In which document can I find out about the static Power consumption per periphery for QN908x?
In particular the uA usage of WDT and BOR.
the following document doesnt contain it: "Ultra low power Bluetooth 5 system-on-chip solution Rev. 1.2"
Thank you,
解決済! 解決策の投稿を見る。
Sorry for the inconvenience this might cause you, but we only have for the BOR ~150pA into the pin at VDD (3V) and ~-200pA at VSS, the WDT is a digital IP, so we typically characterize the analog ones.
Estephania
Could you please check the QN9080 User Manual? I believe you will find some useful information in chapter 5 Power Management Unit (PMU)
Estephania
It also doesn't mention current consumption of BOD/WDT. Can NXP provide this information?
Cheers,
Let me check if we have the information available.
Estephania
I'm still looking if we have something available, hope to have an update something soon.
Estephania
Estephania
