I was checking the new 1.0.1 version of the Thread stack with FRDM-KW41Z, FRDM-KW40Z and FRDM-KW24D nodes and I couldn't get the KW24D and KW40Z nodes to join a network created by the KW41Z node. I am using the thread_router_eligible_device example for all nodes. I programmed the FRDM-KW40Z and FRDM-KW24D devices using the source from Kinetis_Thread_1.0.1.12.exe installer, and I programmed the FRDM-KW41Z using the source from Kinetis_Thread_1.0.1_Alpha-1.exe installer. Is there anything I am missing?
