Hi, I have an application with MC13224 for Inertial Measurement Unit processing and transmission, so I didn't find any more MC13224 to continue with my development. Will be the MC13226 work as same as MC13224, by and large?. My development includes I2C, SPI and ZigBee Rx and Tx.
Hi Manuel
Unfortunatelly both the MC13224 and the MC13226 are no longer manufacturer, so is not a good option migrate to the MC13226 due this is no longer manufacturer.
I recommend that you check the following link
ARM Cortex-M0+/M4 Cores|Kinetis W MCUs|Freescale
also please check the fact sheet for the KW2x
I hope this will help you.
Vicente
Thanks for your answer, the fact is that I have already bougth 15 of MC13226, So I am not sure why it does not works properly as MC13224, I have some problems to program it.
Hello Manuel,
I'd recommend you to take a look into this document, section 1.1 to see the main differences between those radios: http://www.freescale.com/files/rf_if/doc/data_sheet/MC1322x.pdf
As Vicente commented, those radios are no longer manufactured and support is very limited.
