NFC PN5180
NFC PN5180
liguangmingkaif
Does PN5180 support writing MAX66242 tag?Have you done any actual verification?
Jonathan_Iglesias
Dear 光明 李, I see that the tag you mention is ISO 15693  so you should be able to use the commands in the reader library since there is some APIs for ISO15693, since this is not an NXP products is hard for me to tell  or advice on this. my recommendation is that you check our reader library and check the commands .
NFC Reader Library | NXP
Jonathan
