Converting CAN-FD and CAN-HD vice versa on i.Mx8qxp
1,406 次查看
notify1forme
Hi Vincent
Glad to see you again on the internet.
I want to make sure that is it possible to convert the data between can-fd and can-hs vice versa on application.
as I see it is possible to use it but I am not going to go through all from scratch.
So Could you guide me Which is the best way to get it?
My Circumstance :
I.mx8qxp + baseboard  + audio daughter board .
Have a nice day.
Vincent Park.
1 回复
1,259 次查看
jamesbone
Hello Vincent,
pls refer to the chapter 4.5 FlexCAN of enclosed file:
The FlexCAN on the i.MX 8QuadMax/8QuadXPlus supports CAN FD protocol. and for the testing here is a document that you can review
https://community.nxp.com/docs/DOC-341641
