The mac seq number in 802.15.4 Sleepy device
wslee
* Test environment :
 - JN5169
 - SDK : JN-SW-4163
 - device : Coordinator, Sleepy device
 - JN-AN-1174
I am using  vAppApiSaveMacSettings() before vAHI_Sleep(E_AHI_SLEEP_OSCON_RAMON) and vAppApiRestoreMacSettings() when AppWarmStart().
My problem is the following.
The mac seq number is always same if it transmits by vAppApiMcpsRequest() when sleepy device was woken from sleep mode .
That mac seq is 76.
But When none sleep, it's normally increase by one.
The attachment is sniffer log.
lee
Labels (2)
mario_castaneda
Hi Lee,
Please print the pu8Payload[0]  value before you go to sleep. The sEndDeviceData.u8TxPacketSeqNb++ is increasing the sequence number.
Mario
wslee
Hi Mario,
I am using packets in my format. So, the pu8Payload[0] is always 0xaa.
My question is MAC Sequence.
Lee
wslee
Hi Mario,
How's it going?
Lee
mario_castaneda
Hi Lee,
You must modify the MAC_Pib_s structure before sending the data.
    uint8                       u8Dsn;/**< macDSN attribute */
} MAC_Pib_s;
mac_pib_CombinedMac.h
s_psMacPib->u8Dsn= count++;‍‍‍‍‍‍‍‍‍‍
Let me know your findings.
Mario
wslee
Hi Mario,
Thanks for your response.
I have tested, but the result is same. This mac seq is always 76.
The following is source code.
PRIVATE void vTransmitDataPacket(uint8 *pu8Data, uint8 u8Len, uint16 u16DestAdr)
   MAC_McpsReqRsp_s sMcpsReqRsp;
   MAC_McpsSyncCfm_s sMcpsSyncCfm;
   uint8 *pu8Payload, i = 0;
   PRIVATE u8 count;
   s_pvMac = pvAppApiGetMacHandle();
   s_psMacPib = MAC_psPibGetHandle(s_pvMac);
   s_psMacPib->u8Dsn = count++;
   /* Create frame transmission request */
   sMcpsReqRsp.u8Type = MAC_MCPS_REQ_DATA;
   sMcpsReqRsp.u8ParamLength = sizeof(MAC_McpsReqData_s);
   /* Set handle so we can match confirmation to request */
   sMcpsReqRsp.uParam.sReqData.u8Handle = 1;
   /* Use short address for source */
   sMcpsReqRsp.uParam.sReqData.sFrame.sSrcAddr.u8AddrMode = 2;
   sMcpsReqRsp.uParam.sReqData.sFrame.sSrcAddr.u16PanId = u16panid;
   sMcpsReqRsp.uParam.sReqData.sFrame.sSrcAddr.uAddr.u16Short = u16id;
   /* Use short address for destination */
   sMcpsReqRsp.uParam.sReqData.sFrame.sDstAddr.u8AddrMode = 2;
   sMcpsReqRsp.uParam.sReqData.sFrame.sDstAddr.u16PanId = u16panid;
   sMcpsReqRsp.uParam.sReqData.sFrame.sDstAddr.uAddr.u16Short = u16DestAdr;
   /* Frame requires ack but not security, indirect transmit or GTS */
   sMcpsReqRsp.uParam.sReqData.sFrame.u8TxOptions = 0;//MAC_TX_OPTION_ACK;
   pu8Payload = sMcpsReqRsp.uParam.sReqData.sFrame.au8Sdu;
   for (i = 0; i < (u8Len); i++)
      pu8Payload[i] = *pu8Data++;
   /* Set frame length */
   sMcpsReqRsp.uParam.sReqData.sFrame.u8SduLength = i;
   /* Request transmit */
   vAppApiMcpsRequest(&sMcpsReqRsp, &sMcpsSyncCfm);
Lee
mario_castaneda
Hi Lee,
You should add the code out of the vTransmitDataPacket and before of it.
 vTransmitDataPacket(&TxData,9,TagVstemp.u16coordShortAdr);
Please let me know your findings.
Mario
wslee
Hi Mario,
I don't know the difference between the codes.
Anyway, I have tested, but the result is same.
Does your code work?
Please send me some sample code.
Lee
mario_castaneda
Hi Lee Wonsoo,
How are you implementing the sleep mode?
 PRIVATE MAC_Pib_s *s_psMacPib;
 while (1)
        vProcessEventQueues();
        if(sEndDeviceData.eState == E_STATE_ASSOCIATED)
           DBG_vPrintf(TRUE,"s_psMacPib->u8Dsn 0%0d;\n",s_psMacPib->u8Dsn);
        if(sEndDeviceData.eState == E_STATE_TX_END)
Mario
wslee
Hi Mario.
I found the Issues in Makefile.
Before
CFLAGS += -DENABLE_OPT_IN_MAKE
CFLAGS += -DENABLE_OPT_RFD
After
#CFLAGS += -DENABLE_OPT_IN_MAKE
#CFLAGS += -DENABLE_OPT_RFD
I have changed for sleepy device but It was the wrong setting.
Thank you for your support.
Lee
