I am trying to get the NFC card type using PNEV5180B kit and "NfcrdlibEx1_BasicDiscoveryLoop" example which is defined in "UM10954" ( PN5180 SW Quick start guide" document. I successfully programmed the kit but when I debug, I saw the code waits for the PN5180 IRQ flag forever. Even if I read the card this function does not return. We can see the function in the picture.
There should be no problem if you use PNEV5180B with NxpNfcReadlib. what card you are using?
