NFC and RFID
NFC and RFID
Lifehack
What is the Definition of NFC? What determines if a chip is an NFC chip or an "standard" RFID chip?
Is it for example linked to the protocol this chip is working on?
I know the functional difference between NFC and RFID and I know that NFC works on HF RFID (13.56 MHz) but what is the technical difference?
Fabian_R
Hello sir,
NFC is defined by an organization of members called the NFC Forum. If you please follow the next link this will give you a better understanding of the NFC definition and its protocol. https://nfc-forum.org/about-us/
As you said, NFC works on top of HF RFID. Please check the full explanation in the next link: https://nfc-forum.org/what-is-nfc/
Feel free to explore the full available information.
Fabian
Fabian_R
Hello sir,
Fabian
