sniff mode
Showing results forย
Search instead forย
Did you mean:ย
sniff mode
koichimatsuo
Our customer, SONY is asking whether MKW30 or MKW40 has implemented sniff mode or not.
Do you plan to implement this mode?
If yes, when will FSL release it ?
If no, would you tell us the reason? Because we need to tell it to them.
  *H/W does not implement this mode. etc..
Koichi
mihaidragnea
Hello Koichi-san,
According to MKW3x/4x reference manual, the sniff mode is not currently supported by the hardware. The SNF_EN bit from the sniff control register has no effect.
But if your question is about having a BLE/IEEE 802.15.4 sniffer using KW3x/4x the answer is yes, we will have. The planned date is end of Q3 - beginning of Q4 2015.
Mihai
mihaidragnea
Hello Koichi-san,
Mihai
koichimatsuo
Hello Mihai_san,
Thank you for your response.
I will inform them of our plan.
Koichi
