jn5169 control bridge and APS data confirm fail
jiajuntan
i am trying to receive reports from a zigbee device. I can receive all reports from the device except one that reports a manufacturer specific attribute. Whenever that packet is received, the control bridge (JN-AN-1216) sends APS data confirm fail to the host. The host does not get the report. I can verify that the report was observed by another zigbee sniffer.
Any idea why, or is there something i need to modify in the control bridge code to receive that report?
Jia Jun
mario_castaneda
Hi Jian Jun Tan,
What is the version that you are using (JN-AN-1216)?
Some bugs was solved in the newest versions, like:
Control Bridge not parsing string correctly for reports
Mario
jiajuntan
I am using version 1005. I see that this is already the latest version available on the zigbee 3.0 page.
Attached is the report captured by uniqua that causes the APS Data Fail. Hopefully it helps provide some clue.
jiajuntan
I think i found the solution. Thanks much.
sunburst
Hi:
   I meet the same bug, could you tell me how to solve it?
   Thank you very much!
mario_castaneda
Hi Zhao,
What is the ZigBee control bridge version that you are working on?
Mario
