF%BC%9A***%20%5Bc%2B%2B11.o%5D%20%E9%94%99%E8%AF%AF%201%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EC%2B%2B11%20%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E.......%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E......%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E......%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E......%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E%3CEM%3EOpenGL%20ES%202.x%20%E8%87%AA%E5%8A%A8%E6%A3%80%E6%B5%8B...()%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Ffsl-linaro-toolchain%2Farm-fsl-linux-gnueabi%2Fbin%2Fg%2B%2B%20-c%20-pipe%20-march%3Darmv7-a%20-mfpu%3Dneon%20-DLINUX%3D1%20-DEGL_API_FB%3D1%20-mfloat-abi%3Dsoftfp%20-O2%20-Wall%20-W%20-fPIE%20-I..%2F..%2F..%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B%20-I.%20-I%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Finclude%2FGLES2%20-I%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Finclude%20-I%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Fbin%20-o%20opengles2.o%20opengles2.cpp%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eg%2B%2B%EF%BC%9A%E5%B0%9D%E8%AF%95%E6%89%A7%E8%A1%8C%E2%80%9Ccc1plus%E2%80%9D%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9Aexecvp%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9A%E9%80%89%E9%A1%B9%20-march%3D%20invalide%EF%BC%9A%E3%80%8Aarmv7-a%E3%80%8B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Egmake%3A%20***%20%5Bopengles2.o%5D%20%E9%94%99%E8%AF%AF%201%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EOpenGL%20ES%202.x%20%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EOpenGL%20ES%202.0%20%E5%8A%9F%E8%83%BD%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%EF%BC%81%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%E7%BC%96%E8%BE%91%E6%9D%A5%E4%BF%AE%E6%94%B9%E5%8C%85%E5%90%AB%E5%92%8C%E5%BA%93%E6%90%9C%E7%B4%A2%E8%B7%AF%E5%BE%84%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_INCDIR_OPENGL_ES2%E3%80%81QMAKE_LIBDIR_OPENGL_ES2%20%E5%92%8C%20QMAKE_LIBS_OPENGL_ES2%20%E4%B8%AD%E7%9A%84%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fqt5%2Fqtbase%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B%E3%80%82%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E%3CSTRONG%3E%E6%9C%89%E5%85%B3%20Udoobuntu%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.udoo.org%2Fdownloads%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.udoo.org%2Fdownloads%2F%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E%3CSTRONG%3E%20%E6%9C%AC%E6%95%99%E7%A8%8B%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.udoo.org%2FProjectsAndTutorials%2Fhow-to-build-qt5-for-udoo%2F%3FportfolioID%3D1394%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.udoo.org%2FProjectsAndTutorials%2Fhow-to-build-qt5-for-udoo%2F%3F%3C%2FA%3E%20portfolioID%3D1394%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E%3CSTRONG%3E%E6%88%91%E7%9A%84qmake.conf%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3Einclude(..%2Fcommon%2Flinux_device_pre.conf)%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EROOTFS_PATH%3D%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3ETOOLCHAIN_PREFIX%3D%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Ffsl-linaro-toolchain%2Farm-fsl-linux-gnueabi%2Fbin%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EEGLFS_PLATFORM_HOOKS_SOURCES%20%3D%20%24%24PWD%2Fqeglfshooks_imx6.cpp%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_INCDIR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%24%24%7BROOTFS_PATH%7D%2Fusr%2Finclude%20%24%24%7BROOTFS_PATH%7D%2Fusr%2Fbin%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_LIBDIR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%24%24%7BROOTFS_PATH%7D%2Fusr%2Flib%2Farm-linux-gnueabihf%20%24%24%7BROOTFS_PATH%7D%2Fusr%2Flib%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_INCDIR_OPENGL_ES2%20%2B%3D%20%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Finclude%2FGLES2%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_LIBDIR_OPENGL_ES2%20%2B%3D%20%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Flib%2FGLESv2%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3E%23QMAKE_LIBS_EGL%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Flib%2FGLESv2%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23QMAKE_LIBS_OPENGL_ES2%26nbsp%3B%20%2B%3D%20%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Flib%2FGLESv2%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23QMAKE_LIBS_OPENVG%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fusr%2Flib%2FOpenVG%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_LIBS_EGL%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20-lEGL%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_LIBS_OPENGL_ES2%26nbsp%3B%20%2B%3D%20-lGLESv2%20-lEGL%20-lGAL%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_LIBS_OPENVG%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20-lOpenVG%20-lEGL%20-lGAL%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_LFLAGS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20-Wl%2C-rpath-link%2C%24%24%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Flib%2Farm-linux-gnueabihf%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3EIMX6_CFLAGS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-march%3Darmv7-a%20-mfpu%3Dneon%20-DLINUX%3D1%20-DEGL_API_FB%3D1%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_CFLAGS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%24%24IMX6_CFLAGS%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EQMAKE_CXXFLAGS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%24%24IMX6_CFLAGS%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3Einclude(..%2Fcommon%2Flinux_arm_device_post.conf)%3C%2FEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CEM%3Eload(qt_config)%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%92%8C%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3E.%2Fconfigure%20-prefix%20%2Fopt%2Fqt5%20-make%20libs%20-no-pch%20-no-opengl%20-device%20imx6%20-device-option%20CROSS_COMPILE%3D%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Ffsl-linaro-toolchain%2Farm-fsl-linux-gnueabi%2Fbin%2F%20-no-largefile%20-opengl%20es2%20-qt-zlib%20-qt-libpng%20-qt-libjpeg%20-no-nis%20-no-cups%20-gui%20-make%20examples%20-sysroot%20%2Fhome%2Fmodjo%2FUdoo%2FQt5_build%2Fexemples%20-no-gcc-sysroot%20-opensource%20-confirm-license%20-qreal%20float%20-v%3CSPAN%20style%3D%22font-family%3A%20mceinline%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-family%3A%20mceinline%3B%22%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BB%8E%20yocto%20%E9%A1%B9%E7%9B%AE%E7%9A%84%20dora%20%E5%88%86%E6%94%AF%E6%9E%84%E5%BB%BA%20qt-5.1.1%E3%80%82%E6%89%80%E6%9C%89%E4%BC%98%E7%A7%80%E7%9A%84%E4%BD%9C%E5%93%81%E9%83%BD%E6%9D%A5%E8%87%AA%20qtwebkit-examples%20%E4%B8%AD%E7%AE%80%E5%8D%95%E7%9A%84%E6%B5%8F%E8%A7%88%E5%99%A8%E7%9A%84%20HTML5%20%E8%A7%86%E9%A2%91%3C%2FP%3E%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E6%92%AD%E6%94%BE%E5%99%A8%E6%8E%A7%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%98%AF%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%9C%A8%E6%9F%90%E4%BA%9B%E8%A7%86%E9%A2%91%E4%B8%8A%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E8%A7%86%E9%A2%91%E7%9A%84%E5%AE%9A%E6%A0%BC%E5%B8%A7%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E6%92%AD%E6%94%BE%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%20gstreamer%20%E8%BE%93%E5%87%BA%E5%A6%82%E4%B8%8B%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQt%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E7%B3%BB%E7%BB%9F%20Compose%20%E6%96%87%E4%BB%B6%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%E8%80%83%E8%99%91%E8%AE%BE%E7%BD%AE%20QTCOMPOSE%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3Elibpng%20%E8%AD%A6%E5%91%8A%EF%BC%9AiCCP%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E5%B7%B2%E7%BC%96%E8%BE%91%E7%9A%84%E5%B7%B2%E7%9F%A5%20sRGB%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%9B%E5%BA%A6%E9%9D%99%E6%AD%A2%E6%97%B6%E6%94%B6%E5%88%B0%E5%AE%8C%E6%88%90%E4%BF%A1%E5%8F%B7%EF%BC%9A10%20Url%EF%BC%9AQUrl(%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fqt-project.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fqt-project.org%2F%3C%2FA%3E%20%3CSPAN%3E%E2%80%9D)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAiur%3A%203.0.11%20%3C%2FP%3E%3CP%3E%E6%A0%B8%E5%BF%83%EF%BC%9AMPEG4PARSER_06.07.04%20%E6%9E%84%E5%BB%BA%E4%BA%8E%202013%20%E5%B9%B4%2012%20%E6%9C%88%205%20%E6%97%A5%2011%3A41%3A38%3C%2FP%3E%3CP%3Emime%EF%BC%9A%E8%A7%86%E9%A2%91%2Fquicktime%EF%BC%9B%E9%9F%B3%E9%A2%91%2Fx-m4a%EF%BC%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2Fx-3gp%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9A%2Fusr%2Flib%2Fimx-mm%2Fparser%2Flib_mp4_parser_arm11_elinux.so.3.2%3C%2FP%3E%3CP%3E%E5%86%85%E5%AE%B9%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20URI%3A%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fr1---sn-8xb5-px8e.googlevideo.com%2Fvideoplayback%3Fip%3D212.90.165.14%26amp%3Brequire%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fr1---sn-8xb5-px8e.googlevideo.com%2Fvideoplayback%3Fip%3D212.90.165.14%26amp%3Brequire%3C%2FA%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ssl%3Dyes%26amp%3Bmws%3Dyes%26amp%3Bsource%3Dyoutube%26amp%3Bupn%3D4-tA0Ie6tDA%26amp%3Bmv%3Dm%26amp%3Bsparams%3Did%2Cip%2Cipbits%2Citag%2Cra%3C%2FP%3E%3CP%3Etebypass%EF%BC%8Crequiressl%EF%BC%8C%E6%BA%90%EF%BC%8Cupn%EF%BC%8C%E8%BF%87%E6%9C%9F%26amp%3Bkey%3Dyt5%26amp%3Bipbits%3D0%26amp%3Bmt%3D1401803916%26amp%3Bid%3Do-ABczKx%3C%2FP%3E%3CP%3EqqFwtM_XhBgSvGnsGqyiHL18Wy6SqK0BZepcFQ%26amp%3B%E7%AD%BE%E5%90%8D%3D121A2CB3142FB772CD72A9F1D872603%3C%2FP%3E%3CP%3EC749A2B74.0370EDFC498A96A43C8F8A98C10184E14158A0D2%26amp%3Bsver%3D3%26amp%3Bratebypass%3Dyes%26amp%3Bexpire%3D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201401827798%26amp%3Bms%3Dau%26amp%3Bfexp%3D908548%2C912321%2C913434%2C916611%2C923341%2C926122%2C930008%26amp%3Bitag%3D18%26amp%3Bc%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pn%3DVgAqvxj2iI2hp45w%26amp%3Bptk%3Dyoutube_none%26amp%3Bpltype%3Dcontentugc%26amp%3Bc%3DWEB%26amp%3Bcver%3Dhtml5%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%90%9C%E7%B4%A2%EF%BC%9A%E6%98%AF%3C%2FP%3E%3CP%3E%E5%A4%A7%E5%B0%8F%EF%BC%88%E5%AD%97%E8%8A%82%EF%BC%89%EF%BC%9A32830110%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%B5%E5%BD%B1%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%8F%AF%E6%90%9C%E7%B4%A2%EF%BC%9A%E6%98%AF%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Live%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A%20No%3C%2FP%3E%3CP%3E%E6%97%B6%E9%95%BF%EF%BC%9A0%3A11%3A52.503360000%3C%2FP%3E%3CP%3E%E8%AF%BB%E5%8F%96%E6%A8%A1%E5%BC%8F%EF%BC%9A%E8%BD%A8%E9%81%93%3C%2FP%3E%3CP%3E%E8%BD%A8%E9%81%93%EF%BC%9A2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9B%B2%E7%9B%AE%2000%20%5Bvideo_000000%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%E6%97%B6%E9%95%BF%EF%BC%9A0%3A11%3A52.503360000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Language%3A%20und%3C%2FP%3E%3CP%3E%E5%93%91%E5%89%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%A7%86%E9%A2%91%2Fx-h264%EF%BC%8C%E8%A7%A3%E6%9E%90%3D%EF%BC%88%E5%B8%83%E5%B0%94%E5%80%BC%EF%BC%89true%EF%BC%8C%E5%AE%BD%E5%BA%A6%3D%EF%BC%88int%EF%BC%89640%EF%BC%8C%E9%AB%98%E5%BA%A6%3D%EF%BC%88int%EF%BC%89360%EF%BC%8C%E5%B8%A7%E9%80%9F%E7%8E%87%3D%EF%BC%88%3C%2FP%3E%3CP%3E%E5%88%86%E6%95%B0)24000%2F1001%3C%2FP%3E%3CP%3E%E6%9B%B2%E7%9B%AE%2001%20%5Baudio_000000%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%E6%97%B6%E9%95%BF%EF%BC%9A0%3A11%3A52.503360000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Language%3A%20und%3C%2FP%3E%3CP%3E%E5%93%91%E5%89%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%9F%B3%E9%A2%91%2Fmpeg%EF%BC%8Cmpegversion%3D(int)4%EF%BC%8C%E9%80%9A%E9%81%93%3D(int)2%EF%BC%8C%E9%80%9F%E7%8E%87%3D(int)44100%EF%BC%8C%E6%AF%94%E7%89%B9%E7%8E%87%3D(int)9%3C%2FP%3E%3CP%3E6000%EF%BC%8Cframed%3D%EF%BC%88%E5%B8%83%E5%B0%94%E5%80%BC%EF%BC%89true%EF%BC%8C%E6%B5%81%E6%A0%BC%E5%BC%8F%3D%EF%BC%88%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%89raw%EF%BC%8Ccodec_data%3D%EF%BC%88%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%89121000%3C%2FP%3E%3CP%3E00000000000000000000000000%3C%2FP%3E%3CP%3E%E5%93%94%E5%A3%B0%EF%BC%9A3.0.11%20%3C%2FP%3E%3CP%3E%E6%A0%B8%E5%BF%83%EF%BC%9AAAC%20%E8%A7%A3%E7%A0%81%E5%99%A8%E5%8C%85%E8%A3%85%E5%99%A8%E6%9E%84%E5%BB%BA%E4%BA%8E%202014%20%E5%B9%B4%201%20%E6%9C%88%2022%20%E6%97%A5%2015%3A42%3A53%3C%2FP%3E%3CP%3Emime%EF%BC%9A%E9%9F%B3%E9%A2%91%2Fmpeg%EF%BC%8Cmpegversion%3D(int)%7B2%2C4%7D%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%EF%BC%9A%2Fusr%2Flib%2Fimx-mm%2Faudio-codec%2Fwrap%2Flib_aacd_wrap_arm12_elinux.so.3%3C%2FP%3E%3CP%3E%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%EF%BC%9ABLN_MAD-MMCODECS_AACD_ARM_03.07.00_CORTEX-A8%EF%BC%8C%E6%9E%84%E5%BB%BA%E4%BA%8E%202013%20%E5%B9%B4%209%20%E6%9C%88%2018%20%E6%97%A5%2010%3A29%3A53%E3%80%82%3C%2FP%3E%3CP%3E%5B---%26gt%3BFINALIZE%20aiurdemux%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQtMultimedia%20%E7%A4%BA%E4%BE%8B%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E5%93%AA%E9%87%8C%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%20opensuse%2013.21%20(64)%20%E4%B8%8A%E4%B8%BA%20RIOT%20(IMX6)%20%E8%AE%BE%E7%BD%AE%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%99%A8%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%83%B3%E5%9C%A8%20Ubuntu%20Image%20%E4%B8%8B%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20qws%20%E7%9A%84%20qt%EF%BC%88%E4%BB%8D%E7%84%B6%E5%BF%85%E9%A1%BB%E5%BC%84%E6%B8%85%E6%A5%9A%E5%A6%82%E4%BD%95%E7%A6%81%E7%94%A8%20GUI%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%B8%8D%E6%98%AF%E2%80%9C%E6%A0%87%E5%87%86%E2%80%9D%E7%9A%84%20Unbuntu%20%E5%90%AF%E5%8A%A8%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A5%E9%AA%A4%206%20%E5%81%87%E8%AE%BE%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%BC%E5%87%BA%E8%B7%AF%E5%BE%84%3D%24PATH%3A%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E5%AE%83%EF%BC%8C%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%E5%AE%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BC%BC%E4%B9%8E%E2%80%9C%E5%8C%85%E5%90%AB%E2%80%9D%E5%9C%A8%E6%9F%90%E4%BA%9B%20BSD%20%E5%8C%85%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%98%BF%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E6%88%90%E5%8A%9F%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%AD%E5%AE%89%E8%A3%85%E4%BA%86%20qt%204.8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E4%B8%8A%E6%9C%89%204.6.0%EF%BC%8C%E5%AE%83%E6%9C%89%E9%9F%B3%E9%A2%91%E6%BC%94%E7%A4%BA%E4%BB%A3%E7%A0%81%E3%80%824.8%20%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%A4%9A%E5%AA%92%E4%BD%93%E6%BC%94%E7%A4%BA%E3%80%82%E7%8E%B0%E6%9C%89%E7%A4%BA%E4%BE%8B%E6%89%A7%E8%A1%8C%E6%AD%A3%E7%A1%AE%E3%80%82%E7%84%B6%E8%80%8C%E6%88%91%E6%9B%BE%E7%BB%8F%E4%BD%BF%E7%94%A8%E8%BF%87%E7%9A%84%E4%BB%BB%E4%BD%95%E4%BE%8B%E5%AD%90%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20qws%20%E5%9C%A8%204.6.0%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E5%9C%A8%204.8%20%E4%B8%8A%E6%89%A7%E8%A1%8C%E3%80%82%E5%AE%83%E5%9B%A0%E2%80%9C%3CSTRONG%3E%E5%88%86%E6%AE%B5%E9%94%99%E8%AF%AF%3C%2FSTRONG%3E%E2%80%9D%E8%80%8C%E5%B4%A9%E6%BA%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%B8%BB%E6%9C%BA%E4%B8%8A%E6%9C%89%20qtCreater%202.7.2%20%E5%92%8C%20Qt%204.8.4%EF%BC%8C%E4%BB%BB%E4%BD%95%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BE%8B%E5%A6%82%E7%B3%BB%E7%BB%9F%E8%B0%83%E7%94%A8%E4%BB%A3%E7%A0%81%E6%88%96%20mmap%20%E8%B0%83%E7%94%A8%EF%BC%89%E4%BC%BC%E4%B9%8E%E9%83%BD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%BD%AC%E5%90%91%204.8%EF%BC%8C%E5%81%87%E8%AE%BE%E5%B9%B6%E6%9C%9F%E6%9C%9B%E6%9C%89%E6%9B%B4%E5%A5%BD%E7%9A%84%E9%9F%B3%E9%A2%91%E5%92%8C%E4%B8%B2%E8%A1%8C%E9%80%9A%E4%BF%A1%E6%94%AF%E6%8C%81%E3%80%82%E4%BD%86%E7%BC%96%E8%AF%91%E7%9A%84%E7%AE%80%E5%8D%95%E4%BB%A3%E7%A0%81%E5%9C%A8%20ltib%20%E4%B8%AD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E8%BF%99%E9%9D%9E%E5%B8%B8%E4%BB%A4%E4%BA%BA%E6%B2%AE%E4%B8%A7%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%B0%BC%E6%B2%99%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E5%BD%93%E4%BD%A0%E6%B2%A1%E6%9C%89%20X11%20%E6%88%96%20wayland%20%E6%97%B6%EF%BC%8Chellogl_es2%20%E7%A4%BA%E4%BE%8B%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E7%AA%97%E5%8F%A3%E7%B3%BB%E7%BB%9F%EF%BC%8C%E5%9B%A0%E4%B8%BA%20hellogl_es2%20%E5%B0%86%20QGLWidget%20%E5%B0%81%E8%A3%85%E5%9C%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%B0%8F%E9%83%A8%E4%BB%B6%E4%B8%AD%E3%80%82%E6%9B%B4%E5%A5%BD%E7%9A%84%E6%98%AF%E4%BD%BF%E7%94%A8%20QT5%20%2B%20QML%E3%80%82%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%E6%82%A8%E7%9A%84%E9%94%99%E8%AF%AF%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%E6%82%A8%E5%BF%85%E9%A1%BB%E7%BC%96%E8%BE%91%E6%96%87%E4%BB%B6%20qtbase%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B%2Fqmake.conf%20%E5%B9%B6%E5%9C%A8%20IMX6_CFLAGS%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%20-mfloat-abi%3Dhard%E3%80%82%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8Cqt-in-use-image%20%E4%BB%85%E4%B8%BA%20Qt%204.8%20%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%20rootfs%20-%20%E4%BD%86%E8%AF%A5%E7%89%88%E6%9C%AC%E4%BB%8D%E7%84%B6%E8%B6%B3%E4%BB%A5%E7%BC%96%E8%AF%91%20hellogl_es2%20%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%88%91%E7%9A%84%20Qt%205.1.1%20%E5%B7%A5%E5%85%B7%E9%93%BE%E7%BC%96%E8%AF%91%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%E6%88%91%E4%B9%8B%E5%89%8D%E8%AF%84%E8%AE%BA%E4%B8%AD%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%89%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%20-%20gnu%2Fstubs-soft.h%E6%B2%92%E6%9C%89%E6%89%BE%E5%88%B0...%E6%88%91%E4%B9%8B%E5%89%8D%E6%B2%A1%E6%9C%89%E6%84%8F%E8%AF%86%E5%88%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C%E4%B9%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%20-%20%E6%89%80%E4%BB%A5%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%B8%AE%E5%8A%A9%E4%BD%A0%EF%BC%9Asmileysad%EF%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%98%BF%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E8%AF%95%E9%AA%8C%20Yocto%20%E5%92%8C%E6%88%91%E7%9A%84%20Mx6%20%E6%9D%BF%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20dora%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20qte-in-use-image%20%E6%9D%A5%E2%80%9C%E7%83%98%E7%84%99%E2%80%9D%E5%9B%BE%E5%83%8F%E3%80%82%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%E6%9D%A5%E8%AF%95%E9%AA%8C%20QT%20%2B%20OpenGL%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%A0%87%E5%BF%97%20DISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%20%E5%9C%A8%E6%88%91%E7%9A%84%20local.conf%20%E4%B8%8A%E7%A6%81%E7%94%A8%E4%BA%86%20X11%20%E5%92%8C%20Wayland%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%20vivante%20vdk%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E4%BB%8E%20OpenGL%20%E8%BF%90%E8%A1%8C%20hellogl_es2%20%E7%A4%BA%E4%BE%8B%E3%80%82%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E6%98%AF%E4%B8%80%E7%89%87%E6%BC%86%E9%BB%91%E7%9A%84%E6%B8%B2%E6%9F%93%E3%80%82%E6%82%A8%E8%83%BD%E4%BB%8E%20QT%20%E8%BF%90%E8%A1%8C%20OpenGL%20%E7%A4%BA%E4%BE%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%B8%83%E6%8B%89%E5%BE%B7%E5%88%A9%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%20IMX6%20%E5%92%8C%20Qt%20%E5%BC%80%E5%A7%8B%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%8E%E6%82%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%AE%89%E8%A3%85%E5%90%8E%EF%BC%8C%E7%9B%AE%E5%BD%95%E7%9B%B8%E5%90%8C%EF%BC%8C%E4%BB%85%E6%AD%A4%E8%80%8C%E5%B7%B2%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%9C%A8%E2%80%9Cmake%E2%80%9D%E5%92%8C%E2%80%9Cmake%20install%E2%80%9D%E6%9C%9F%E9%97%B4%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%BA%20IMX6%20%E6%9E%84%E5%BB%BA%20Qt4.8%20%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENicolas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%E9%82%A3%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A5%BD%E5%B0%86%E9%82%A3%E4%BA%9B%E6%8A%A5%E5%91%8A%E2%80%9CEGLFS%3A%20OpenGL%20%E7%AA%97%E5%8F%A3%E4%B8%8D%E8%83%BD%E4%B8%8E%E5%85%B6%E4%BB%96%E7%AA%97%E5%8F%A3%E6%B7%B7%E5%90%88%E2%80%9D%E7%9A%84%E4%BB%A3%E7%A0%81%E6%B3%A8%E9%87%8A%E6%8E%89%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%3C%2FP%3E%3CP%3E%E9%99%88%E7%90%86%E6%9F%A5%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111373%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%89%80%E6%9C%89%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20YOCTO%20%E5%88%B6%E4%BD%9C%E5%9B%BE%E5%83%8F%E7%9A%84%E4%BA%BA%E4%B9%9F%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E7%BC%96%E8%AF%91%20Qt%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%AD%A4%E5%A4%84%E7%9A%84%20Qt5%20%E5%AE%9E%E7%94%A8%E6%95%99%E7%A8%8B%EF%BC%9A%3CA%20__default_attr%3D%2299366%22%20__jive_macro_name%3D%22document%22%20class%3D%22jive_macro_document%20jive_macro%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E4%BA%9B%E8%BF%98%E6%B2%A1%E7%94%A8%E8%BF%87%20YOCTO%20%E7%9A%84%E4%BA%BA%EF%BC%9A%E8%B5%B6%E5%BF%AB%E8%A1%8C%E5%8A%A8%E8%B5%B7%E6%9D%A5%E5%90%A7%EF%BC%9Asmileygrin%EF%BC%9A%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20Training%20-%20HOME%3C%2FA%3E%E4%B8%8A%E9%98%85%E8%AF%BB%E6%9B%B4%E5%A4%9A%E5%86%85%E5%AE%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E4%BD%BF%E7%94%A8%20Qt4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9B%B4%E8%BD%BB%E6%9D%BE%E5%9C%B0%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E5%9B%A0%E4%B8%BA%20YOCTO%20%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%8D%E5%90%8C%E7%9A%84%E5%B1%82%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E4%B8%BB%E6%9D%BF%EF%BC%9Aqt-in-use-image%20%E6%88%96%20qte-in-use-image%3C%2FP%3E%3CP%3E%E4%BD%9C%E4%B8%BA%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%9Ameta-toolchain-qt%20%E6%88%96%20meta-toolchain-qte%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%A9%E5%BE%97%E5%BC%80%E5%BF%83%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20xicai%20chen.%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20Qt%205%20%E4%B8%AD%E7%9A%84%20hellowindow%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%8A%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%88%20%3CSTRONG%3EEGLFS%3A%20OpenGL%20%E7%AA%97%E5%8F%A3%E4%B8%8D%E8%83%BD%E4%B8%8E%E5%85%B6%E4%BB%96%E7%AA%97%E5%8F%A3%E6%B7%B7%E5%90%88%3C%2FSTRONG%3E%EF%BC%89%3CBR%20%2F%3E%E4%BD%A0%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%20Qt%204.8%20%E6%9C%89%E4%B8%80%E4%B8%AA%E8%A1%A5%E4%B8%81%E6%96%87%E4%BB%B6%200001-add-i.MX6-EGL-support.patch%EF%BC%8C%E4%BD%86%E6%98%AF%20QT5%20%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E4%BD%A0%E9%94%99%E8%BF%87%E4%BA%86%E5%90%97%EF%BC%9F%E5%8F%AF%E8%83%BD%E6%9C%89%E4%B8%8E%20Qt5%20%E7%B1%BB%E4%BC%BC%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%BD%93%E6%88%91%E5%9C%A8%20Qt%205.1%20%E4%B8%AD%E5%B0%9D%E8%AF%95%20hellowindow%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E5%A6%82%E4%B8%8B%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%E3%80%82%E4%BD%A0%E6%9C%89%E4%BB%80%E4%B9%88%E6%8F%90%E7%A4%BA%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3EQIconvCodec%3A%3AconvertFromUnicode%EF%BC%9A%E4%BD%BF%E7%94%A8%20Latin-1%20%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%EF%BC%8Ciconv_open%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3EQIconvCodec%3A%3AconvertToUnicode%EF%BC%9A%E4%BD%BF%E7%94%A8%20Latin-1%20%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%EF%BC%8Ciconv_open%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3EQEglFSImx6Hooks%20%E5%B0%86%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%20FB_MULTI_BUFFER%3D2%20%E4%BB%A5%E5%90%AF%E7%94%A8%E5%8F%8C%E7%BC%93%E5%86%B2%E5%92%8C%E5%9E%82%E7%9B%B4%E5%90%8C%E6%AD%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E9%9C%80%E8%A6%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E8%A6%86%E7%9B%96%EF%BC%9Aexport%20QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER%3D1%3C%2FP%3E%3CP%3EEGLFS%EF%BC%9A%E6%97%A0%E6%B3%95%E6%9F%A5%E8%AF%A2%E7%89%A9%E7%90%86%E5%B1%8F%E5%B9%95%E5%B0%BA%E5%AF%B8%EF%BC%8C%E9%BB%98%E8%AE%A4%E4%B8%BA%20100%20dpi%E3%80%82%3C%2FP%3E%3CP%3EEGLFS%EF%BC%9A%E8%A6%81%E8%A6%86%E7%9B%96%EF%BC%8C%E8%AF%B7%E8%AE%BE%E7%BD%AE%20QT_QPA_EGLFS_PHYSICAL_WIDTH%20%E5%92%8C%20QT_QPA_EGLFS_PHYSICAL_HEIGHT%EF%BC%88%E4%BB%A5%E6%AF%AB%E7%B1%B3%E4%B8%BA%E5%8D%95%E4%BD%8D%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3EEGLFS%EF%BC%9AOpenGL%20%E7%AA%97%E5%8F%A3%E4%B8%8D%E8%83%BD%E4%B8%8E%E5%85%B6%E4%BB%96%E7%AA%97%E5%8F%A3%E6%B7%B7%E5%90%88%E3%80%82%3C%2FP%3E%3CP%3E%E5%B7%B2%E4%B8%AD%E6%AD%A2%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%9A%E6%88%91%E6%98%AF%20Linux%20Embedded%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E7%9A%84%E5%88%9D%E5%AD%A6%E8%80%85%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E6%98%AF%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E5%9F%BA%E7%A1%80%E3%80%82%E6%88%91%E5%BE%88%E6%8A%B1%E6%AD%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%20QT%205%20%E7%A8%8B%E5%BA%8F%E4%BB%8E%E5%9F%BA%E4%BA%8E%20PC%20%E7%9A%84%20Ubuntu%20%E7%B3%BB%E7%BB%9F%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%88%B0%20i.MX6%20%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8C%89%E7%85%A7%E9%A1%B5%E9%9D%A2%E7%9A%84%E8%AF%B4%E6%98%8E%E4%B8%BA%E4%B8%BB%E6%9D%BF%E6%9E%84%E5%BB%BA%E4%BA%86%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E2%80%9C%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20%3CSPAN%3E%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E8%AE%BE%E7%BD%AE%20QT%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%2294066%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94066%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94066%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%96%87%E6%A1%A3%EF%BC%8C%E5%8D%B3%E6%AD%A4%E9%A1%B5%E9%9D%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AE%8C%E6%88%90%E4%BA%86%E6%AD%A5%E9%AA%A4%201%E3%80%812%E3%80%813%20%E5%92%8C%204%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%AD%A5%E9%AA%A4%205%20%E4%B8%AD%E5%BC%95%E7%94%A8%E4%BA%86%20gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20h%20%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.linaro.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ettp%3A%2F%2Fwww.linaro.org%2F%3C%2FA%3E%E4%B8%8A%E6%89%BE%E5%88%B0%E4%BA%86%E5%AE%83%E7%BD%91%E7%AB%99%E4%BD%86%E6%88%91%E6%B2%A1%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%E5%9F%BA%E4%BA%8E%20ltib%20%E7%9A%84%E9%A2%84%E6%9E%84%E5%BB%BA%20rootfs%20%E6%9D%A5%E4%B8%BA%20IMX6%20Sabre%20AI%20%E6%9D%BF%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%20Qt5.x%E3%80%82%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%E7%9B%B8%E5%90%8C%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%AD%A4%E7%BA%BF%E7%A8%8B%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E7%9B%B8%E5%90%8C%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E5%99%A8%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%20rootfs%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%8B%89%E7%8E%9B%E5%9D%8E%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2Juha%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%9C%8B%E6%9D%A5%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%2C%20FreeSans%2C%20Helvetica%2C%20sans-serif%3B%22%3Eqtdeclarative%3C%2FSPAN%3E%E5%B7%B2%E7%BB%8F%E4%BF%AE%E5%A4%8D%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9Asmileyhappy%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E6%98%AF%20Qt%20%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E7%9C%9F%E6%AD%A3%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fbugreports.qt-project.org%2Fbrowse%2FQTBUG-34065%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fbugreports.qt-project.org%2Fbrowse%2FQTBUG-34065%3C%2FA%3E%3C%2FP%3E%3CP%3E%EF%BC%88%E6%88%91%E7%8C%9C%E4%BD%A0%E5%AE%9E%E9%99%85%E4%B8%8A%E6%98%AF%E5%9C%A8%E7%BC%96%E8%AF%91%205.1%20%E4%B9%8B%E5%90%8E%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C5.1.1%20%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E7%BC%96%E8%AF%91%E5%BE%97%E5%BE%88%E5%A5%BD%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%85%8B%E9%9A%86%E4%BA%86%20qt5%20%E6%BA%90%EF%BC%8C%E8%AF%B7%E8%AE%B0%E4%BD%8F%E6%A3%80%E5%87%BA%E7%9B%B8%E5%BA%94%E7%9A%84%20git%20%E6%A0%87%E7%AD%BE%E4%BB%A5%E8%8E%B7%E5%8F%96%205.1.1)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%9E%84%E5%BB%BA%E6%9C%80%E6%96%B0%E7%9A%84%20Qt5.1%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecompiler%2Fqv4isel_masm_p.h%3A%20%E5%9C%A8%E6%88%90%E5%91%98%E5%87%BD%E6%95%B0%20'void%20QQmlJS%3A%3AMASM%3A%3AAssembler%3A%3AstoreUInt32(JSC%3A%3AAbstractMacroAssembler%26lt%3B%3Aarmassembler%26gt%3B%3A%3ARegisterID%2C%20QQmlJS%3A%3AMASM%3A%3AAssembler%3A%3APointer)'%20%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%BC%96%E8%AF%91%E5%99%A8%2Fqv4isel_masm_p.h%3A1212%3A63%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A'convertUInt32ToDouble'%E6%9C%AA%E5%9C%A8%E6%AD%A4%E8%8C%83%E5%9B%B4%E5%86%85%E5%A3%B0%E6%98%8E%3C%2FP%3E%3CP%3Ecompiler%2Fqv4isel_masm_p.h%3A%20%E5%9C%A8%E6%88%90%E5%91%98%E5%87%BD%E6%95%B0%20'void%20QQmlJS%3A%3AMASM%3A%3AInstructionSelection%3A%3AconvertUIntToDouble(QQmlJS%3A%3AV4IR%3A%3ATemp*%2C%20QQmlJS%3A%3AV4IR%3A%3ATemp*)'%20%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3Ecompiler%2Fqv4isel_masm_p.h%3A1491%3A18%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A'class%20QQmlJS%3A%3AMASM%3A%3AAssembler'%20%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20'convertUInt32ToDouble'%20%E7%9A%84%E6%88%90%E5%91%98%3C%2FP%3E%3CP%3Ecompiler%2Fqv4isel_masm_p.h%3A1493%3A18%3A%20%E9%94%99%E8%AF%AF%3A%20'class%20QQmlJS%3A%3AMASM%3A%3AAssembler'%20%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20'convertUInt32ToDouble'%20%E7%9A%84%E6%88%90%E5%91%98%3C%2FP%3E%3CP%3E%E7%BC%96%E8%AF%91%E5%99%A8%2Fqv4isel_masm.cpp%EF%BC%9A%E5%9C%A8%E6%88%90%E5%91%98%E5%87%BD%E6%95%B0%E2%80%9Cvirtual%20void%20QQmlJS%3A%3AMASM%3A%3AInstructionSelection%3A%3AvisitRet(QQmlJS%3A%3AV4IR%3A%3ARet*)%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3Ecompiler%2Fqv4isel_masm.cpp%3A1978%3A22%3A%20%E9%94%99%E8%AF%AF%3A%20'class%20QQmlJS%3A%3AMASM%3A%3AAssembler'%20%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20'convertUInt32ToDouble'%20%E7%9A%84%E6%88%90%E5%91%98%3C%2FP%3E%3CP%3E%E7%BC%96%E8%AF%91%E5%99%A8%2Fqv4isel_masm.cpp%EF%BC%9A%E5%9C%A8%E6%88%90%E5%91%98%E5%87%BD%E6%95%B0%E2%80%9CJSC%3A%3AAbstractMacroAssembler%26lt%3B%3Aarmassembler%26gt%3B%3A%3AJump%20QQmlJS%3A%3AMASM%3A%3AInstructionSelection%3A%3AgenTryDoubleConversion(QQmlJS%3A%3AV4IR%3A%3AExpr*%2C%20JSC%3A%3AMacroAssemblerARM%3A%3AFPRegisterID)%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3Ecompiler%2Fqv4isel_masm.cpp%3A2172%3A14%3A%20%E9%94%99%E8%AF%AF%3A%20'class%20QQmlJS%3A%3AMASM%3A%3AAssembler'%20%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20'convertUInt32ToDouble'%20%E7%9A%84%E6%88%90%E5%91%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EQt5%20git%20version%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E4%BA%A4%20cb2d850b479fed9fed3c4a9fea698f924be942ef%3C%2FP%3E%3CP%3E%3CSPAN%3EAuthor%3A%20Qt%20Submodule%20Update%20Bot%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aqt_submodule_update_bot%40ovi.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eqt_submodule_update_bot%40ovi.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%97%A5%E6%9C%9F%EF%BC%9A2013%E5%B9%B410%E6%9C%8815%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C22%3A00%3A06%20%2B0300%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%95%BF%E6%9C%9F%E6%8A%95%E8%B5%84%E5%B1%80%204%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%B8%8E%E9%97%AE%E5%80%99%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84QT4.8%E5%B7%B2%E7%BB%8F%E7%BC%96%E8%AF%91%E6%88%90%E5%8A%9F%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%9C%A8%E7%9B%AE%E6%A0%87%E6%9D%BF%E4%B8%8A%E6%B5%8B%E8%AF%95%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3Eroot%40freescale%2Fopt%2Fqt4.8-arm-elink%2Fexamples%2Fopengl%2Fhellogl_es2%24.%2Fhellogl_es2-%E5%B9%B3%E5%8F%B0%20eglfs%3C%2FP%3E%3CP%3E.%2Fhellogl_es2%EF%BC%9A%E5%8A%A0%E8%BD%BD%E5%85%B1%E4%BA%AB%E5%BA%93%E6%97%B6%E5%87%BA%E9%94%99%EF%BC%9AlibQtOpenGL.so.4%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E6%89%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%9E%84%E5%BB%BA%E4%BC%BC%E4%B9%8E%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40freescale%2Fopt%2Fqt5%2Fexamples%2Fopengl%2Fhellowindow%24.%2Fhellowindow-%E5%B9%B3%E5%8F%B0%20eglfs%3C%2FP%3E%3CP%3EQIconvCodec%3A%3AconvertFromUnicode%EF%BC%9A%E4%BD%BF%E7%94%A8%20Latin-1%20%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%EF%BC%8Ciconv_open%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3EQIconvCodec%3A%3AconvertToUnicode%EF%BC%9A%E4%BD%BF%E7%94%A8%20Latin-1%20%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%EF%BC%8Ciconv_open%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3Eidr_remove%20%E8%B0%83%E7%94%A8%E4%BA%86%E6%9C%AA%E5%88%86%E9%85%8D%E7%9A%84%20id%3D2126092104%E3%80%82%3C%2FP%3E%3CP%3E%5B%26lt%3B8004f72c%26gt%3B%5D%20(unwind_backtrace%2B0x0%2F0x138)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8024d930%26gt%3B%5D%20(idr_remove%2B0x1f8%2F0x208)%3C%2FP%3E%3CP%3E%5B%26lt%3B8024d930%26gt%3B%5D%20(idr_remove%2B0x1f8%2F0x208)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B802bb51c%26gt%3B%5D%20(drm_ctxbitmap_free%2B0x24%2F0x30)%3C%2FP%3E%3CP%3E%5B%26lt%3B802bb51c%26gt%3B%5D%20(drm_ctxbitmap_free%2B0x24%2F0x30)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B802bba28%26gt%3B%5D%20(drm_rmctx%2B0x5c%2F0x10c)%3C%2FP%3E%3CP%3E%5B%26lt%3B802bba28%26gt%3B%5D%20(drm_rmctx%2B0x5c%2F0x10c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B802bc064%26gt%3B%5D%20(drm_ioctl%2B0x2d0%2F0x3b4)%3C%2FP%3E%3CP%3E%5B%26lt%3B802bc064%26gt%3B%5D%20(drm_ioctl%2B0x2d0%2F0x3b4)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8010b344%26gt%3B%5D%20(do_vfs_ioctl%2B0x80%2F0x558)%3C%2FP%3E%3CP%3E%5B%26lt%3B8010b344%26gt%3B%5D%20(do_vfs_ioctl%2B0x80%2F0x558)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B8010b854%26gt%3B%5D%20(sys_ioctl%2B0x38%2F0x5c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8010b854%26gt%3B%5D%20(sys_ioctl%2B0x38%2F0x5c)%20%E6%9D%A5%E8%87%AA%20%5B%26lt%3B80048600%26gt%3B%5D%20(ret_fast_syscall%2B0x0%2F0x30)%3C%2FP%3E%3CP%3E%E5%88%86%E6%AE%B5%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3Eroot%40freescale%2Fopt%2Fqt5%2Fexamples%2Fopengl%2Fhellowindow%24%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E7%BA%BF%E7%B4%A2%E5%8F%AF%E4%BB%A5%E8%A7%A3%E9%87%8A%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%9C%A8%E7%9B%AE%E6%A0%87%E6%9D%BF%E4%B8%8A%E6%B5%8B%E8%AF%95%20qt5%20%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C(.%2Fhellogl_es2)%E6%88%91%E6%9C%89%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%9C%E6%AD%A4%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E6%89%BE%E4%B8%8D%E5%88%B0%E6%88%96%E5%8A%A0%E8%BD%BD%20Qt%20%E5%B9%B3%E5%8F%B0%E6%8F%92%E4%BB%B6%E2%80%9Ceglfs%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E6%9C%89%E5%85%B3%E6%AD%A4%20eglfs%20%E9%94%99%E8%AF%AF%E7%9A%84%E4%BB%BB%E4%BD%95%E6%8F%90%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3Ejessie.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Michael%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%20X%20%E4%B8%8B%E8%BF%90%E8%A1%8C%EF%BC%8C%E6%82%A8%E7%9C%9F%E6%AD%A3%E5%B8%8C%E6%9C%9B%E7%9A%84%E6%98%AF%E5%8A%A0%E9%80%9F%20X%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20Qt%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%82%A8%E5%8F%AF%E8%83%BD%E5%BA%94%E8%AF%A5%E5%8F%AA%E4%BD%BF%E7%94%A8%3CTT%3Eapt-get%3C%2FTT%3E%E6%9D%A5%E5%AE%89%E8%A3%85%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Michael%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eeglvivante.h%20%E5%8C%85%E5%90%AB%E5%9C%A8%20eglplatform.h%20%E4%B8%AD%EF%BC%8C%E5%8C%85%E5%90%AB%E5%9C%A8%20egl.h%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E9%85%8D%E7%BD%AE%E8%A1%A5%E4%B8%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-arm%2Fcommit%2Fedcd4a6659c281458423ed39586607d69b4bed2a%22%20title%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Fmeta-fsl-arm%2Fcommit%2Fedcd4a6659c281458423ed39586607d69b4bed2a%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eqt4%3A%20%E4%B8%BA%20i.MX6%20%E5%90%AF%E7%94%A8%20OpenGL%20ES2%20%E6%94%AF%E6%8C%81%20%C2%B7%20edcd4a6%20%C2%B7%20Freescale%2Fmeta-fsl-arm%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EEric%EF%BC%8C%E8%BF%98%E6%9C%89%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%9D%97%20SABRElite%20%E6%9D%BF%EF%BC%8C%E5%AE%83%E8%BF%90%E8%A1%8C%E5%B8%A6%E6%9C%89%20X-window%20%E6%A1%8C%E9%9D%A2%E7%9A%84%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20Ubuntu%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%83%B3%E5%9C%A8%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20X-window%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%B8%80%E4%B8%AA%20QT%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%89%8B%E5%86%8C%EF%BC%88Building%20QT%20for%20i.MX6%EF%BC%89%E9%80%82%E5%90%88%E6%88%91%E7%9A%84%E4%BB%BB%E5%8A%A1%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%E8%BF%88%E5%85%8B%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eric!%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%9C%A8%20EGL%2Feglvivante.h%20%E4%B8%AD%E6%9C%89%E8%BF%99%E4%BA%9B%E5%A3%B0%E6%98%8E%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%88%91%E7%9A%84%20qt-4.8.4%2Fsrc%2Fplugins%2Fplatforms%2Feglfs%2Fqeglfsscreen.cpp%EF%BC%88EGL%20%E6%94%AF%E6%8C%81%E8%A1%A5%E4%B8%81%E4%B9%8B%E5%90%8E%EF%BC%89%E4%B8%AD%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%8C%87%E5%90%91%20EGL%2Feglvivante.h%20%E7%9A%84%E9%93%BE%E6%8E%A5%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%20qeglfsscreen.cpp%20%E5%92%8C%20qeglfsscreen.h%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E5%AF%B9%20EGL%2Feglvivante.h%20%E7%9A%84%E5%BC%95%E7%94%A8%E6%88%96%E8%80%85%E5%9C%A8%20eglfs.pro%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E5%88%B0%E5%A4%84%E9%83%BD%E6%B7%BB%E5%8A%A0%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%AF%E6%B2%A1%E6%9C%89%E6%95%88%E6%9E%9C%EF%BC%8C%E5%87%BA%E7%8E%B0%E7%9B%B8%E5%90%8C%E7%9A%84%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26gt%3B%26gt%3B%20%E6%82%A8%E7%9A%84%20LTIB%20%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%98%AF%E5%90%A6%E5%8C%85%E5%90%AB%E4%BA%86%20gpu-viv-bin-mx6q%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8%20LTIB%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%8E%B0%E6%88%90%E7%9A%84%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20Ubuntu%20rootfs%20%E6%98%A0%E5%83%8F%3CEM%3EL3.0.35_4.0.0_UBUNTU_RFS%EF%BC%8C%3C%2FEM%3E%3CSPAN%3E%E6%9D%A5%E8%87%AA%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-wiki-small%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%2294809%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94809%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-94809%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%E8%BF%88%E5%85%8B%E5%B0%94%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Michael%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E5%A3%B0%E6%98%8E%E5%BA%94%E8%AF%A5%E5%9C%A8%3CTT%3EEGL%2Feglvivante.h%3C%2FTT%3E%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E~%2Fltib4-nox%2Frootfs%2Fusr%2Finclude%24%20grep%20-r%20fbGetDisplayByIndex%20*%0AEGL%2Feglvivante.h%3AfbGetDisplayByIndex(%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9A%84%20LTIB%20%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%98%AF%E5%90%A6%E5%8C%85%E5%90%AB%E4%BA%86%3CTT%3Egpu-viv-bin-mx6q%3C%2FTT%3E%20%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E4%B8%BA%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%20Boundary%20%E7%9A%84%20SABRElite%20%E6%9D%BF%E6%9E%84%E5%BB%BA%20QT4.8%E3%80%82%E6%B2%A1%E6%83%B3%E5%88%B0%EF%BC%8C%E5%9C%A8%3CSTRONG%3E%E7%AC%AC9%E6%AD%A5%EF%BC%88%E7%8E%B0%E5%9C%A8%E9%9C%80%E8%A6%81%E6%9E%84%E5%BB%BA%3CEM%3Eeglfs%3C%2FEM%3E%E6%8F%92%E4%BB%B6%EF%BC%89%3C%2FSTRONG%3E%E6%97%B6%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%3Eqeglfsscreen.cpp%EF%BC%9A%E5%9C%A8%E6%9E%84%E9%80%A0%E5%87%BD%E6%95%B0%E2%80%9CQEglFSScreen%3A%3AQEglFSScreen(EGLNativeDisplayType)%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eqeglfsscreen.cpp%3A109%3A43%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98fbGetDisplayByIndex%E2%80%99%E6%9C%AA%E5%9C%A8%E6%AD%A4%E8%8C%83%E5%9B%B4%E5%86%85%E5%A3%B0%E6%98%8E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eqeglfsscreen.cpp%3A110%3A57%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98fbGetDisplayGeometry%E2%80%99%E6%9C%AA%E5%9C%A8%E6%AD%A4%E8%8C%83%E5%9B%B4%E5%86%85%E5%A3%B0%E6%98%8E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eqeglfsscreen.cpp%EF%BC%9A%E5%9C%A8%E6%88%90%E5%91%98%E5%87%BD%E6%95%B0%E2%80%9Cvoid%20QEglFSScreen%3A%3AcreateAndSetPlatformContext()%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eqeglfsscreen.cpp%3A181%3A95%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98fbCreateWindow%E2%80%99%E6%9C%AA%E5%9C%A8%E6%AD%A4%E8%8C%83%E5%9B%B4%E5%86%85%E5%A3%B0%E6%98%8E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Emake%3A%20***%20%5B.obj%2Frelease-shared%2Fqeglfsscreen.o%5D%20%E9%94%99%E8%AF%AF%201%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%20%E6%9C%89%E4%BB%80%E4%B9%88%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%E8%BF%88%E5%85%8B%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E4%B9%9F%E5%9C%A8%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%20QT5%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E5%AE%83%EF%BC%8C%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%9Asmileyhappy%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%B9%B2%E6%9D%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ESarjoon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%B2%A1%E6%9C%89%EF%BC%8C%E5%B8%8C%E6%9C%9B%E4%BC%9A%E6%9C%89%E5%86%85%E7%BD%AE%20QT5%20%E6%94%AF%E6%8C%81%E7%9A%84%E6%9B%B4%E6%96%B0...%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E7%94%A8%20Qt4%20%E6%9D%A5%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E5%8F%96%E5%BE%97%E5%A4%AA%E5%A4%A7%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%E8%A6%81%E4%B9%88...%20%3D%20(%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%90%E5%B0%94%E5%9D%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frossdehmoobed%22%20target%3D%22_blank%22%3E%E7%BD%97%E6%96%AF%E5%BE%B7%E7%A9%86%E8%B4%9D%E5%BE%B7%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%93%A6..%E4%BD%A0%E5%AF%B9%E6%AD%A4%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%3C%2FP%3E%3CP%3ESarjoon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%84%9F%E8%B0%A2%20Zoltan%20%E7%9A%84%E5%9B%9E%E5%A4%8D%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98......%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%90%E5%B0%94%E5%9D%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E4%BD%A0%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E9%82%A3%E4%B8%AA%E8%BE%93%E5%85%A5%E9%97%AE%E9%A2%98......%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E8%BF%90%E8%A1%8C%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%8E%EF%BC%8C%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%2Fhellowindow%20-platform%20eglfs..%20%E6%88%91%E6%97%A0%E6%B3%95%E8%BE%93%E5%85%A5%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%EF%BC%88%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E8%A7%A6%E6%91%B8%EF%BC%89%E3%80%82%E8%A7%A6%E6%91%B8%E5%8A%9F%E8%83%BD%E5%AE%8C%E5%85%A8%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E5%AF%BC%E5%87%BA%E4%BA%86%E6%89%80%E6%9C%89%E5%BF%85%E8%A6%81%E7%9A%84%20Tslib%20%E5%8F%98%E9%87%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E6%82%A8%E6%89%BE%E5%88%B0%E7%9A%84%E5%BA%93%E6%96%87%E4%BB%B6%E4%B8%8E%E8%A7%A6%E6%91%B8%E9%97%AE%E9%A2%98%E6%9C%89%E5%85%B3%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E6%82%A8%E8%BF%98%E6%8F%90%E5%88%B0%E2%80%9C%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E4%BB%96%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E6%89%80%E6%9C%89%E9%97%AE%E9%A2%98%3C%2FSPAN%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E5%BA%93%EF%BC%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FzOrg1331%2Ffsl-gpu-viv-mx6q%2Ftree%2Fmaster%2Fusr%2Flib%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FzOrg1331%2Ffsl-gpu-viv-mx6q%2Ftree%2Fmaster%2Fusr%2Flib%3C%2FA%3E%20%EF%BC%8C%E4%BD%86%3C%2FP%3E%3CP%3E%E9%82%A3%E4%BA%9B%E5%B7%B2%E7%BB%8F%E5%BE%88%E6%97%A7%E4%BA%86%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E4%BB%96%E4%BB%AC%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E6%89%80%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E4%B8%8D%E5%85%BC%E5%AE%B9%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%90%E5%B0%94%E5%9D%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%A0%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E4%BA%86%E5%90%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%BC%96%E8%BE%91%20build%2Fconf%2Flocal.conf%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%20Ubuntu%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%E2%80%9CYocto%20%E4%B8%8E%E8%BE%B9%E7%95%8C%E8%AE%BE%E5%A4%87%E7%9A%84%20Nitrogen6x%EF%BC%9A%E4%BB%85%E9%9C%80%205%20%E4%B8%AA%E6%AD%A5%E9%AA%A4%EF%BC%81%E2%80%9D%E4%B8%AD%E7%9A%84%E6%96%87%E7%AB%A0%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%AE%89%E8%A3%85%E6%89%80%E6%9C%89%E5%BF%85%E8%A6%81%E7%9A%84%E8%BD%AF%E4%BB%B6%E3%80%82%E6%88%91%E5%B0%86%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E6%8C%87%E7%A4%BA%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%E3%80%82%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8Csquirem%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%90%E8%A1%8C%E4%BA%86%20bitbake%20fsl-image-gui%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%91%E7%8E%B0%20MACHINE%3Dimx6qsabresd%20%E4%B8%8D%E6%98%AF%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%E3%80%82%E6%88%91%E7%9A%84%E6%9D%BF%E6%98%AF%20Boundary%20%E7%9A%84%20Nitrogen6x%20%E6%9D%BF%E3%80%82%E5%A6%82%E4%BD%95%E5%B0%86%E5%85%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%20MACHINE%3Dnitrogen6x%EF%BC%9F%E4%BD%A0%E8%83%BD%E5%B8%AE%E5%BF%99%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%9B%BE%E5%83%8F%E4%B8%8A%E7%9A%84%20Qt4.8.4%20%E5%BA%93%E3%80%82%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%E6%98%AF%E5%90%A6%E5%B7%B2%E6%B7%BB%E5%8A%A0Qt4.8.4%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E7%A1%AE%E5%AE%9A%E9%81%B5%E5%BE%AA%E4%BA%86%E6%AD%A4%E5%A4%84%E6%A6%82%E8%BF%B0%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%90%97%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E7%A1%AE%E5%AE%9A%E6%82%A8%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%AE%89%E8%A3%85%E4%BA%86%E6%89%80%E6%9C%89%E5%BF%85%E8%A6%81%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%90%97%EF%BC%9F%E8%AF%B7%E5%8F%82%E9%98%85%20Yocto%20%E9%A1%B9%E7%9B%AE%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%E5%B9%B6%E6%9F%A5%E7%9C%8B%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fyocto-project-qs%2Fyocto-project-qs.html%22%20title%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fyocto-project-qs%2Fyocto-project-qs.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fdocs%2Fcurrent%2Fyocto-project-qs%2Fyocto-project-qs.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8C%9C%E4%BD%A0%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%20Ubuntu%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E8%BF%99%E4%B8%AA%E5%91%BD%E4%BB%A4%E5%B0%86%E5%AE%89%E8%A3%85%E4%BD%A0%E9%9C%80%E8%A6%81%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%9A%20%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3Esudo%20apt-get%20install%20gawk%20wget%20git-core%20diffstat%20%E8%A7%A3%E5%8E%8B%E7%BC%A9%20texinfo%20%5C%3C%2FP%3E%0A%3CP%3E%E6%9E%84%E5%BB%BA%E5%BF%85%E9%9C%80%E7%9A%84%20chrpath%20libsdl1.2-devxterm%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E8%BF%90%E8%A1%8C%E2%80%9Cbitbake%20core-image-minimal%E2%80%9D%E3%80%82%E5%AE%83%E4%BC%9A%E5%BC%B9%E5%87%BA%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%E4%BC%AA%E4%B8%8D%E5%AD%98%E5%9C%A8%E4%BD%86%E9%9C%80%E8%A6%81%EF%BC%8C%E5%9C%A8%E4%B8%BB%E6%9E%84%E5%BB%BA%E4%B9%8B%E5%89%8D%E5%85%88%E6%9E%84%E5%BB%BA%E5%AE%83%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%EF%BC%9AOE-core%20%E7%9A%84%E9%85%8D%E7%BD%AE%E5%81%A5%E5%85%A8%E6%80%A7%E6%A3%80%E6%9F%A5%E5%99%A8%E6%A3%80%E6%B5%8B%E5%88%B0%E6%BD%9C%E5%9C%A8%E7%9A%84%E9%94%99%E8%AF%AF%E9%85%8D%E7%BD%AE%E3%80%82%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20%E8%A6%81%E4%B9%88%E4%BF%AE%E5%A4%8D%E6%AD%A4%E9%94%99%E8%AF%AF%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8C%E8%A6%81%E4%B9%88%E8%87%AA%E8%A1%8C%E6%89%BF%E6%8B%85%E9%A3%8E%E9%99%A9%E7%A6%81%E7%94%A8%E6%A3%80%E6%9F%A5%E5%99%A8%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%20sanity.conf%EF%BC%89%E3%80%82%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%BD%9C%E5%9C%A8%E9%97%AE%E9%A2%98%2F%E5%BB%BA%E8%AE%AE%E7%9A%84%E5%88%97%E8%A1%A8%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20%E8%AF%B7%E5%AE%89%E8%A3%85%E4%BB%A5%E4%B8%8B%E7%BC%BA%E5%B0%91%E7%9A%84%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9Agawk%E3%80%81chrpath%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E8%BF%90%E8%A1%8C%E2%80%9Capt-get%20install%20gawk%20chrpath%E2%80%9D%E3%80%82%E5%AE%83%E4%BC%9A%E5%BC%B9%E5%87%BA%E5%A6%82%E4%B8%8B%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%E4%BB%A5%E4%B8%8B%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%B7%B2%E8%87%AA%E5%8A%A8%E5%AE%89%E8%A3%85%EF%BC%8C%E4%B8%8D%E5%86%8D%E9%9C%80%E8%A6%81%EF%BC%9A%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20libp11-kit-dev%20libgpg-error-dev%20comerr-dev%20libqt3-headers%20libgnutls-openssl27%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20libkrb5-dev%20liblcms1-dev%20libgnutlsxx27%20libgssrpc4%20libxt-dev%20libxmu-dev%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20libtasn1-3-dev%20libcups2-dev%20libqt3-compat-headers%20qt3-dev-tools%20libgcrypt11-dev%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20libkadm5clnt-mit8%20libaudio-dev%20libkadm5srv-mit8%20libxmu-headers%20libkdb5-6%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200in%3B%22%3E%3CSTRONG%3E%20libgnutls-dev%20krb5-multidev%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E2%80%9Capt-get%20autoremove%20.......%E2%80%9D%E6%9D%A5%E5%88%A0%E9%99%A4%E5%AE%83%E4%BB%AC%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CZoltan%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%9D%A5%E8%87%AA%E5%85%B6%E4%BB%96%E5%87%A0%E5%AE%B6%E4%BE%9B%E5%BA%94%E5%95%86%E7%9A%84%20MPU%20%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E5%AE%83%EF%BC%8C%E4%BD%86%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%98%AF%E4%B8%80%E4%B8%AA%E4%B8%8E%20rootfs%20%E7%9B%B8%E5%85%B3%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%E4%B8%8E%20simlinks%20%E5%92%8C%20lib%20%E8%B7%AF%E5%BE%84%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%20raspberry-pi%20%E8%AE%BE%E5%A4%87%E6%8C%87%E5%8D%97%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%EF%BC%8C%E4%BD%86%E5%8F%AA%E9%80%82%E7%94%A8%E4%BA%8E%E4%BB%96%E4%BB%AC%E6%8C%87%E5%AE%9A%E7%9A%84%20rootfs%20%E5%9B%BE%E5%83%8F%EF%BC%88raspbian%20wheezy%20%E5%9B%BE%E5%83%8F%EF%BC%89%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fqt-project.org%2Fwiki%2FRaspberryPi_Beginners_guide%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fqt-project.org%2Fwiki%2FRaspberryPi_Beginners_guide%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E8%87%AA%E5%B7%B1%E7%9A%84%20rootfs%20%E6%97%B6%EF%BC%8C%E9%81%87%E5%88%B0%E4%BA%86%E6%82%A8%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%BB%96%E4%BB%AC%E6%8F%90%E5%87%BA%E7%9A%84%E4%BF%AE%E5%A4%8D%E6%96%B9%E6%B3%95%E5%8F%AF%E8%83%BD%E6%98%AF%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E9%82%A3%E5%B0%B1%E6%98%AF%E8%BF%90%E8%A1%8C%E4%B8%80%E4%B8%AA%E8%84%9A%E6%9C%AC%E6%9D%A5%E4%BF%AE%E5%A4%8D%E7%AC%A6%E5%8F%B7%E9%93%BE%E6%8E%A5%E5%92%8C%E5%BA%93%E8%B7%AF%E5%BE%84%EF%BC%8C%E5%8C%85%E5%90%AB%E5%9C%A8%E4%BB%96%E4%BB%AC%E6%8F%90%E4%BE%9B%E7%9A%84%20croos-compiled-tools%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%E5%B0%BD%E7%AE%A1%E5%A6%82%E6%AD%A4%EF%BC%8C%E7%BD%91%E7%BB%9C%E4%B8%8A%E5%88%B0%E5%A4%84%E9%83%BD%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%E6%97%A7%E7%9A%84%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E8%BF%99%E7%A1%AE%E5%AE%9E%E4%BB%A4%E4%BA%BA%E5%A4%B4%E7%96%BC%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%B8%85%E7%90%86%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%E9%9D%9E%E5%B8%B8%E9%87%8D%E8%A6%81%E3%80%82%E8%BF%99%E9%87%8C%E9%9C%80%E8%A6%81%E7%89%B9%E5%88%AB%E6%8C%87%E5%87%BA%E7%9A%84%E6%98%AF%EF%BC%8C%E5%94%AF%E4%B8%80%E5%AE%9E%E9%99%85%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%B8%85%E7%90%86%E5%AD%98%E5%82%A8%E5%BA%93%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egit%20%E5%AD%90%E6%A8%A1%E5%9D%97%20foreach%E2%80%94%E2%80%94%E9%80%92%E5%BD%92%E2%80%9Cgit%20clean%20-dfx%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E2%80%9Cmake%20confclean%E2%80%9D%E5%9C%A8%20Qt5%20%E4%B8%AD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E8%80%8C%E2%80%9Cmake%20clean%E2%80%9D%E5%8F%AA%E8%83%BD%E6%B8%85%E9%99%A4%20.o%E5%92%8C%E5%85%B6%E4%BB%96%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20.%2Fconfigure%20%E7%94%9F%E6%88%90%E7%9A%84%E6%89%80%E6%9C%89%E9%85%8D%E7%BD%AE%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%B8%8B%E8%BD%BD%20tar.gz%20%E5%B9%B6%E4%BD%BF%E7%94%A8%E8%AF%A5%E6%BA%90%E4%BB%A3%E7%A0%81%E5%AF%B9%E4%BA%8E%20Qt5%20%E6%9D%A5%E8%AF%B4%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E9%80%89%E6%8B%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9C%9F%E7%9A%84%E5%BE%88%E6%83%B3%E7%94%A8%20imx6%20%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%BF%E7%94%A8%E6%88%91%E8%87%AA%E5%B7%B1%E7%94%A8%20buildroot%20%E7%94%9F%E6%88%90%E7%9A%84%20rootfs%EF%BC%88%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%89%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESantiago%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B2%A1%E6%9C%89%40-no-gcc-sysroot%20%E4%B8%8E%20-sysroot%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%BA%20ltib%20%E7%9A%84%20freescale-linaro%20%E5%B7%A5%E5%85%B7%E9%93%BE%E5%88%B6%E4%BD%9C%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%B8%8D%E5%85%81%E8%AE%B8%E6%82%A8%E8%AE%BE%E7%BD%AE%20-sysroot%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%89%80%E6%9C%89%E5%9F%BA%E6%9C%AC%E7%9A%84%20posix%20building-blooks%20%E9%83%BD%E4%BD%8D%E4%BA%8E%E5%B7%A5%E5%85%B7%E9%93%BE%E4%B8%AD%EF%BC%8C%E8%80%8C%E4%B8%BA%20gcc%20%E8%AE%BE%E7%BD%AE%20-sysroot%20%E4%BC%9A%E7%A0%B4%E5%9D%8F%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C'-sysroot'%20%E5%92%8C%20'-no-gcc-sysroot'%20%E7%9A%84%E7%BB%84%E5%90%88%E4%BC%9A%E5%AF%BC%E8%87%B4%20Qt5%20%E5%9C%A8%E5%90%8E%E5%8F%B0%E6%89%A7%E8%A1%8C%E4%B8%80%E4%BA%9B%E7%A5%9E%E5%A5%87%E7%9A%84%E6%93%8D%E4%BD%9C%EF%BC%88%E4%BE%8B%E5%A6%82PKG%20%E5%8F%98%E9%87%8F%EF%BC%89%E4%BD%86%E4%B8%8D%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%B0%86%E2%80%9C--sysroot%E2%80%9D%E6%B7%BB%E5%8A%A0%E5%88%B0%20gnu%20%E6%A0%87%E5%BF%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Joerg%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%9B%9E%E7%AD%94%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E7%9B%AE%E5%89%8D%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%20LTIB%20%E4%B8%AD%E7%9A%84%E5%9B%BE%E5%83%8F%E4%B8%8A%E6%9E%84%E5%BB%BA%20QT4.8%E3%80%82%E7%94%B1%E4%BA%8E%20Yocto%20%E5%9B%BE%E5%83%8F%E5%86%85%E7%BD%AE%E6%9C%89%20QT%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E7%A8%8D%E5%90%8E%E4%BC%9A%E8%80%83%E8%99%91%E5%AE%83%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%80%9A%E8%BF%87%E8%B0%B7%E6%AD%8C%E6%90%9C%E7%B4%A2%E5%B9%B6%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%8F%90%E5%88%B0%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%20libjpeg-dev%20%E7%9A%84%E7%9B%B8%E5%85%B3%E5%B8%96%E5%AD%90%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AA%E5%B8%96%E5%AD%90%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E4%BF%AE%E5%A4%8D%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHallo%20Bill%2C%3C%2FP%3E%3CP%3E4.8%20%E7%89%88%E6%9C%AC%E6%97%A0%E9%9C%80%E8%BF%99%E4%B9%88%E5%81%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9C%8B%E7%9C%8B%E8%BF%99%E4%B8%AA%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F339555%23339555%22%20title%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F339555%23339555%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F339555%23339555%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E4%B8%BA%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%20Boundary%20%E7%9A%84%20Nitrogen6x%20%E6%9D%BF%E6%9E%84%E5%BB%BA%20QT4.8%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E5%9C%A8%E7%AC%AC%208%20%E6%AD%A5%E6%9E%84%E5%BB%BA%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E2%80%9C%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Ajpeglib.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E2%80%9D%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%A0%E4%BB%AC%E5%AF%B9%E4%BA%8E%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%94%99%E8%AF%AF%E5%88%97%E8%A1%A8%E6%9C%89%E4%BB%80%E4%B9%88%E8%AF%84%E8%AE%BA%E3%80%82%3C%2FP%3E%3CP%3Ecd%E2%80%9C%2Fhome%2Fbyang%2Fqt%2F.%2Fsrc%2Fplugins%2Fimageformats%2Fjpeg%E2%80%9D%3CBR%20%2F%3E%E5%88%B6%E4%BD%9C%20Makefile%3CBR%20%2F%3E%20make%5B4%5D%3A%20%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fbyang%2Fqt%2Fsrc%2Fplugins%2Fimageformats%2Fjpeg'%3CBR%20%2F%3E%20make%5B4%5D%3A%20%60Makefile'%20%E6%98%AF%E6%9C%80%E6%96%B0%E7%9A%84%E3%80%82%3CBR%20%2F%3Emake%5B4%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%9C%2Fhome%2Fbyang%2Fqt%2Fsrc%2Fplugins%2Fimageformats%2Fjpeg%E2%80%9D%3CBR%20%2F%3E%20make%5B3%5D%3A%20%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%9C%2Fhome%2Fbyang%2Fqt%2Fsrc%2Fplugins%2Fimageformats%2Fjpeg%E2%80%9D%3CBR%20%2F%3E%20make%5B3%5D%3A%20%E8%BF%9B%E5%85%A5%E7%9B%AE%E5%BD%95%20%60%2Fhome%2Fbyang%2Fqt%2Fsrc%2Fplugins%2Fimageformats%2Fjpeg'%3CBR%20%2F%3E%20arm-fsl-linux-gnueabi-g%2B%2B%20-c%20-pipe%20-O2%20-O2%20-march%3Darmv7-a%20-mfpu%3Dneon%20-DLINUX%3D1%20-DEGL_API_FB%3D1%20-fvisibility%3Dhidden%20-fvisibility-inlines-hidden%20-D_REENTRANT%20-Wall%20-W%20-fPIC%20-DQT_NO_DEBUG%20-DQT_PLUGIN%20-DQT_GUI_LIB%20-DQT_NETWORK_LIB%20-DQT_CORE_LIB%20-DQT_SHARED%20-I..%2F..%2F..%2F..%2Fmkspecs%2Fqws%2Flinux-imx6-g%2B%2B%20-I%E3%80%82-I..%2F..%2F..%2F..%2Finclude%2FQtCore%20-I..%2F..%2F..%2F..%2Finclude%2FQtNetwork%20-I..%2F..%2F..%2F..%2Finclude%2FQtGui%20-I..%2F..%2F..%2F..%2Finclude%20-I..%2F..%2F..%2Fgui%2Fimage%20-I.moc%2Frelease-shared%20-I%2Fhome%2Fbyang%2Fltib%2Frootfs%2Fusr%2Finclude%20-I%2Ftftpboot%2Frootfs%2Fusr%2Finclude%2Farm-linux-gnueabi%2F%20-o%20.obj%2Frelease-shared%2Fqjpeghandler.o%20..%2F..%2F..%2Fgui%2Fimage%2Fqjpeghandler.cpp%3CBR%20%2F%3E%20..%2F..%2F..%2Fgui%2Fimage%2Fqjpeghandler.cpp%3A71%3A21%3A%20%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Ajpeglib.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3Emake%5B3%5D%3A%20***%20%5B.obj%2Frelease-shared%2Fqjpeghandler.o%5D%20%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%80%E8%BF%91%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E4%B8%8A%E8%BF%B0%E8%AF%B4%E6%98%8E%E4%B8%BA%20iMX6%20%E6%9D%BF%E6%9E%84%E5%BB%BA%20QT5%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%9A%20%3CSPAN%20style%3D%22font-size%3A%208.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2FDownload%3FcolCode%3DL3.0.35_4.0.0_UBUNTU_RFS%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%26amp%3Bfpsp%3D1%26amp%3BWT_TYPE%3DBoard%2520Support%2520Packages%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dtgz%26amp%3BWT_ASSET%3DDownloads%26amp%3Bsr%3D60%26amp%3BParent_nodeId%3D1337694700967726419044%26amp%3BParent_p%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EL3.0.35_4.0.0_UBUNTU_RFS%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E.%2Fconfigure%20-v%20-opensource%20-confirm-license%20-no-pch%20-no-xcb%20-no-opengl%20-opengl%20es2%20-make%20libs%20-device%20imx6%20-device-option%20CROSS_COMPILE%3D%2Fopt%2Fgcc-linaro-arm-linux-gnueabihf-4.8-2013.06_linux%2Fbin%2Farm-linux-gnueabihf--sysroot%20%2Fhome%2Fmax%2FDev%2Frootfs%20-no-gcc-sysroot%20-prefix%20%2Fopt%2FQt5-imx6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fopt%2Fgcc-linaro-arm-linux-gnueabihf-4.8-2013.06_linux%2Fbin%2F..%2Flib%2Fgcc%2Farm-linux-gnueabihf%2F4.8.2%2F..%2F..%2F..%2F..%2Farm-linux-gnueabihf%2Fbin%2Fld%3A%20%E9%94%99%E8%AF%AF%EF%BC%9Aopengles2%20%E4%BD%BF%E7%94%A8%20VFP%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%8F%82%E6%95%B0%EF%BC%8Copengles2.o%E6%B2%A1%E6%9C%89%3C%2FP%3E%3CP%3E%2Fopt%2Fgcc-linaro-arm-linux-gnueabihf-4.8-2013.06_linux%2Fbin%2F..%2Flib%2Fgcc%2Farm-linux-gnueabihf%2F4.8.2%2F..%2F..%2F..%2F..%2Farm-linux-gnueabihf%2Fbin%2Fld%3A%20%E6%97%A0%E6%B3%95%E5%90%88%E5%B9%B6%E6%96%87%E4%BB%B6%20opengles2.o%20%E7%9A%84%E7%9B%AE%E6%A0%87%E7%89%B9%E5%AE%9A%E6%95%B0%E6%8D%AE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E...%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22mce_paste_marker%22%3E%3C%2FP%3E%3CP%20class%3D%22mce_paste_marker%22%3E%2Fhome%2Fmax%2FDev%2Frootfs%2Fusr%2Flib%2FlibGAL.so%3A%20%E5%AF%B9%E2%80%9CXMapRaised%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3E%2Fhome%2Fmax%2FDev%2Frootfs%2Fusr%2Flib%2FlibGAL.so%3A%20%E5%AF%B9%E2%80%9Cpthread_setspecific%40GLIBC_2.4%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3E%2Fhome%2Fmax%2FDev%2Frootfs%2Fusr%2Flib%2FlibGAL.so%3A%20%E5%AF%B9%E2%80%9C_XReadPad%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3E%2Fhome%2Fmax%2FDev%2Frootfs%2Fusr%2Flib%2FlibGAL.so%3A%20%E5%AF%B9%E2%80%9Cdlopen%40GLIBC_2.4%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3E%2Fhome%2Fmax%2FDev%2Frootfs%2Fusr%2Flib%2FlibGAL.so%3A%20%E5%AF%B9%E2%80%9Cpthread_key_delete%40GLIBC_2.4%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3E%2Fhome%2Fmax%2FDev%2Frootfs%2Fusr%2Flib%2FlibGAL.so%3A%20%E5%AF%B9%E2%80%9CXPending%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3Ecollect2%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9Ald%20%E8%BF%94%E5%9B%9E%201%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3C%2FP%3E%3CP%3Emake%3A%20***%20%5Bopengles2%5D%20%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3CP%3EOpenGL%20ES%202.x%20%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3EOpenGL%20ES%202.0%20%E5%8A%9F%E8%83%BD%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%EF%BC%81%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87%E7%BC%96%E8%BE%91%E6%9D%A5%E4%BF%AE%E6%94%B9%E5%8C%85%E5%90%AB%E5%92%8C%E5%BA%93%E6%90%9C%E7%B4%A2%E8%B7%AF%E5%BE%84%3C%2FP%3E%3CP%3EQMAKE_INCDIR_OPENGL_ES2%E3%80%81QMAKE_LIBDIR_OPENGL_ES2%20%E5%92%8C%20QMAKE_LIBS_OPENGL_ES2%20%E4%B8%AD%E7%9A%84%3C%2FP%3E%3CP%3E%2Fhome%2Fmax%2FDev%2Frepository%2Fqt5%2Fqtbase%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E7%84%B6%E5%90%8E%E5%A6%82%E6%9E%9C%E6%88%91%E5%8F%96%E5%87%BA%20ES%EF%BC%8C%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%EF%BC%9A%E2%80%9C%3C%2FSPAN%3E%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%9E%B6%E6%9E%84%EF%BC%81%E2%80%9D%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E2%80%9C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E5%AF%B9%E6%AD%A4%E5%8F%91%E8%A1%A8%E8%AF%84%E8%AE%BA%E5%90%97%EF%BC%9F%E6%9C%89%E4%BB%80%E4%B9%88%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E9%99%84%E5%8A%A0%E7%9A%84%E8%A1%A5%E4%B8%81%E5%8F%AF%E4%BB%A5%E4%BF%AE%E5%A4%8D%E8%AF%A5%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%E6%9C%80%E5%A4%A7%E9%99%90%E5%BA%A6%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Brad%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E6%88%90%E4%B8%BA%E6%9C%80%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20Yocto%20%E7%9A%84%20QT%E3%80%81rootfs%20%E5%92%8C%E5%B7%A5%E5%85%B7%E9%93%BE%E7%BC%96%E5%86%99%E6%96%B0%E7%9A%84%20Howto%E2%80%9C%E8%AE%BE%E7%BD%AE%20QT%20Creator%E2%80%9D%E7%9A%84%E4%BA%BA%E3%80%82%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BD%86%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E6%88%91%E6%85%A2%E6%85%A2%E5%9C%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%9B%B8%E4%BF%A1%E6%B2%A1%E6%9C%89%E4%BA%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%9C%9F%E6%AD%A3%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%3B-)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E5%88%B0%20~%2Fimx6%2Fltib%2Frootfs%20%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%8F%AA%E8%BF%9B%E8%A1%8C%20NFS%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20LTIB%20%E5%88%9B%E5%BB%BA%E4%BA%86%20rootfs%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%90%E8%A1%8C%E9%85%8D%E7%BD%AE%E4%BC%9A%E4%BA%A7%E7%94%9F%E5%87%A0%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%96%87%E4%BB%B6%E5%88%B6%E4%BD%9C%E5%B9%B6%E5%AE%89%E8%A3%85%E5%88%B0%20%2Fopt%2Fqt4%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%AD%A5%E9%AA%A4%EF%BC%8312%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%BA%8C%E7%82%B9%E6%AF%AB%E6%97%A0%E6%84%8F%E4%B9%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%B2%A1%E6%9C%89%20opt%2Fqt4%2Fexamples%20%E7%9B%AE%E5%BD%95%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E9%82%A3%E9%87%8C%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eroot%40freescale%20%2F%24%20ls%20opt%2Fqt4%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Ebin%20%E5%8C%85%E5%90%AB%20lib%20%E6%8F%92%E4%BB%B6%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9F%A5%E9%81%93%E6%88%91%E5%8F%AF%E8%83%BD%E5%9C%A8%E5%93%AA%E5%84%BF%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%88%91%E9%9D%9E%E5%B8%B8%E4%BB%94%E7%BB%86%E5%9C%B0%E9%81%B5%E5%BE%AA%E4%BA%86%E6%8C%87%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%83%E6%8B%89%E5%BE%B7%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%BF%85%E9%A1%BB%E5%B0%86%E2%80%9C%2Fmedia%2FNameOfMountedRootFs%E2%80%9D%E6%94%BE%E7%BD%AE%E4%B8%BA%20ROOTFFS%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E4%B8%8A%E8%BF%B0%E8%AF%B4%E6%98%8E%E6%9E%84%E5%BB%BA%20Qt4%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A5%E9%AA%A4%EF%BC%832%20%E4%B8%AD%E6%98%AF%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%24%20ln%20-s%20%24(ROOTFFS)%20%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E5%AE%83%E6%97%B6%EF%BC%8C%E5%AE%83%E6%8C%87%E5%87%BA%E5%8F%98%E9%87%8F%E2%80%9CROOTFFS%EF%BC%9A%E6%9C%AA%E6%89%BE%E5%88%B0%E5%91%BD%E4%BB%A4%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%A4%B1%E8%B4%A5%E5%90%97%EF%BC%9F%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%20ROOTFS%20%E4%BD%86%E4%BB%8D%E7%84%B6%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EROOTFFS%20%E6%98%AF%20qt%20%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%E5%90%97%EF%BC%9F%E5%9C%A8%E5%93%AA%E9%87%8C%E5%AE%9A%E4%B9%89%EF%BC%9F%E5%AE%83%E4%B8%8D%E5%9C%A8%E6%88%91%E7%9A%84%E7%8E%AF%E5%A2%83%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AE%83%E4%BD%8D%E4%BA%8E%20master-next%20%E5%88%86%E6%94%AF%E4%B8%8A%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%B0%9A%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A1%AE%E5%AE%9A%E6%B7%BB%E5%8A%A0%E4%BA%86%20Qt5%20%E5%90%97%EF%BC%9F%E5%B7%AB%E5%A9%86%E4%BB%93%E5%BA%93%E8%A6%81%E6%A3%80%E6%9F%A5%E5%90%97%EF%BC%9F%E8%BF%AA%E4%BC%A6%EF%BC%8C%E8%A6%81%E5%BB%BA%E9%80%A0%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJoerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%BD%91%E7%AB%99%E4%B8%8B%E8%BD%BD%E6%96%87%E6%A1%A3%E5%8C%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%8B%E8%BD%BD%E4%BA%86%E5%9B%BE%E5%83%8F%EF%BC%88L3.0.35_4.0.0_130424_images_MX6%EF%BC%89%E5%A6%82%E4%BD%95%E5%B0%86%E5%85%B6%E6%94%BE%E5%9C%A8%20SD%20%E4%B8%8A%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E6%A3%80%E6%9F%A5%E4%BA%86%E6%88%91%E9%93%BE%E6%8E%A5%E7%9A%84%20BSP%20%E6%94%AF%E6%8C%81%E5%93%AA%E4%BA%9B%E6%9C%BA%E5%99%A8%E3%80%82%E7%9C%8B%E6%9D%A5%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%20nitro6x%20%E6%98%AF%E5%8F%97%E6%94%AF%E6%8C%81%E7%9A%84%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%BC%BC%E4%B9%8E%E6%9C%89%E4%B8%80%E7%BB%84%E9%92%88%E5%AF%B9%E6%82%A8%E6%89%80%E6%8C%87%E7%9A%84%E6%BC%94%E7%A4%BA%E5%9B%BE%E5%83%8F%E7%9A%84%20Qt4%20%E9%85%8D%E6%96%B9%EF%BC%9A%3CA%20href%3D%22http%3A%2F%2Fimgur.com%2Fa%2FN9hL7%22%20title%3D%22http%3A%2F%2Fimgur.com%2Fa%2FN9hL7%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E7%9B%B8%E5%86%8C%20-%20Imgur%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%82%A3%E4%B9%88%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20yocto%20%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%E5%90%97%EF%BC%9F%E5%83%8F%20fsl-image-gui-nitrogen6x.sdcard%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%96%E6%8C%87%E7%9A%84%E6%98%AF%E9%A2%84%E5%85%88%E6%9E%84%E5%BB%BA%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%82%A8%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E8%8A%AF%E7%89%87%E7%9A%84%E2%80%9C%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E8%BD%AF%E4%BB%B6%20-%20%E6%9D%BF%E7%BA%A7%E6%94%AF%E6%8C%81%E5%8C%85%E2%80%9D%E9%83%A8%E5%88%86%E4%B8%8B%E6%89%BE%E5%88%B0%E3%80%82%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E5%AF%B9%E4%BA%8E%20SabreSD%20%E6%9D%BF%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DRDIMX6SABREBRD%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20style%3D%22color%3A%20%23017bba%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23cccccc%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EL3.0.35_4.0.0_DEMO_IMAGE%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%AF%B9%20LTIB%20%E5%92%8C%20Yocto%20%E7%9A%84%E7%9C%8B%E6%B3%95%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E6%AD%A3%E5%9C%A8%E8%BD%AC%E5%90%91%20Yocto%EF%BC%8C%E8%80%8C%20LTIB%20%E5%B9%B3%E5%8F%B0%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E7%BC%BA%E9%99%B7%E3%80%82%E4%BD%BF%E7%94%A8%20Freescale%20%E7%A4%BE%E5%8C%BA%20BSP%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20title%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreescale%2Ffsl-community-bsp-platform%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B4%E6%98%8E%E4%BD%8D%E4%BA%8E%E9%93%BE%E6%8E%A5%E4%B8%AD%E3%80%82%E7%BC%96%E8%AF%91%E5%90%8E%EF%BC%8C%E5%B0%86%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%20SD%20%E5%8D%A1%E6%98%A0%E5%83%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E5%A4%8D%E5%88%B6%E5%88%B0%E5%AE%9E%E9%99%85%E7%9A%84%20SD%20%E5%8D%A1%EF%BC%8C%E5%B9%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E4%BB%BB%E4%BD%95%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%E5%B7%B2%E7%BB%8F%E5%AE%8C%E5%85%A8%E6%94%AF%E6%8C%81%20Qt4%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%9C%80%E8%BF%91%E6%89%8D%E6%B7%BB%E5%8A%A0%20Qt5%20%E6%94%AF%E6%8C%81%EF%BC%88%E5%A4%A7%E7%BA%A6%E4%B8%80%E5%91%A8%E5%89%8D%E6%B7%BB%E5%8A%A0%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E2%80%9C%E8%AF%A5%E6%9E%84%E5%BB%BA%E5%B7%B2%E5%9C%A8%E9%A2%84%E6%9E%84%E5%BB%BA%E7%9A%84%20rootfs%EF%BC%88%E5%9F%BA%E4%BA%8E%20LTIB%EF%BC%89%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%AA%8C%E8%AF%81%EF%BC%8C%E5%8F%AF%E4%BB%8E%20freescale.com%20%E4%B8%8B%E8%BD%BD%E2%80%9D%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%E6%88%91%E5%BF%85%E9%A1%BB%E7%94%A8%20ltib%20%E6%9D%A5%E6%9E%84%E5%BB%BA%E5%AE%83%E6%88%96%E8%80%85%E6%88%91%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%E5%AE%83%E5%90%97%EF%BC%9F%E5%BD%93%E6%88%91%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%E5%AE%83%E6%97%B6%EF%BC%8C%E8%AF%B7%E8%A7%A3%E9%87%8A%E5%A6%82%E4%BD%95%E5%9C%A8%E4%B8%BB%E6%9C%BA%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3ELTIB%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E6%B2%A1%E6%9C%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E4%BB%80%E4%B9%88%E6%84%8F%E4%B9%89%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E5%9B%A0%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3EYocto%3C%2FSPAN%3E%3CSPAN%20class%3D%22hps%22%3E%E6%9B%B4%E5%8F%97%E6%AC%A2%E8%BF%8E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%81%9A%20LTIB%20%E5%87%A0%E5%A4%A9%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3EJoerg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E8%84%9A%E6%9C%AC%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%23!%2Fbin%2Fsh%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E.%2Fconfigure%20-v%20-opensource%20-confirm-license%20-no-pch%20-no-xcb%20-opengl%20es2%20%5C%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E-%E5%88%B6%E4%BD%9C%E5%BA%93-%E8%AE%BE%E5%A4%87imx6%20%5C%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3B%20-make%20examples%20-make%20demos%20%5C%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E-device-option%20CROSS_COMPILE%3D%2Fhome%2Fsquirem%2FDesktop%2Fpoky-dylan-9.0.0%2Fbuild%2Ftmp%2Fsysroots%2Fx86_64-linux%2Fusr%2Fbin%2Farmv7a-vfp-neon-poky-linux-gnueabi%2Farm-poky-linux-gnueabi-%20%5C%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E-sysroot%20%2Fhome%2Fsquirem%2FDesktop%2Fpoky-dylan-9.0.0%2Fbuild%2Ftmp%2Fdeploy%2Fimages%2Fmountpoint%20%5C%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3B%20-prefix%20%2Fopt%2Fqt5%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%3CSTRONG%3E-no-opengl%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3E-no-gcc-sysroot%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%3CSTRONG%3E-no-opengl%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E4%B8%8E%3CSTRONG%3E-opengl%20es2%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E5%86%B2%E7%AA%81%EF%BC%8C%E5%B9%B6%E4%B8%94%3CSTRONG%3E-no-gcc-sysroot%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E4%B8%8E%3CSTRONG%3E-sysroot%20%3C%2FSTRONG%3E%3CDIR%3E%3CSTRONG%3E%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E5%86%B2%E7%AA%81%E3%80%82%E6%82%A8%E5%8F%AF%E8%83%BD%E8%BF%98%E6%B3%A8%E6%84%8F%E5%88%B0%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%3CSTRONG%3E-no-xcb%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%EF%BC%8C%E5%9B%A0%E4%B8%BA%20xcb%20%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FDIR%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E5%8F%A5%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%B7%BB%E5%8A%A0%E6%9B%B4%E5%A4%9A%E9%80%89%E9%A1%B9%E6%9D%A5%E5%88%A0%E9%99%A4%20SQL%20%E6%94%AF%E6%8C%81%E3%80%82%E8%BF%90%E8%A1%8C%3CSTRONG%3E.%2Fconfigure%20-h%3C%2FSTRONG%3E%E6%9F%A5%E7%9C%8B%E6%82%A8%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%AF%B4%E6%98%8E%E6%9E%84%E5%BB%BA%20QT5%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E4%BD%86%E6%88%91%E5%8F%91%E7%8E%B0%E9%85%8D%E7%BD%AE%E5%91%BD%E4%BB%A4%E4%B8%8D%E9%80%82%E5%90%88%E6%88%91%E7%9A%84%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%89%80%E4%BB%A5%E6%88%91%E5%B0%86%E9%85%8D%E7%BD%AE%E5%91%BD%E4%BB%A4%E6%9B%B4%E6%94%B9%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E.%2Fconfigure%20-v%20-opensource%20-confirm-license%20-system-sqlite%20-no-sse2%20-no-sse3%20-no-ssse3%20-no-sse4.1%20-no-sse4.2-no-avx%20-no-xcb%20-no-sql-mysql%20-no-sql-db2%20-no-sql-ibase%20-no-sql-oci%20-no-sql-odbc%20-no-sql-tds%20-no-sql-sqlite2%20-no-pch%20-no-opengl%20-opengl%20es2%20-wayland%20-make%20libs%20-device%20imx6%20-make%20examples%20-make%20demos%20-device-option%20CROSS_COMPILE%3D%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-fsl-linux-gnueabi-%20-sysroot%20%2Fmedia%2Fnew-version%2Fbuild%2FL3.0.35_4.0.0%2Fltib%2Frootfs%20-no-gcc-sysroot%20-prefix%20%2Fusr%2Flocal%2FTrolltech%2FQt5-imx6-1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E9%80%9A%E8%BF%87%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E2%80%9Cmake%E2%80%9D%E6%97%B6%E5%87%BA%E7%8E%B0%E4%BA%86%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-fsl-linux-gnueabi-g%2B%2B%20-Wl%EF%BC%8C-rpath-link%EF%BC%8C%2Fmedia%2Fnew-version%2Fbuild%2FL3.0.35_4.0.0%2Fltib%2Frootfs%2Fusr%2Flib%20-Wl%EF%BC%8C--no-undefined%20-Wl%EF%BC%8C-O1%20-Wl%EF%BC%8C-rpath%EF%BC%8C%2Fusr%2Flocal%2FQt-5.0.0%2FQt5-imx6-1%2Flib%20-shared%20-o%20libqsqlmysql.so%20.obj%2Frelease-shared%2Fmain.o%20.obj%2Frelease-shared%2Fqsql_mysql.o%20.obj%2Frelease-shared%2Fmoc_qsql_mysql_p.o%20-L%2Fmedia%2Fnew-version%2Fbuild%2FL3.0.35_4.0.0%2Fltib%2Frootfs%2Fusr%2Flib%20-L%2Fusr%2Flib%20-Wl%2C-Bsymbolic-functions%20-rdynamic%20-L%2Fusr%2Flib%2Fmysql%20-lmysqlclient_r%20-L%2Fmedia%2Fnew-version%2Fbuild%2Fltib%2Frpm%2FBUILD%2Fqt5%2Fqtbase%2Flib%20-lQt5Sql%20-lQt5Core%20-lpthread%20%3C%2FP%3E%3CP%3E%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2F..%2Flib%2Fgcc%2Farm-fsl-linux-gnueabi%2F4.6.2%2F..%2F..%2F..%2F..%2Farm-fsl-linux-gnueabi%2Fbin%2Fld%3A%20%E5%9C%A8%E6%90%9C%E7%B4%A2%20libpthread_nonshared.a%20%E6%97%B6%E8%B7%B3%E8%BF%87%E4%B8%8D%E5%85%BC%E5%AE%B9%E7%9A%84%20%2Fusr%2Flib%2Flibpthread_nonshared.a%3C%2FP%3E%3CP%3E%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2F..%2Flib%2Fgcc%2Farm-fsl-linux-gnueabi%2F4.6.2%2F..%2F..%2F..%2F..%2Farm-fsl-linux-gnueabi%2Fbin%2Fld%3A%20%E5%9C%A8%E6%90%9C%E7%B4%A2%20libc_nonshared.a%20%E6%97%B6%E8%B7%B3%E8%BF%87%E4%B8%8D%E5%85%BC%E5%AE%B9%E7%9A%84%20%2Fusr%2Flib%2Flibc_nonshared.a%3C%2FP%3E%3CP%3E.obj%2F%E5%8F%91%E5%B8%83%E5%85%B1%E4%BA%AB%2Fqsql_mysql.o%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%9CQMYSQLDriver%3A%3Aopen(QString%20const%26amp%3B%2C%20QString%20const%26amp%3B%2C%20QString%20const%26amp%3B%2C%20QString%20const%26amp%3B%2C%20int%2C%20QString%20const%26amp%3B)%E2%80%9D%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3Eqsql_mysql.cpp%3A(.text%2B0x2cb4)%3A%E5%AF%B9%E2%80%9Cmysql_set_character_set%E2%80%9D%E6%9C%AA%E5%AE%9A%E4%B9%89%E5%BC%95%E7%94%A8%3C%2FP%3E%3CP%3Ecollect2%EF%BC%9Ald%20%E8%BF%94%E5%9B%9E%201%20%E9%80%80%E5%87%BA%E7%8A%B6%E6%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E9%85%8D%E7%BD%AEQT5%E7%9A%84%E6%97%B6%E5%80%99%E5%B7%B2%E7%BB%8F%E6%8A%8Amysql%E7%9A%84%E9%80%89%E9%A1%B9%E5%8F%96%E6%B6%88%E4%BA%86%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFAQ%3A%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%20qtdeclarative%E2%80%A6%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E..%2Fqtbase%2Fbin%2Fqmake%20-r%3C%2FP%3E%3CP%3E%E9%A1%B9%E7%9B%AE%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9C%AA%E7%9F%A5%E7%9A%84%E6%9E%84%E5%BB%BA%E9%83%A8%E5%88%86%EF%BC%9A%E6%BC%94%E7%A4%BA%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E8%AF%BB%E5%8F%96%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtdeclarative%2Fsrc%2Fsrc.pro%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E8%AF%BB%E5%8F%96%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtdeclarative%2Fsrc%2Fqml%2Fqml.pro%3C%2FP%3E%3CP%3E%E9%A1%B9%E7%9B%AE%E6%B6%88%E6%81%AF%EF%BC%9A%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtbase%2Fbin%2Fsyncqt%20-module%20QtQml%20-version%205.1.0-outdir%20%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtdeclarative%20%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtdeclarative%3C%2FP%3E%3CP%3E%3CSRCBASE%3E%20%3D%20%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtdeclarative%20%3C%2FSRCBASE%3E%3C%2FP%3E%3CP%3E%3COUTBASE%3E%3D%20%2Fhome%2Fhp-lablinux%2Fltib_imx6solo_duallite%2Fqt5%2Fqtdeclarative%20%3C%2FOUTBASE%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%A1%B9%E7%9B%AE%E9%94%99%E8%AF%AF%EF%BC%9AQT_PRIVATE%20%E4%B8%AD%E7%9A%84%E6%9C%AA%E7%9F%A5%E6%A8%A1%E5%9D%97%EF%BC%9Av8%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E7%A1%AE%E5%AE%9A%E9%97%AE%E9%A2%98%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E5%9B%9B%E5%A4%84%E5%AF%BB%E6%89%BE%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E6%9C%89%E7%94%A8%E7%9A%84%E6%8F%90%E7%A4%BA%E3%80%82%E4%BD%A0%E6%9C%89%E4%B8%BB%E6%84%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-right%3A%200.9pt%3B%20margin-left%3A%2013.6pt%3B%20margin-bottom%3A%200.0001pt%3B%20text-indent%3A%20-7.5pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%E2%80%9C%E4%BF%AE%E6%94%B9%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%20qtbase%2Fbin%2Fqt.conf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-right%3A%200.9pt%3B%20margin-left%3A%2013.6pt%3B%20margin-bottom%3A%200.0001pt%3B%20text-indent%3A%20-7.5pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%E5%B9%B6%E6%B7%BB%E5%8A%A0%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%89%8D%E7%BC%80%EF%BC%8C%E5%8D%B3%20coconfigure%20%E4%B8%8A%E7%BB%99%E5%87%BA%E7%9A%84%E5%89%8D%E7%BC%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-right%3A%200.9pt%3B%20margin-left%3A%2013.6pt%3B%20margin-bottom%3A%200.0001pt%3B%20text-indent%3A%20-7.5pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E*%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-right%3A%200.9pt%3B%20margin-left%3A%2013.6pt%3B%20margin-bottom%3A%200.0001pt%3B%20text-indent%3A%20-7.5pt%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%90%E8%A1%8C%20configure%20%E5%91%BD%E4%BB%A4%E5%90%8E%EF%BC%8C%E5%9C%A8%E6%94%AF%E6%8C%81%E7%9A%84%E5%8A%9F%E8%83%BD%E6%91%98%E8%A6%81%E4%B8%AD%EF%BC%8COpenVG%20%E6%98%BE%E7%A4%BA%E4%B8%BA%E4%B8%8D%E5%8F%97%E6%94%AF%E6%8C%81%EF%BC%8C%E8%BF%99%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E8%BF%98%E6%98%AF%E6%84%8F%E5%91%B3%E7%9D%80%E6%88%91%E8%BF%99%E8%BE%B9%E7%BC%BA%E5%B0%91%E6%9F%90%E4%BA%9B%E5%BA%93%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%B8%BAi.MX6%E6%9E%84%E5%BB%BAQT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%95%88%E6%9E%9C%E9%9D%9E%E5%B8%B8%E5%A5%BD%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%94%AF%E4%B8%80%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%BD%93%E4%BD%BF%E7%94%A8%20eglfs%20%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E9%BC%A0%E6%A0%87%E6%88%96%E9%94%AE%E7%9B%98%E4%B8%8D%E5%B7%A5%E4%BD%9C%E3%80%82eglfs%20%E6%94%AF%E6%8C%81%E7%94%A8%E6%88%B7%E8%BE%93%E5%85%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-11-2013 10:29 AM
更新人:
