Could you please clarify what could be th reason of such Error when using ZPS_eAplZdoBind()
This is happening time to time. To be specific I can call ZPS_eAplZdoBind() to an object without any issue and in an other occasion, all ZPS_eAplZdoBind() I'm doing will report the same error ZPS_APL_ZDP_E_INV_REQUESTTYPE
The code is using the JN-AN-1216
This looks similar to https://community.nxp.com/t5/Wireless-Connectivity/ZPS-APL-ZDP-E-INV-REQUESTTYPE-on-jn5168-zigbee/m-... but it looks that no answers was provided
Hi @zigbee1,
You could free the APD Instance if you have that error.
hAPduInst = PDUM_hAPduAllocateAPduInstance(apduZDP); // ToDo - Clarify apduZCL is defined in application scope; how to link the name in BDB (independent of application)
if( ZPS_APL_ZDP_E_INV_REQUESTTYPE == eStatus ||
ZPS_APL_ZDP_E_INSUFFICIENT_SPACE== eStatus )
PDUM_eAPduFreeAPduInstance(hAPduInst);
Mario
Could you kindly response to the question which is what is the meaning of that errors ?
What you have responded is what to do when receiving this error to avoid a PDU leakage (and which by the way is already done) !
Hi @zigbee1,
Could you please share the implementation that you did?
What is the process that you are doing?
Also, you could print out the vDisplayBindingTable for the debugging purpose.
Mario
