We are looking for a Eddystone-UID Beacon scanner code implementation for QN9080, is there an example application for that?
If not, which example application would you suggest to build upon and the recommended steps to follow?
Could you please check this post https://community.nxp.com/docs/DOC-329201 ?
I believe it works for you as you can find how to implement it there
Estephania
Also, please refer to this other post.
https://community.nxp.com/docs/DOC-341402
Estephania
