QN9080-001-M17 (SIP) Module Gerber data
1,055件の閲覧回数
andrew_clifford
Hi, I am designing the QN9080-001-M17 (SIP) chip into a product and was hoping to see if Gerber data was available for the module used in the development kit. I just wanted to get a view of the clearance areas used for the Bluetooth antenna and surrounding board. I know that it is in the user manual, but the complete lack of description/explanation makes it a little tricky to follow!
I haven't been able to find it on the NXP site anywhere, but I may have missed it. Any hints?
Andrew
タグ(2)
4 返答(返信)
918件の閲覧回数
andrew_clifford
A quick follow-up: In my tralwing of the NXP website to try and find information, I came across the design file for the QN9080SIP-DK, which includes the gerber data for the QN9080SIP module. Perfect!
The files are here: https://www.nxp.com/downloads/en/design-support/QN9080SIP-DESIGNFILES.zip
I found the link by searching on the NXP site for "qn9080sipdk" (no spaces of dahses or anythign), which seemed to do the trick! I think i now have the information I need.
Thanks for your help Sebastian!
Cheers,
Andrew
918件の閲覧回数
Sebastian_Del_Rio
Hello Andrew, I hope you're doing well,
Thank you for your feedback, if you have any other questions, please let me know.
Sebastian
918件の閲覧回数
Sebastian_Del_Rio
The Bluetooth antenna in the QN9080SIP is contained inside the module, and you can find the footprint information, package outlines and measurements in this document. Could you please take a look at Figures 5 and 6, as those show some layout recommendations.
Sebastian
918件の閲覧回数
andrew_clifford
Hi Sebastian, thank you for your response.
Thank you for the link to the objective data sheet. i already had this document and used it for the pacakge footprint (figure 5), but was a bit bewildered by all of the different figures (figure 6 to 14) as there is very little description to go with them (e.g. which of the diufferen layouts is better, or are they all equivalent, etc.).
For example, if i want to use the sort of layout shown in Fig 8 to 10 (center edge layout), can I do this in the corner of the board, or do I have to draw the antenna as shown in Fig. 11 to 14?
