QN9080-001-M17-BLE-Cancel manual message sending
749件の閲覧回数
1758793535
    Every time 001-m17 sends data, you need to press "Ctrl + enter". Which function of "wireless—UART" does "Ctrl + enter" correspond to? How to remove this restriction?
2 返答(返信)
727件の閲覧回数
Ricardo_Zamora
The Wireless UART example expects to receive an ASCII char from Tera Term to send it Over the Air. In code, this is handled with CallBacks (Uart_RxCallBack, UartStreamFlushTimerCallback, BleApp_FlushUartStream).
The BleApp_FlushUartStream collects the data from the serial manager, and then, sends it Over the Air.
Hope this makes sense
Ricardo
715件の閲覧回数
1758793535
HI
If I press "Ctrl + enter" on the keyboard, the function circled in red will be executed.
Thank you!
