QN9080 remove external XTAL osillator (16/32MHz) problem
wang_barry
     We used 9080 to develop our product.
     We try to remove external 32k & 32M crystal oscillator. (only use internal oscillator).
     But We can't program image through LPC-LINK2 or ISP when we remove 32M crystal oscillator.
     Question:
        1. Can we remove the 32M crystal oscillator without affecting MCU work normally.
        2. if yes,  any suggest for  program image program
Tags (2)
Ricardo_Zamora
Hope you are doing well. The internal 32M oscillator is only used to system startup, not intended for peripherals.
You need the external XTAL in your design.
Ricardo
Ricardo_Zamora
Ricardo
