can't download JN-SW-4168 sdk
youhuangfu
neals
I found this thread after trying many times to download JN-SW-4168 over the last few days.
Every time I download it the zipfile ends up being zero bytes long.
Same for other downloads, JN-SW-4141.zip and JN-SW-4263-SDK.zip which I previously downloaded on September 8 of this year.
I can download JN-SW-4107.zip, which I assume is intact at ~360KB.
What's the trick?
Thank you kindly.
Neal
mario_castaneda
Hi Neal,
Sorry for this inconvenience.
We are fixing this issue. I will reply to you as soon as possible.
Mario
neals
I am happy to report that I successfully downloaded the 4168 SDK a few minutes ago.
Thank you for your support.
Neal
mario_castaneda
Hi Neal,
The issue has been fixed and the files are working now.
Could you please try to download once more and please let me know if you have issues with the zip file.
Mario
neals
Mario,
The download problem was solved back in December.
Today I'm happy to report that I was finally able to get the JN-AN-1189-ZigBee-HA-Demo DimmableLight project to compile. As someone who has never used Eclipse / BeyondStudio I had no idea I would need to check the Copy Projects into Workspace option when importing the AN-1189 projects from a NON-Zip file. Once I got that figured out it was of course obvious how the SDKs must be installed relative to the Project/Workspace.
The example shown in Step 2 of Chapter 2.2 of "BeyondStudio for NXP Installation and User Guide" shows the project import dialog window with the defaults for a non-Zip import operation. However, when you choose to import from a Zip file the Copy Projects into Workspace checkbox is forced to the enabled state and grayed-out. I didn't notice any mention about needing to check the box for the non-Zip case.
Clarifying this situation would save folks new to BeyondStudio quite a bit of time in getting up and running, IMHO.
Neal
mario_castaneda
Hi Neal,
Could you please take a look at the next document?
Beyond Studio Common Errors
Mario
mario_castaneda
Could you please download it again?
Please let me know if you have problems with the files.
Mario
