Our customer, SONY is asking whether MKW30 or MKW40 has implemented sniff mode or not.
Do you plan to implement this mode?
If yes, when will FSL release it ?
If no, would you tell us the reason? Because we need to tell it to them.
*H/W does not implement this mode. etc..
Koichi
Solved! Go to Solution.
Hello Koichi-san,
According to MKW3x/4x reference manual, the sniff mode is not currently supported by the hardware. The SNF_EN bit from the sniff control register has no effect.
But if your question is about having a BLE/IEEE 802.15.4 sniffer using KW3x/4x the answer is yes, we will have. The planned date is end of Q3 - beginning of Q4 2015.
Mihai
Hello Koichi-san,
Mihai
Hello Mihai_san,
Thank you for your response.
I will inform them of our plan.
Koichi
