Below is the ASL_Node_Desc_req function from bee stack. (ASL_Zdpinterface.c)
void ASL_Node_Desc_req
zbCounter_t *pSequenceNumber,
zbNwkAddr_t aDestAddress
I cannot understand what the sequence number is, how it should be set and what it does. Can someone please enlighten me on this?
Mete
Hi Atilla
Please refer to "8.6 Device and service discovery – client services" chapter from the Software Reference Manual for ZigBee document, you should be able to locate it in the path <Kinetis_BeeStack_5.0.0_path>\doc. it is named as BSSRMZB2007.pdf
Hope this information helps you
Jorge Alcala
