The marked passage in the snippet of the JN51xx Core Utilities User Guide (JN-UG-3116) suggests that PDUM_eAPduInstanceSetPayloadSize does not need to be used if PDUM_u16APduInstanceWriteNBO or PDUM_u16APduInstanceWriteStrNBO are used to load data into the PDU. My own experience suggests that PDUM_eAPduInstanceSetPayloadSize MUST be used prior to sending the PDU.
Hi Peter,
Yes, you are right, PDUM_eAPduInstanceSetPayloadSize MUST be used prior to sending the PDU.
As you know the PDUM_u16APduInstanceWriteNBO writes the specified data values into the specified APDU instance., but also the user could create his function to allocate the specified position in packed network byte order.
Mario
