Matter Development Platform - Lighting-App on IOTZTB-DK006
1,624件の閲覧回数
seah
I tried the instructions from matter/examples/lighting-app/nxp/k32w/k32w0 at v1.2.0.1-tag-nxp · NXP/matter (github.com), and successfully built chip-k32w0x-light-example.bin.
I then flashed the DK6 board with command
C:\nxp\DK6Programmer> ./DK6Programmer.exe -s COM10 -p chip-k32w0x-light-example.bin
but the board UI LED does not correspond to the device UI as mentioned in the README file, and it looks like firmware is not running properly. Please advise.
タグ(3)
1,378件の閲覧回数
seah
Thanks for your advice. It is working after  I reset device to default state with SW2.
LED toggling command is working fine
root@imx8mmevk-matter:~# chip-tool onoff toggle 8888 1
11 返答(返信)
1,599件の閲覧回数
mihai_ignat
Hello.
Can you please detail the configuration used for the build? Did you use the standard command?
gn gen out/debug --args="chip_with_OM15082=1 chip_with_ot_cli=0 is_debug=false chip_crypto=\"platform\" chip_with_se05x=0 chip_pw_tokenizer_logging=true"
If so, looking at the DK6Programmer command you used, this is writing the binary at address 0x0. This is not compatible with the standard built application binary. You also need to write the SSBL binary, as explained in the OTA chapter.
You can find the binary in the SDK downloaded with west command, in path %matter_root%/third_party/nxp/k32w0_sdk/repo/core/boards/k32w061dk6/wireless_examples/framework/ssbl/binary/ssbl_ext_flash_pdm_support.bin.
You need to write this binary first to the board with command:
DK6Programmer.exe -V2 -s <COM_PORT> -P 1000000 -Y -p FLASH@0x00="k32w061dk6_ssbl.bin"
Then you can write the application binary using the following command:
DK6Programmer.exe -V2 -s <COM_PORT> -P 1000000 -Y -p FLASH@0x4000="chip-k32w0x-light-example.bin"
The standard build command uses a Pigweed tokenizer to compress debug strings and save flash space so in order to validate that the application runs correctly, you need to call:
python3 ../../../../../examples/platform/nxp/k32w/k32w0/scripts/detokenizer.py serial -i /dev/ttyUSB0 -d out/debug/chip-k32w0x-light-example-database.bin -o device.txt
Please let me know if this works.
BR,
Mihai
1,523件の閲覧回数
seah
Hello Mihai,
Thanks for suggestions to write SSBL binary.
I try again with following steps, according to ducument K32W0X1-MATTER-QSG.pdf (nxp.com)
PS C:\nxp\DK6Programmer> .\DK6Programmer.exe -V2 -s COM10 -P 1000000 -e flash
PS C:\nxp\DK6Programmer> .\DK6Programmer.exe -V2 -s COM10 -P 1000000 -Y -p FLASH@0x00="ssbl_ext_flash_pdm_support.bin"
PS C:\nxp\DK6Programmer> .\DK6Programmer.exe -V5 -s COM10 -P 1000000 -w image_dir_0=0000000010000000
PS C:\nxp\DK6Programmer> .\DK6Programmer.exe -V5 -s COM10 -P 1000000 -w image_dir_1=00400000C9040101
PS C:\nxp\DK6Programmer> .\DK6Programmer.exe -V2 -s COM10 -P 1000000 -Y -p FLASH@0x4000="chip-k32w0x-light-example.bin"
 And I can see that the board is now having the right device UI with LED D2 flashing with Short Flash On (50ms on/950ms off)
1,510件の閲覧回数
mihai_ignat
Hello.
Glad to hear that it worked.
We recommend following the READMEs for the desired application from the Matter NXP Github as it contains all the updated information for building and running the examples. The Matter QSG is out of date, being based on Matter 1.0 release and we do not recommend using it at this point. We are planning to update the documentation to the latest version.
BR,
Mihai
1,490件の閲覧回数
seah
I continue to setup the demo according to instructions at meta-nxp-connectivity/docs/guides/nxp_mpu_matter_demos.md at master · nxp-imx/meta-nxp-connectivity ...
i.MX8M MINI EVK is loaded with demo image from NXP named imx-matter_2023-q4_imx8mmevk-matter.zip
Two files were setup at home directory as below
root@imx8mmevk-matter:~# ls
setup-border-router.sh  wifiap.conf
The file wifiap.conf is edited with the ssid and psk of my network using the tool 'wpa_passphrase'
Content of 'setup-border-router.sh'
#!/bin/sh
modprobe moal mod_para=nxp/wifi_mod_para.conf
wpa_supplicant -d -B -i mlan0 -c /home/root/wifiap.conf
udhcpc -i mlan0
echo "nameserver 8.8.8.8" > /etc/resolv.conf
service otbr_fwcfg start
modprobe btnxpuart
hciconfig hci0 up
#thread
otbr-agent -I wpan0 -B mlan0 'spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=1000
000' &
iptables -A FORWARD -i mlan0 -o wpan0 -j ACCEPT
iptables -A FORWARD -i wpan0 -o mlan0 -j ACCEPT
otbr-web &
#form openthread network
ot-ctl dataset init new
ot-ctl dataset commit active
ot-ctl ifconfig up
ot-ctl thread start
Execute the script above with the following output:
[ 403.593466] mlan: loading out-of-tree module taints kernel.
[ 403.622728] wlan: Loading MWLAN driver
[ 403.627382] wlan: Register to Bus Driver...
[ 403.631922] vendor=0x02DF device=0x9149 class=0 function=1
[ 403.637742] Attach moal handle ops, card interface type: 0x105
[ 403.643627] rps set to 0 from module param
[ 403.649513] SD8987: init module param from usr cfg
[ 403.654351] card_type: SD8987, config block: 0
[ 403.658823] cfg80211_wext=0xf
[ 403.661801] max_vir_bss=1
[ 403.664435] cal_data_cfg=none
[ 403.667411] ps_mode = 1
[ 403.669856] auto_ds = 1
[ 403.672316] host_mlme=enable
[ 403.675207] fw_name=nxp/sdiouart8987_combo_v0.bin
[ 403.679942] SDIO: max_segs=128 max_seg_size=65535
[ 403.684656] rx_work=1 cpu_num=4
[ 403.687814] Enable moal_recv_amsdu_packet
[ 403.691896] Attach mlan adapter operations.card_type is 0x105.
[ 403.698114] wlan: Enable TX SG mode
[ 403.701626] wlan: Enable RX SG mode
[ 403.707131] Request firmware: nxp/sdiouart8987_combo_v0.bin
[ 403.967979] Wlan: FW download over, firmwarelen=617588 downloaded 617588
[ 404.836431] WLAN FW is active
[ 404.839432] on_time is 404832405625
[ 404.899811] FW country code WW does not match with US
[ 404.905091] fw_cap_info=0x181d7f03, dev_cap_mask=0xffffffff
[ 404.910699] max_p2p_conn = 8, max_sta_conn = 8
[ 404.927653] Register NXP 802.11 Adapter mlan0
[ 404.936702] Register NXP 802.11 Adapter uap0
[ 404.944718] Register NXP 802.11 Adapter wfd0
[ 404.949477] wlan: version = SD8987----16.92.21.p99.2-MM6X16423.p6-GPL-(FP92)
[ 404.958613] wlan: Register to Bus Driver Done
[ 404.960128] pwm-backlight backlight: supply power not found, using dummy regulator
[ 404.963507] wlan: Driver loaded successfully
wpa_supplicant v2.10
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'mlan0' conf '/home/root/wifiap.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/home/root/wifiap.conf' -> '/home/root/wifiap.conf'
Reading configuration file '/home/root/wifiap.conf'
Priority group 0
id=0 ssid='Xiaomi_59F8'
id=1 ssid='VEST-WH-TEST'
nl80211: TDLS supported
nl80211: TDLS external setup
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-14-72:1
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported cipher 00-0f-ac:11
nl80211: Supported cipher 00-0f-ac:12
nl80211: Supported cipher 00-0f-ac:8
nl80211: Supported cipher 00-0f-ac:9
nl80211: Supported cipher 00-0f-ac:10
nl80211: Supports Probe Response offload in AP mode
nl80211: Using driver-based off-channel TX
nl80211: TDLS channel switch
nl80211: Driver-advertised extended capabilities (default) - hexdump(len=11): 00 00 00 00 21 00 00 40 00 00 00
nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=11): 00 00 00 00 21 00 00 40 00 00 00
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=0
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4105
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=7
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=8
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=9
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4608
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4609
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4610
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5376
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=2
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5888
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5889
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5890
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=3
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4352
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4353
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4354
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4355
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4356
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4357
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4358
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4359
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=256
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5126
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5124
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4106
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=4109
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5121
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5123
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5120
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5122
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5128
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5125
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=5127
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=17
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=18
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=6400
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=6401
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=6402
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=6403
nl80211: Supported vendor command: vendor_id=0x5043 subcmd=6404
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=0
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=1
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=2
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=3
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=4
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=5377
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65537
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65538
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65539
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65540
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65541
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65542
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65543
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65544
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65547
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65548
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65549
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=65550
nl80211: Supported vendor event: vendor_id=0x5043 subcmd=7
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: key_mgmt=0x1ff0f enc=0x7ef auth=0x7 flags=0x1000c008d7fbfae0 rrm_flags=0x38 probe_resp_offloads=0x0 max_stations=8 max_remain_on_chan=5000 max_scan_ssids=10
nl80211: interface mlan0 in phy mwiphy0
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0xaaaae58cf480
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0104 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=040a multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=040b multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=040c multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=040d multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=090a multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=090b multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=090c multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=090d multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0409506f9a09 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=7f506f9a09 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0409506f9a1a multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0800 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0801 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=040e multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=06 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0a07 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0a11 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0a0b multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0a1a multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=1101 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=1102 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0505 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0500 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=0502 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=1301 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=1305 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae58cf480 match=7e506f9a1a multicast=0
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
Add interface mlan0 to a new radio mwiphy0
nl80211: Regulatory information - country=00
nl80211: 755-928 @ 2 MHz 20 mBm (no IR)
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[N[ 405.854035] wlan: mlan0 START SCAN
O_IR] 2472[NO_IR] 2484[NO_IR]
nl80211: Mode IEEE 802.11a: 5180[NO_IR] 5200[NO_IR] 5220[NO_IR] 5240[NO_IR] 5260[NO_IR][RADAR] 5280[NO_IR][RADAR] 5300[NO_IR][RADAR] 5320[NO_IR][RADAR] 5500[NO_IR][RADAR] 5520[NO_IR][RADAR] 5540[NO_IR][RADAR]
nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467[NO_IR] 2472[NO_IR] 2484[NO_IR]
mlan0: Own MAC address: e8:fb:1c:b9:7b:53
wpa_driver_nl80211_set_key: ifindex=3 (mlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
nl80211: DEL_KEY
broadcast key
wpa_driver_nl80211_set_key: ifindex=3 (mlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
nl80211: DEL_KEY
broadcast key
wpa_driver_nl80211_set_key: ifindex=3 (mlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
nl80211: DEL_KEY
broadcast key
wpa_driver_nl80211_set_key: ifindex=3 (mlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
nl80211: DEL_KEY
broadcast key
wpa_driver_nl80211_set_key: ifindex=3 (mlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
nl80211: DEL_KEY
broadcast key
wpa_driver_nl80211_set_key: ifindex=3 (mlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0 key_flag=0x10
nl80211: DEL_KEY
broadcast key
mlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
TDLS: TDLS operation supported by driver
TDLS: Driver uses external link setup
TDLS: Driver supports TDLS channel switching
mlan0: WPS: UUID based on MAC address: 34aa9ae1-09bf-57a8-8e27-e39ac7b2d004
ENGINE: Loading builtin engines
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
P2P: Add operating class 81
P2P: Channels - hexdump(len=11): 01 02 03 04 05 06 07 08 09 0a 0b
P2P: Own listen channel: 81:1
P2P: Random operating channel: 81:6
P2P: initialized
P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11
P2P: cli_channels:
MBO: Update non-preferred channels, non_pref_chan=N/A
mlan0: Added interface mlan0
mlan0: State: DISCONNECTED -> DISCONNECTED
nl80211: Set mlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Daemonize..
udhcpc: started, v1.36.1
Dropped protocol specifier '.udhcpc' from 'mlan0.udhcpc'. Using 'mlan0' (ifindex=3).
udhcpc: broadcasting discover
[ 410.480074] wlan: SCAN COMPLETED: scanned AP count=38
[ 410.501132] wlan: HostMlme mlan0 send auth to bssid dc:XX:XX:XX:4a:e9
[ 410.513502] mlan0:
[ 410.513513] wlan: HostMlme Auth received from dc:XX:XX:XX:4a:e9
[ 410.526577] CMD_RESP: cmd 0x121 error, result=0x2
[ 410.531321] IOCTL failed: 000000003dab2c7e id=0x200000, sub_id=0x200024 action=2, status_code=0x3
[ 410.540495] Get multi-channel policy failed
[ 410.566621] wlan: HostMlme mlan0 Connected to bssid dc:XX:XX:XX:4a:e9 successfully
[ 410.577907] mlan0:
[ 410.577922] wlan: Send EAPOL pkt to dc:XX:XX:XX:4a:e9
[ 410.593560] mlan0:
[ 410.593573] wlan: Send EAPOL pkt to dc:XX:XX:XX:4a:e9
[ 410.607966] IPv6: ADDRCONF(NETDEV_CHANGE): mlan0: link becomes ready
[ 410.616141] woal_cfg80211_set_rekey_data return: gtk_rekey_offload is DISABLE
udhcpc: broadcasting select for 10.99.99.9, server 192.168.11.101
udhcpc: lease of 10.99.99.9 obtained from 192.168.11.101, lease time 691200
/etc/udhcpc.d/50default: Adding DNS 8.8.8.8
/etc/udhcpc.d/50default: Adding DNS 165.21.83.88
[ 413.926974] pwm-backlight backlight: supply power not found, using dummy regulator
[ 413.956096] audit: type=1325 audit(1716486753.172:25): table=filter:9 family=10 entries=1 op=nft_register_rule pid=701 comm="ip6tables"
[ 413.968722] audit: type=1300 audit(1716486753.172:25): arch=c00000b7 syscall=211 success=yes exit=320 a0=3 a1=ffffdead88c0 a2=0 a3=1 items=0 ppid=690 pid=701 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/sbin/xtables-nft-multi" key=(null)
[ 413.997713] audit: type=1327 audit(1716486753.172:25): proctitle=6970367461626C6573002D4900464F52574152440031002D6F007770616E30002D6A004F5442525F464F52574152445F494E4752455353
[ 414.013522] audit: type=1325 audit(1716486753.172:26): table=filter:10 family=10 entries=1 op=nft_register_rule pid=703 comm="ip6tables"
[ 414.025864] audit: type=1300 audit(1716486753.172:26): arch=c00000b7 syscall=211 success=yes exit=360 a0=3 a1=ffffd9d168a0 a2=0 a3=1 items=0 ppid=690 pid=703 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/sbin/xtables-nft-multi" key=(null)
[ 414.053897] audit: type=1327 audit(1716486753.172:26): proctitle=6970367461626C6573002D41004F5442525F464F52574152445F494E4752455353002D6D00706B7474797065002D2D706B742D7479706500756E6963617374002D69007770616E30002D6A0044524F50
[ 414.073998] audit: type=1325 audit(1716486753.188:27): table=filter:11 family=10 entries=1 op=nft_register_rule pid=707 comm="ip6tables"
[ 414.086336] audit: type=1300 audit(1716486753.188:27): arch=c00000b7 syscall=211 success=yes exit=312 a0=3 a1=fffffeb95e10 a2=0 a3=1 items=0 ppid=690 pid=707 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables" exe="/usr/sbin/xtables-nft-multi" key=(null)
[ 414.114380] audit: type=1327 audit(1716486753.188:27): proctitle=6970367461626C6573002D41004F5442525F464F52574152445F494E4752455353002D6D00736574002D2D6D617463682D736574006F7462722D696E67726573732D64656E792D73726300737263002D6A0044524F50
[ 414.135462] audit: type=1325 audit(1716486753.188:28): table=filter:12 family=10 entries=1 op=nft_register_rule pid=708 comm="ip6tables"
[ 415.306589] Bluetooth: MGMT ver 1.22
[ 415.367318] NET: Registered PF_ALG protocol family
connect session failed: No such file or directory
root@imx8mmevk-matter:~# otbr-web[719]: [INFO]-WEB-----: Running 0.3.0-thread-reference-20230710-8-gff1b012505
interfaceName not specified, using default wpan0
listenAddr not specified, using default ::
http port not specified, using default 80
otbr-web[719]: [INFO]-WEB-----: Border router web started on wpan0
otbr-web[719]: [ERR ]-WEB-----: OpenThread daemon is not running.
Take note of the errors
1. connect session failed: No such file or directory
2. OpenThread daemon is not running
Get Thread network credentials:
root@imx8mmevk-matter:~# ot-ctl dataset active -x
0e08000000000001000035060004001fffe00708fd457e7b5b4fa1030c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234
Done
commissioning
$ chip-tool pairing ble-thread 8888 hex:0e08000000000001000035060004001fffe00708fd457e7b5b4fa1030c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234 20202021 3840
the output is:
[1716487179.371187][778:778] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_tool_kvs
[1716487179.371354][778:778] CHIP:DL: writing settings to file (/tmp/chip_tool_kvs-yJCaqk)
[1716487179.371413][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_tool_kvs)
[1716487179.372139][778:778] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1716487179.372169][778:778] CHIP:DL: ChipLinuxStorage::Init: Attempt to re-initialize with KVS config file: /tmp/chip_kvs
[1716487179.378552][778:778] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1716487179.378723][778:778] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-DDSqqN)
[1716487179.378791][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1716487179.378844][778:778] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1716487179.378885][778:778] CHIP:DL: writing settings to file (/tmp/chip_config.ini-Lx3hLd)
[1716487179.378916][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
[1716487179.378945][778:778] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1716487179.378983][778:778] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-1h8Pyr)
[1716487179.379014][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1716487179.380618][778:778] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-cCahZX)
[1716487179.380742][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1716487179.380764][778:778] CHIP:DL: NVS set: chip-factory/unique-id = "D758EFC25AAE7E50"
[1716487179.380833][778:778] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-UbfDwK)
[1716487179.380909][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1716487179.380925][778:778] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
[1716487179.380968][778:778] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-gjnGtr)
[1716487179.381029][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1716487179.381044][778:778] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
[1716487179.381089][778:778] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-elB0qr)
[1716487179.381140][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1716487179.381154][778:778] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
[1716487179.381202][778:778] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-NGX97g)
[1716487179.381265][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1716487179.381280][778:778] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1716487179.381347][778:778] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-CqQmpr)
[1716487179.381407][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1716487179.381422][778:778] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
[1716487179.381459][778:778] CHIP:DL: writing settings to file (/tmp/chip_config.ini-0ntExs)
[1716487179.381509][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
[1716487179.381524][778:778] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
[1716487179.381569][778:778] CHIP:DL: writing settings to file (/tmp/chip_config.ini-q8Wsuf)
[1716487179.381625][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
[1716487179.381640][778:778] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
[1716487179.382337][778:778] CHIP:DL: Failed to get Ethernet interface
[1716487179.382797][778:778] CHIP:DL: Failed to reset Ethernet statistic counts
[1716487179.382993][778:778] CHIP:DL: Got WiFi interface: mlan0
[1716487179.384141][778:778] CHIP:DL: Found the primary WiFi interface:mlan0
[1716487179.385016][778:778] CHIP:IN: UDP::Init bind&listen port=0
[1716487179.385108][778:778] CHIP:IN: UDP::Init bound to port=42775
[1716487179.385122][778:778] CHIP:IN: UDP::Init bind&listen port=0
[1716487179.385163][778:778] CHIP:IN: UDP::Init bound to port=55935
[1716487179.385175][778:778] CHIP:IN: BLEBase::Init - setting/overriding transport
[1716487179.385184][778:778] CHIP:IN: TransportMgr initialized
[1716487179.385214][778:778] CHIP:FP: Initializing FabricTable from persistent storage
[1716487179.719971][778:778] CHIP:TS: Last Known Good Time: [unknown]
[1716487179.720017][778:778] CHIP:TS: Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48
[1716487179.720777][778:778] CHIP:ZCL: Using ZAP configuration...
[1716487179.723395][778:778] CHIP:CTL: System State Initialized...
[1716487179.725996][778:778] CHIP:CTL: Setting attestation nonce to random value
[1716487179.726071][778:778] CHIP:CTL: Setting CSR nonce to random value
[1716487179.726630][778:778] CHIP:IN: UDP::Init bind&listen port=5550
[1716487179.726716][778:778] CHIP:IN: UDP::Init bound to port=5550
[1716487179.726732][778:778] CHIP:IN: UDP::Init bind&listen port=5550
[1716487179.726780][778:778] CHIP:IN: UDP::Init bound to port=5550
[1716487179.726792][778:778] CHIP:IN: TransportMgr initialized
[1716487179.727073][778:781] CHIP:DL: CHIP task running
[1716487179.727161][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1716487179.727575][778:781] CHIP:CTL: Setting attestation nonce to random value
[1716487179.727724][778:781] CHIP:CTL: Setting CSR nonce to random value
[1716487179.727809][778:781] CHIP:CTL: Couldn't get ExampleOpCredsCAKey from storage: /usr/src/debug/matter/1.0-r0/src/controller/ExamplePersistentStorage.cpp:106: CHIP Error 0x000000A0: Value not found in the persisted storage
[1716487179.729202][778:781] CHIP:CTL: Couldn't get ExampleOpCredsICAKey from storage: /usr/src/debug/matter/1.0-r0/src/controller/ExamplePersistentStorage.cpp:106: CHIP Error 0x000000A0: Value not found in the persisted storage
[1716487179.730114][778:781] CHIP:CTL: Generating RCAC
[1716487179.732584][778:781] CHIP:CTL: Generating ICAC
[1716487179.733232][778:781] CHIP:CTL: Generating NOC
[1716487179.734989][778:781] CHIP:FP: Validating NOC chain
[1716487179.738181][778:781] CHIP:FP: NOC chain validation successful
[1716487179.739321][778:781] CHIP:FP: Added new fabric at index: 0x1
[1716487179.739347][778:781] CHIP:FP: Assigned compressed fabric ID: 0x3263B3F30220D214, node ID: 0x000000000001B669
[1716487179.739367][778:781] CHIP:TS: Last Known Good Time: 2023-10-14T01:16:48
[1716487179.739379][778:781] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1716487179.739389][778:781] CHIP:TS: Retaining current Last Known Good Time
[1716487179.741076][778:781] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1716487179.741533][778:781] CHIP:TS: Committing Last Known Good Time to storage: 2023-10-14T01:16:48
[1716487179.741936][778:781] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 3263B3F30220D214)
[1716487179.741967][778:781] CHIP:IN: UDP::Init bind&listen port=5550
[1716487179.742043][778:781] CHIP:IN: UDP::Init bound to port=5550
[1716487179.742057][778:781] CHIP:IN: UDP::Init bind&listen port=5550
[1716487179.742103][778:781] CHIP:IN: UDP::Init bound to port=5550
[1716487179.742114][778:781] CHIP:IN: TransportMgr initialized
[1716487179.756895][778:781] CHIP:CTL: Setting thread operational dataset from parameters
[1716487179.756941][778:781] CHIP:CTL: Setting attestation nonce to random value
[1716487179.756989][778:781] CHIP:CTL: Setting CSR nonce to random value
[1716487179.757012][778:781] CHIP:CTL: Commission called for node ID 0x00000000000022B8
[1716487179.770255][778:780] CHIP:DL: TRACE: Bus acquired for name C-030a
[1716487179.784142][778:781] CHIP:DL: PlatformBlueZInit init success
[1716487179.795344][778:780] CHIP:BLE: BLE removing known devices.
[1716487179.799222][778:780] CHIP:BLE: BLE initiating scan.
[1716487179.810764][778:780] CHIP:BLE: Device 67:98:32:1F:6C:3B does not look like a CHIP device.
[1716487179.813953][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487179.815757][778:780] CHIP:BLE: Device 4D:4F:4D:D1:78:E8 does not look like a CHIP device.
[1716487179.830116][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487179.855742][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487179.873372][778:780] CHIP:BLE: Device 2B:4F:EB:A9:D8:FC does not look like a CHIP device.
[1716487179.889453][778:780] CHIP:BLE: Device 5B:01:33:B7:F7:71 does not look like a CHIP device.
[1716487179.891125][778:780] CHIP:BLE: Device 6B:0A:F9:F2:3B:EF does not look like a CHIP device.
[1716487179.897644][778:780] CHIP:BLE: Device 27:99:12:03:C2:D8 does not look like a CHIP device.
[1716487179.933992][778:780] CHIP:BLE: Device 7E:2E:C1:0F:62:B4 does not look like a CHIP device.
[1716487179.934568][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487179.937847][778:780] CHIP:BLE: Device 7D:33:C0:E3:FC:6B does not look like a CHIP device.
[1716487179.996088][778:780] CHIP:BLE: Device 5B:F2:4C:98:33:E5 does not look like a CHIP device.
[1716487179.998052][778:780] CHIP:BLE: Device F3:FF:55:1F:08:A6 does not look like a CHIP device.
[1716487179.999739][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487180.009627][778:780] CHIP:BLE: Device FA:99:46:A5:2A:77 does not look like a CHIP device.
[1716487180.010848][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487180.049299][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487180.051523][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487180.053831][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487180.057432][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487180.058888][778:780] CHIP:BLE: Device 49:0E:11:99:99:C4 does not look like a CHIP device.
[1716487180.068662][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487180.077100][778:780] CHIP:BLE: Device 33:A7:B4:11:B7:F1 does not look like a CHIP device.
[1716487180.089901][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487180.115700][778:780] CHIP:BLE: Device 42:4B:01:F2:78:D9 does not look like a CHIP device.
[1716487180.117554][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487180.126823][778:780] CHIP:BLE: Device 4D:4F:4D:D1:78:E8 does not look like a CHIP device.
[1716487180.132047][778:780] CHIP:BLE: Device 0D:26:6D:FD:31:4D does not look like a CHIP device.
[1716487180.132289][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487180.136434][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487180.169846][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487180.174758][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487180.187581][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487180.197001][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487180.210253][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487180.231712][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487180.233914][778:780] CHIP:BLE: Device 5B:F2:4C:98:33:E5 does not look like a CHIP device.
[1716487180.235860][778:780] CHIP:BLE: Device 4D:4F:4D:D1:78:E8 does not look like a CHIP device.
[1716487180.258687][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487180.260641][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487180.269018][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487180.291796][778:780] CHIP:BLE: Device 78:99:06:5F:07:B7 does not look like a CHIP device.
[1716487180.296182][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487180.308280][778:780] CHIP:BLE: Device 7D:33:C0:E3:FC:6B does not look like a CHIP device.
[1716487180.315312][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487180.331607][778:780] CHIP:BLE: Device 2A:60:97:D7:08:D7 does not look like a CHIP device.
[1716487180.351438][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487180.355851][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487180.370438][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487180.412434][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487180.412772][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487180.429996][778:780] CHIP:BLE: Device 3D:25:7E:51:C1:71 does not look like a CHIP device.
[1716487180.432046][778:780] CHIP:BLE: Device 69:6A:1C:29:F4:FC does not look like a CHIP device.
[1716487180.471892][778:780] CHIP:BLE: Device CB:CA:E0:46:14:7D does not look like a CHIP device.
[1716487180.473582][778:780] CHIP:BLE: Device 6D:2C:F5:57:D9:1D does not look like a CHIP device.
[1716487180.473799][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487180.475423][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487180.507893][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487180.528999][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487180.534083][778:780] CHIP:BLE: Device 07:64:44:BE:AD:DF does not look like a CHIP device.
[1716487180.534416][778:780] CHIP:BLE: Device 27:99:12:03:C2:D8 does not look like a CHIP device.
[1716487180.536760][778:780] CHIP:BLE: Device 2A:60:97:D7:08:D7 does not look like a CHIP device.
[1716487180.556636][778:780] CHIP:BLE: Device 5A:FA:79:EA:9D:0C does not look like a CHIP device.
[1716487180.556878][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487180.574365][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487180.576266][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487180.598225][778:780] CHIP:BLE: Device 79:9E:9C:49:35:FD does not look like a CHIP device.
[1716487180.609649][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487180.627882][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487180.631457][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487180.631835][778:780] CHIP:BLE: Device 67:98:32:1F:6C:3B does not look like a CHIP device.
[1716487180.635525][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487180.669614][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487180.671566][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487180.688089][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487180.707991][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487180.712864][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487180.716670][778:780] CHIP:BLE: Device 76:9D:81:1C:13:8A does not look like a CHIP device.
[1716487180.718166][778:780] CHIP:BLE: Device 4C:DC:B5:3C:BA:77 does not look like a CHIP device.
[1716487180.731029][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487180.752793][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487180.753562][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487180.757525][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487180.772948][778:780] CHIP:BLE: Device 6A:BE:9D:B1:37:8B does not look like a CHIP device.
[1716487180.787896][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487180.795617][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487180.811652][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487180.827960][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487180.832988][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487180.890332][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487180.891782][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487180.893587][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487180.894930][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487180.896570][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487180.912971][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487180.953518][778:780] CHIP:BLE: Device 79:C8:86:1A:89:87 does not look like a CHIP device.
[1716487180.954036][778:780] CHIP:BLE: Device 07:64:44:BE:AD:DF does not look like a CHIP device.
[1716487180.956059][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487180.957768][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487180.969667][778:780] CHIP:BLE: Device D7:5C:21:37:85:99 does not look like a CHIP device.
[1716487180.969947][778:780] CHIP:BLE: Device 2B:4F:EB:A9:D8:FC does not look like a CHIP device.
[1716487180.972281][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487180.977286][778:780] CHIP:BLE: Device 26:75:A2:97:67:5E does not look like a CHIP device.
[1716487180.977505][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487181.014504][778:780] CHIP:BLE: Device 4C:DC:B5:3C:BA:77 does not look like a CHIP device.
[1716487181.016480][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487181.033983][778:780] CHIP:BLE: Device 7E:2E:C1:0F:62:B4 does not look like a CHIP device.
[1716487181.037766][778:780] CHIP:BLE: Device 52:6F:8D:A6:B3:3E does not look like a CHIP device.
[1716487181.037982][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487181.050441][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487181.052485][778:780] CHIP:BLE: Device 27:99:12:03:C2:D8 does not look like a CHIP device.
[1716487181.076202][778:780] CHIP:BLE: Device 5B:F2:4C:98:33:E5 does not look like a CHIP device.
[1716487181.078140][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487181.089022][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487181.090996][778:780] CHIP:BLE: Device 76:9D:81:1C:13:8A does not look like a CHIP device.
[1716487181.113024][778:780] CHIP:BLE: Device C4:AC:59:41:A2:00 does not look like a CHIP device.
[1716487181.131387][778:780] CHIP:BLE: Device 5A:FA:79:EA:9D:0C does not look like a CHIP device.
[1716487181.133514][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487181.152536][778:780] CHIP:BLE: Device 32:3E:F2:6F:55:89 does not look like a CHIP device.
[1716487181.156772][778:780] CHIP:BLE: Device 49:B7:B1:A6:6E:D2 does not look like a CHIP device.
[1716487181.168618][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487181.170552][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487181.193654][778:780] CHIP:BLE: Device DA:69:D2:72:B1:09 does not look like a CHIP device.
[1716487181.194216][778:780] CHIP:BLE: Device 79:C8:86:1A:89:87 does not look like a CHIP device.
[1716487181.196118][778:780] CHIP:BLE: Device 4D:4F:4D:D1:78:E8 does not look like a CHIP device.
[1716487181.210175][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487181.228472][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487181.232796][778:780] CHIP:BLE: Device 7D:33:C0:E3:FC:6B does not look like a CHIP device.
[1716487181.234640][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487181.249244][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487181.255490][778:780] CHIP:BLE: Device 69:6A:1C:29:F4:FC does not look like a CHIP device.
[1716487181.268559][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487181.270562][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487181.276359][778:780] CHIP:BLE: Device 43:53:A4:A7:17:2B does not look like a CHIP device.
[1716487181.277034][778:780] CHIP:BLE: Device 07:64:44:BE:AD:DF does not look like a CHIP device.
[1716487181.292103][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487181.296129][778:780] CHIP:BLE: Device 6D:2C:F5:57:D9:1D does not look like a CHIP device.
[1716487181.310613][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487181.312914][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487181.314785][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487181.316863][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487181.332432][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487181.352894][778:780] CHIP:BLE: Device 67:65:44:CA:DD:54 does not look like a CHIP device.
[1716487181.353577][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487181.355726][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487181.357079][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487181.371097][778:780] CHIP:BLE: Device 25:4F:45:10:59:B6 does not look like a CHIP device.
[1716487181.371420][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487181.374850][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487181.376777][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487181.393646][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487181.408764][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487181.411702][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487181.452661][778:780] CHIP:BLE: Device 63:F7:C5:17:A0:37 does not look like a CHIP device.
[1716487181.467814][778:780] CHIP:BLE: Device 79:C8:86:1A:89:87 does not look like a CHIP device.
[1716487181.473167][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487181.475610][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487181.477495][778:780] CHIP:BLE: Device 25:4F:45:10:59:B6 does not look like a CHIP device.
[1716487181.479561][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487181.487329][778:780] CHIP:BLE: Device 5A:FA:79:EA:9D:0C does not look like a CHIP device.
[1716487181.492048][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487181.509840][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487181.512032][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487181.513518][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487181.528246][778:780] CHIP:BLE: Device 69:6A:1C:29:F4:FC does not look like a CHIP device.
[1716487181.536639][778:780] CHIP:BLE: Device E6:A6:02:5F:0D:8F does not look like a CHIP device.
[1716487181.537113][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487181.538571][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487181.571564][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487181.573576][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487181.588477][778:780] CHIP:BLE: Device 3D:25:7E:51:C1:71 does not look like a CHIP device.
[1716487181.590597][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487181.592653][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487181.609868][778:780] CHIP:BLE: Device 5B:F2:4C:98:33:E5 does not look like a CHIP device.
[1716487181.612166][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487181.613954][778:780] CHIP:BLE: Device 7D:33:C0:E3:FC:6B does not look like a CHIP device.
[1716487181.617722][778:780] CHIP:BLE: Device EC:BC:B1:EC:95:F5 does not look like a CHIP device.
[1716487181.617925][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487181.627613][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487181.628993][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487181.648176][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487181.654874][778:780] CHIP:BLE: Device 76:9D:81:1C:13:8A does not look like a CHIP device.
[1716487181.656933][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487181.675555][778:780] CHIP:BLE: Device 2D:F2:9D:5B:E9:66 does not look like a CHIP device.
[1716487181.690099][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487181.695563][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487181.714866][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487181.729745][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487181.732824][778:780] CHIP:BLE: Device 67:98:32:1F:6C:3B does not look like a CHIP device.
[1716487181.734817][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487181.757962][778:780] CHIP:BLE: Device 58:51:26:77:0C:E7 does not look like a CHIP device.
[1716487181.776438][778:780] CHIP:BLE: Device 52:6F:8D:A6:B3:3E does not look like a CHIP device.
[1716487181.778428][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487181.789015][778:780] CHIP:BLE: Device 25:4F:45:10:59:B6 does not look like a CHIP device.
[1716487181.790577][778:780] CHIP:BLE: Device 5B:01:33:B7:F7:71 does not look like a CHIP device.
[1716487181.792419][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487181.793935][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487181.795591][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487181.797363][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487181.813017][778:780] CHIP:BLE: Device 78:56:E7:8B:57:79 does not look like a CHIP device.
[1716487181.830788][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487181.836378][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487181.848168][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487181.875759][778:780] CHIP:BLE: Device 7E:2E:C1:0F:62:B4 does not look like a CHIP device.
[1716487181.896275][778:780] CHIP:BLE: Device 7E:6D:71:E1:B0:33 does not look like a CHIP device.
[1716487181.896922][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487181.898860][778:780] CHIP:BLE: Device 2A:60:97:D7:08:D7 does not look like a CHIP device.
[1716487181.909933][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487181.911520][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487181.913491][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487181.915180][778:780] CHIP:BLE: Device 79:9E:9C:49:35:FD does not look like a CHIP device.
[1716487181.928734][778:780] CHIP:BLE: Device 26:75:A2:97:67:5E does not look like a CHIP device.
[1716487181.933062][778:780] CHIP:BLE: Device CC:67:D5:46:BB:CC does not look like a CHIP device.
[1716487181.933525][778:780] CHIP:BLE: Device 78:99:06:5F:07:B7 does not look like a CHIP device.
[1716487181.953879][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487181.968348][778:780] CHIP:BLE: Device 52:6F:8D:A6:B3:3E does not look like a CHIP device.
[1716487181.970353][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487181.974353][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487181.988732][778:780] CHIP:BLE: Device 49:0E:11:99:99:C4 does not look like a CHIP device.
[1716487182.027692][778:780] CHIP:BLE: Device 4D:4F:4D:D1:78:E8 does not look like a CHIP device.
[1716487182.048405][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487182.050491][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487182.068746][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487182.070861][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487182.073072][778:780] CHIP:BLE: Device 2B:4F:EB:A9:D8:FC does not look like a CHIP device.
[1716487182.075120][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487182.090250][778:780] CHIP:BLE: Device 43:53:A4:A7:17:2B does not look like a CHIP device.
[1716487182.092386][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487182.094484][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487182.110387][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487182.112432][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487182.116393][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487182.130421][778:780] CHIP:BLE: Device 52:6F:8D:A6:B3:3E does not look like a CHIP device.
[1716487182.134468][778:780] CHIP:BLE: Device 57:4A:89:89:0E:61 does not look like a CHIP device.
[1716487182.134731][778:780] CHIP:BLE: Device 58:51:26:77:0C:E7 does not look like a CHIP device.
[1716487182.136856][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487182.138371][778:780] CHIP:BLE: Device 7E:2E:C1:0F:62:B4 does not look like a CHIP device.
[1716487182.151454][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487182.193648][778:780] CHIP:BLE: Device 5B:F2:4C:98:33:E5 does not look like a CHIP device.
[1716487182.196348][778:780] CHIP:BLE: Device FC:4E:E0:D9:6B:2D does not look like a CHIP device.
[1716487182.196931][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487182.214001][778:780] CHIP:BLE: Device 78:99:06:5F:07:B7 does not look like a CHIP device.
[1716487182.216089][778:780] CHIP:BLE: Device 25:4F:45:10:59:B6 does not look like a CHIP device.
[1716487182.230304][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487182.233615][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487182.249656][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487182.255164][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487182.257480][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487182.267144][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487182.269310][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487182.271187][778:780] CHIP:BLE: Device 32:3E:F2:6F:55:89 does not look like a CHIP device.
[1716487182.290688][778:780] CHIP:BLE: Device 67:98:32:1F:6C:3B does not look like a CHIP device.
[1716487182.292902][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487182.296227][778:780] CHIP:BLE: Device C4:AC:59:41:A2:00 does not look like a CHIP device.
[1716487182.307862][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487182.311996][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487182.315998][778:780] CHIP:BLE: Device 57:4A:89:89:0E:61 does not look like a CHIP device.
[1716487182.318650][778:780] CHIP:BLE: Device FF:14:6E:37:26:A4 does not look like a CHIP device.
[1716487182.329180][778:780] CHIP:BLE: Device 72:80:6C:DA:A5:F4 does not look like a CHIP device.
[1716487182.329470][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487182.348115][778:780] CHIP:BLE: Device 26:75:A2:97:67:5E does not look like a CHIP device.
[1716487182.350304][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487182.353049][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487182.373350][778:780] CHIP:BLE: Device 33:A7:B4:11:B7:F1 does not look like a CHIP device.
[1716487182.390650][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487182.412301][778:780] CHIP:BLE: Device D0:37:8E:CE:7C:33 does not look like a CHIP device.
[1716487182.412886][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487182.433937][778:780] CHIP:BLE: Device CE:C5:95:94:9B:DC does not look like a CHIP device.
[1716487182.434619][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487182.437495][778:780] CHIP:BLE: Device 50:CD:E9:7D:07:F5 does not look like a CHIP device.
[1716487182.450147][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487182.452301][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487182.455809][778:780] CHIP:BLE: Device 7B:27:46:8E:CD:62 does not look like a CHIP device.
[1716487182.468573][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487182.470462][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487182.475063][778:780] CHIP:BLE: Device 79:9E:9C:49:35:FD does not look like a CHIP device.
[1716487182.493696][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487182.495720][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487182.510034][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487182.533593][778:780] CHIP:BLE: Device 5B:01:33:B7:F7:71 does not look like a CHIP device.
[1716487182.535648][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487182.549260][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487182.553730][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487182.556052][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487182.570442][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487182.572565][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487182.576526][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487182.596437][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487182.608286][778:780] CHIP:BLE: Device 5A:FA:79:EA:9D:0C does not look like a CHIP device.
[1716487182.613586][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487182.615964][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487182.628986][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487182.631494][778:780] CHIP:BLE: Device 78:56:E7:8B:57:79 does not look like a CHIP device.
[1716487182.633398][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487182.635724][778:780] CHIP:BLE: Device 69:6A:1C:29:F4:FC does not look like a CHIP device.
[1716487182.637646][778:780] CHIP:BLE: Device 4C:DC:B5:3C:BA:77 does not look like a CHIP device.
[1716487182.638964][778:780] CHIP:BLE: Device 07:64:44:BE:AD:DF does not look like a CHIP device.
[1716487182.650997][778:780] CHIP:BLE: Device 6B:0A:F9:F2:3B:EF does not look like a CHIP device.
[1716487182.653114][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487182.668458][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487182.709367][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487182.711390][778:780] CHIP:BLE: Device 5B:F2:4C:98:33:E5 does not look like a CHIP device.
[1716487182.736344][778:780] CHIP:BLE: Device 3D:25:7E:51:C1:71 does not look like a CHIP device.
[1716487182.749377][778:780] CHIP:BLE: Device 79:19:E9:FE:AF:E7 does not look like a CHIP device.
[1716487182.749908][778:780] CHIP:BLE: Device 5B:01:33:B7:F7:71 does not look like a CHIP device.
[1716487182.756026][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487182.767997][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487182.770414][778:780] CHIP:BLE: Device 78:99:06:5F:07:B7 does not look like a CHIP device.
[1716487182.772220][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487182.774420][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487182.787461][778:780] CHIP:BLE: Device 76:9D:81:1C:13:8A does not look like a CHIP device.
[1716487182.790169][778:780] CHIP:BLE: Device D6:85:F4:03:BF:38 does not look like a CHIP device.
[1716487182.827454][778:780] CHIP:BLE: Device 5A:FA:79:EA:9D:0C does not look like a CHIP device.
[1716487182.829088][778:780] CHIP:BLE: Device 32:3E:F2:6F:55:89 does not look like a CHIP device.
[1716487182.834781][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487182.848131][778:780] CHIP:BLE: Device 2A:60:97:D7:08:D7 does not look like a CHIP device.
[1716487182.850340][778:780] CHIP:BLE: Device 79:9E:9C:49:35:FD does not look like a CHIP device.
[1716487182.852314][778:780] CHIP:BLE: Device 0D:26:6D:FD:31:4D does not look like a CHIP device.
[1716487182.873794][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487182.889180][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487182.894266][778:780] CHIP:BLE: Device CC:98:8B:F4:F9:A2 does not look like a CHIP device.
[1716487182.894987][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487182.897969][778:780] CHIP:BLE: Device EB:1E:40:E2:0A:0D does not look like a CHIP device.
[1716487182.906736][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487182.908498][778:780] CHIP:BLE: Device 78:56:E7:8B:57:79 does not look like a CHIP device.
[1716487182.911439][778:780] CHIP:BLE: Device 69:6A:1C:29:F4:FC does not look like a CHIP device.
[1716487182.914442][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487182.931108][778:780] CHIP:BLE: Device 7D:33:C0:E3:FC:6B does not look like a CHIP device.
[1716487182.933400][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487182.935265][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487182.937624][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487182.947156][778:780] CHIP:BLE: Device 4E:20:2A:FD:35:05 does not look like a CHIP device.
[1716487182.949173][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487182.953227][778:780] CHIP:BLE: Device 33:A7:B4:11:B7:F1 does not look like a CHIP device.
[1716487182.956860][778:780] CHIP:BLE: Device C3:CD:8B:BE:2C:D0 does not look like a CHIP device.
[1716487182.957240][778:780] CHIP:BLE: Device 5B:01:33:B7:F7:71 does not look like a CHIP device.
[1716487182.968432][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487182.988131][778:780] CHIP:BLE: Device 7E:6D:71:E1:B0:33 does not look like a CHIP device.
[1716487182.990197][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487182.992181][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487182.993822][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487183.015640][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487183.027151][778:780] CHIP:BLE: Device 63:FF:90:82:80:51 does not look like a CHIP device.
[1716487183.056849][778:780] CHIP:BLE: Device E8:A2:9F:8A:EB:75 does not look like a CHIP device.
[1716487183.057371][778:780] CHIP:BLE: Device 07:64:44:BE:AD:DF does not look like a CHIP device.
[1716487183.074251][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487183.088062][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487183.090179][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487183.092350][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487183.109453][778:780] CHIP:BLE: Device 67:98:32:1F:6C:3B does not look like a CHIP device.
[1716487183.116120][778:780] CHIP:BLE: Device 7D:33:C0:E3:FC:6B does not look like a CHIP device.
[1716487183.129283][778:780] CHIP:BLE: Device 79:C8:86:1A:89:87 does not look like a CHIP device.
[1716487183.150231][778:780] CHIP:BLE: Device 76:9D:81:1C:13:8A does not look like a CHIP device.
[1716487183.152592][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487183.155355][778:780] CHIP:BLE: Device 49:B7:B1:A6:6E:D2 does not look like a CHIP device.
[1716487183.167668][778:780] CHIP:BLE: Device 5B:01:33:B7:F7:71 does not look like a CHIP device.
[1716487183.170048][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487183.171972][778:780] CHIP:BLE: Device 5A:FA:79:EA:9D:0C does not look like a CHIP device.
[1716487183.174313][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487183.190996][778:780] CHIP:BLE: Device DA:69:D2:72:B1:09 does not look like a CHIP device.
[1716487183.194684][778:780] CHIP:BLE: Device D3:EF:B3:43:F5:BC does not look like a CHIP device.
[1716487183.195014][778:780] CHIP:BLE: Device 69:3E:D5:B2:5B:82 does not look like a CHIP device.
[1716487183.207325][778:780] CHIP:BLE: Device 60:6E:41:02:3E:E2 does not look like a CHIP device.
[1716487183.209530][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487183.213593][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487183.232036][778:780] CHIP:BLE: Device 6D:2C:F5:57:D9:1D does not look like a CHIP device.
[1716487183.249264][778:780] CHIP:BLE: Device 7E:2E:C1:0F:62:B4 does not look like a CHIP device.
[1716487183.251655][778:780] CHIP:BLE: Device 35:77:97:C2:68:26 does not look like a CHIP device.
[1716487183.253669][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487183.255995][778:780] CHIP:BLE: Device 58:51:26:77:0C:E7 does not look like a CHIP device.
[1716487183.295452][778:780] CHIP:BLE: Device 64:DC:AC:70:07:8B does not look like a CHIP device.
[1716487183.313899][778:780] CHIP:BLE: Device 77:0A:2B:80:44:D6 does not look like a CHIP device.
[1716487183.314485][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487183.316891][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487183.328295][778:780] CHIP:BLE: Device 48:E1:19:0D:11:B1 does not look like a CHIP device.
[1716487183.328579][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487183.334835][778:780] CHIP:BLE: Device 76:9D:81:1C:13:8A does not look like a CHIP device.
[1716487183.348457][778:780] CHIP:BLE: Device 35:EA:70:DC:7E:8D does not look like a CHIP device.
[1716487183.354320][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487183.357804][778:780] CHIP:BLE: Device E6:CC:B1:EF:A6:A4 does not look like a CHIP device.
[1716487183.372575][778:780] CHIP:BLE: Device 2D:F2:9D:5B:E9:66 does not look like a CHIP device.
[1716487183.374182][778:780] CHIP:BLE: Device 0D:26:6D:FD:31:4D does not look like a CHIP device.
[1716487183.391837][778:780] CHIP:BLE: Device 01:32:06:9E:0F:84 does not look like a CHIP device.
[1716487183.394844][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487183.408025][778:780] CHIP:BLE: Device 79:C8:86:1A:89:87 does not look like a CHIP device.
[1716487183.410117][778:780] CHIP:BLE: Device 26:4F:4F:A5:D7:D3 does not look like a CHIP device.
[1716487183.435882][778:780] CHIP:BLE: Device 52:6F:8D:A6:B3:3E does not look like a CHIP device.
[1716487183.438032][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487183.448335][778:780] CHIP:BLE: Device 35:A2:DF:C8:97:7D does not look like a CHIP device.
[1716487183.450356][778:780] CHIP:BLE: Device 2B:4F:EB:A9:D8:FC does not look like a CHIP device.
[1716487183.455374][778:780] CHIP:BLE: Device 78:56:E7:8B:57:79 does not look like a CHIP device.
[1716487183.456934][778:780] CHIP:BLE: Device 63:F7:C5:17:A0:37 does not look like a CHIP device.
[1716487183.458458][778:780] CHIP:BLE: Device 18:7C:8B:4F:57:E9 does not look like a CHIP device.
[1716487183.466666][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487183.468373][778:780] CHIP:BLE: Device 6B:0A:F9:F2:3B:EF does not look like a CHIP device.
[1716487183.471322][778:780] CHIP:BLE: Device 4D:4F:4D:D1:78:E8 does not look like a CHIP device.
[1716487183.506667][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487183.512798][778:780] CHIP:BLE: Device 6D:2C:F5:57:D9:1D does not look like a CHIP device.
[1716487183.514889][778:780] CHIP:BLE: Device DD:0D:30:DE:7A:BB does not look like a CHIP device.
[1716487183.528782][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487183.532069][778:780] CHIP:BLE: Device 33:A7:B4:11:B7:F1 does not look like a CHIP device.
[1716487183.568116][778:780] CHIP:BLE: Device 7B:27:46:8E:CD:62 does not look like a CHIP device.
[1716487183.570500][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487183.572599][778:780] CHIP:BLE: Device 1A:39:22:DA:D7:87 does not look like a CHIP device.
[1716487183.574655][778:780] CHIP:BLE: Device 75:CA:CB:69:59:FC does not look like a CHIP device.
[1716487183.576509][778:780] CHIP:BLE: Device 3C:23:9A:09:AB:F5 does not look like a CHIP device.
[1716487183.590168][778:780] CHIP:BLE: Device 70:AD:58:86:85:08 does not look like a CHIP device.
[1716487183.596247][778:780] CHIP:BLE: Device 79:9E:9C:49:35:FD does not look like a CHIP device.
[1716487183.598078][778:780] CHIP:BLE: Device 32:3E:F2:6F:55:89 does not look like a CHIP device.
[1716487183.608265][778:780] CHIP:BLE: Device 66:1D:2C:7A:F2:5F does not look like a CHIP device.
[1716487183.613848][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487183.615430][778:780] CHIP:BLE: Device 1D:97:00:1F:BB:F4 does not look like a CHIP device.
[1716487183.628024][778:780] CHIP:BLE: Device 10:5F:8F:D5:DE:EC does not look like a CHIP device.
[1716487183.630295][778:780] CHIP:BLE: Device EC:BC:B1:EC:95:F5 does not look like a CHIP device.
[1716487183.633457][778:780] CHIP:BLE: Device 49:0E:11:99:99:C4 does not look like a CHIP device.
[1716487183.635140][778:780] CHIP:BLE: Device 79:9E:9C:49:35:FD does not look like a CHIP device.
[1716487183.636730][778:780] CHIP:BLE: Device 23:58:11:77:0B:B8 does not look like a CHIP device.
[1716487183.647453][778:780] CHIP:BLE: Device 60:68:6C:54:CB:D4 does not look like a CHIP device.
[1716487183.670441][778:780] CHIP:BLE: Device 36:3F:1D:68:75:51 does not look like a CHIP device.
[1716487183.692007][778:780] CHIP:BLE: Device 56:58:22:1C:50:75 does not look like a CHIP device.
[1716487183.694074][778:780] CHIP:BLE: Device 0B:D3:13:83:0D:D9 does not look like a CHIP device.
[1716487183.715129][778:780] CHIP:BLE: Device 16:D6:E8:B9:ED:E4 does not look like a CHIP device.
[1716487183.718738][778:780] CHIP:BLE: New device scanned: 02:47:5B:55:DA:51
[1716487183.718786][778:780] CHIP:BLE: Device discriminator match. Attempting to connect.
[1716487184.113586][778:780] CHIP:DL: ConnectDevice complete
[1716487185.035403][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0016 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035457][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0016 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035478][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0016 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035491][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0016 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035514][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035529][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035550][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0016 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035562][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0016 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035600][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035614][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035631][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0001 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035644][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service0001 on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035672][778:780] CHIP:DL: Char /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c on service /org/bluez/hci0/dev_02_47_5B_55_DA_51/service000c
[1716487185.035700][778:780] CHIP:DL: New BLE connection: conn 0xffff800c1800, device 02:47:5B:55:DA:51, path /org/bluez/hci0/dev_02_47_5B_55_DA_51
[1716487185.035818][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1716487185.035841][778:781] CHIP:DIS: Closing all BLE connections
[1716487185.036035][778:781] CHIP:IN: BleConnectionComplete: endPoint 0xaaaaea43bc78
[1716487185.038460][778:781] CHIP:IN: SecureSession[0xffff7801fe00]: Allocated Type:1 LSID:63819
[1716487185.038529][778:781] CHIP:SC: Assigned local session key ID 63819
[1716487185.038650][778:781] CHIP:EM: <<< [E:28654i S:0 M:46312682] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1716487185.039254][778:781] CHIP:IN: Message appended to BLE send queue
[1716487185.039284][778:781] CHIP:SC: Sent PBKDF param request
[1716487185.372393][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1716487185.464625][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1716487185.464677][778:781] CHIP:BLE: subscribe complete, ep = 0xaaaaea43bc78
[1716487185.509550][778:780] CHIP:DL: Indication received, conn = 0xffff800c1800
[1716487185.509722][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1716487185.509754][778:781] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1716487185.509770][778:781] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1716487185.509782][778:781] CHIP:BLE: local and remote recv window size = 6
[1716487185.510165][778:781] CHIP:IN: BLE EndPoint 0xaaaaea43bc78 Connection Complete
[1716487185.597356][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1716487185.645968][778:780] CHIP:DL: Indication received, conn = 0xffff800c1800
[1716487185.646134][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1716487185.646275][778:781] CHIP:EM: >>> [E:28654i S:0 M:95370900] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1716487185.646304][778:781] CHIP:EM: Found matching exchange: 28654i, Delegate: 0xffff7801f550
[1716487185.646342][778:781] CHIP:SC: Received PBKDF param response
[1716487185.646387][778:781] CHIP:SC: Peer assigned session ID 39644
[1716487185.646415][778:781] CHIP:SC: Found MRP parameters in the message
[1716487185.656727][778:781] CHIP:EM: <<< [E:28654i S:0 M:46312683] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1716487185.657158][778:781] CHIP:SC: Sent spake2p msg1
[1716487185.732430][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1716487185.915820][778:780] CHIP:DL: Indication received, conn = 0xffff800c1800
[1716487185.915998][778:781] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1716487185.916206][778:781] CHIP:EM: >>> [E:28654i S:0 M:95370901] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1716487185.916235][778:781] CHIP:EM: Found matching exchange: 28654i, Delegate: 0xffff7801f550
[1716487185.916274][778:781] CHIP:SC: Received spake2p msg2
[1716487185.918611][778:781] CHIP:SC: Failed to verify peer's MAC. This can happen when setup code is incorrect.
[1716487185.918635][778:781] CHIP:SC: Sending status report. Protocol code 2, exchange 28654
[1716487185.918704][778:781] CHIP:EM: <<< [E:28654i S:0 M:46312684] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport)
[1716487185.919241][778:781] CHIP:IN: SecureSession[0xffff7801fe00]: Released - Type:1 LSID:63819
[1716487185.919282][778:781] CHIP:SC: Failed during PASE session setup: /usr/src/debug/matter/1.0-r0/src/crypto/CHIPCryptoPALOpenSSL.cpp:1600: CHIP Error 0x000000AC: Internal error
[1716487185.919302][778:781] CHIP:TOO: Secure Pairing Failed
[1716487185.919326][778:781] CHIP:DIS: Closing all BLE connections
[1716487185.919343][778:781] CHIP:IN: Clearing BLE pending packets.
[1716487185.919655][778:781] CHIP:BLE: Auto-closing end point's BLE connection.
[1716487185.919674][778:781] CHIP:DL: Closing BLE GATT connection (con 0xffff800c1800)
[1716487185.919732][778:780] CHIP:DL: BluezDisconnect peer=02:47:5B:55:DA:51
[1716487186.096631][778:781] CHIP:TOO: Pairing Failure: /usr/src/debug/matter/1.0-r0/src/crypto/CHIPCryptoPALOpenSSL.cpp:1600: CHIP Error 0x000000AC: Internal error
[1716487186.096720][778:781] CHIP:DL: Long dispatch time: 180 ms, for event type 16389
[1716487186.096999][778:778] CHIP:CTL: Shutting down the commissioner
[1716487186.097116][778:778] CHIP:CTL: Shutting down the controller
[1716487186.098912][778:778] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1716487186.098973][778:778] CHIP:FP: Forgetting fabric 0x1
[1716487186.098934][778:780] CHIP:DL: Bluez disconnected
[1716487186.099020][778:780] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1716487186.099007][778:778] CHIP:TS: Pending Last Known Good Time: 2023-10-14T01:16:48
[1716487186.099294][778:778] CHIP:TS: Previous Last Known Good Time: 2023-10-14T01:16:48
[1716487186.099311][778:778] CHIP:TS: Reverted Last Known Good Time to previous value
[1716487186.099366][778:778] CHIP:CTL: Shutting down the commissioner
[1716487186.099494][778:778] CHIP:CTL: Shutting down the controller
[1716487186.099509][778:778] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1716487186.099723][778:778] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1716487186.099812][778:778] CHIP:FP: Shutting down FabricTable
[1716487186.099833][778:778] CHIP:TS: Pending Last Known Good Time: 2023-10-14T01:16:48
[1716487186.100007][778:778] CHIP:TS: Previous Last Known Good Time: 2023-10-14T01:16:48
[1716487186.100023][778:778] CHIP:TS: Reverted Last Known Good Time to previous value
[1716487186.100212][778:778] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-5rvWoS)
[1716487186.100451][778:778] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1716487186.100482][778:778] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1716487186.100499][778:778] CHIP:DL: Inet Layer shutdown
[1716487186.100512][778:778] CHIP:DL: BLE shutdown
[1716487186.105375][778:778] CHIP:DL: System Layer shutdown
[1716487186.106404][778:778] CHIP:TOO: Run command failure: /usr/src/debug/matter/1.0-r0/src/crypto/CHIPCryptoPALOpenSSL.cpp:1600: CHIP Error 0x000000AC: Internal error
there is error Run command failure ...Internal error
Seems like it is able to discover the ble broadcasted and attempted to connect but something was wrong.
And i can see that the LED D2 state on DK6 is corresponding to
"Short Flash Off (950ms on/50ms off) — The device is full provisioned, but does not yet have full network (Thread) or service connectivity"
Please advise what is wrong here. Thanks
1,472件の閲覧回数
mihai_ignat
Hello.
Just to confirm, you are running as OTBR an NXP i.MX8 Mini EVK + a K32W0x1 USB dongle/DK6 board as Radio CoProcessor (RCP)? I can see a UART communication in the otbr logs.
A first thought is that the commands are issued too fast and recommendation would be to introduce some sleep calls between some commands. For example:
#!/bin/sh
modprobe moal mod_para=nxp/wifi_mod_para.conf
wpa_supplicant -d -B -i mlan0 -c /home/root/wifiap.conf
sleep 5
udhcpc -i mlan0
sleep 5
echo "nameserver 8.8.8.8" > /etc/resolv.conf
service otbr_fwcfg start
modprobe btnxpuart
hciconfig hci0 up
#thread
otbr-agent -I wpan0 -B mlan0 'spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=1000
000' &
iptables -A FORWARD -i mlan0 -o wpan0 -j ACCEPT
iptables -A FORWARD -i wpan0 -o mlan0 -j ACCEPT
otbr-web &
sleep 2
#form openthread network
ot-ctl dataset init new
sleep 1
ot-ctl dataset commit active
sleep 1
ot-ctl ifconfig up
sleep 1
ot-ctl thread start
Can you please try and provide feedback on this change?
BR,
Mihai
タグ(1)
1,455件の閲覧回数
seah
Yes, the setup is running as OTBR on NXP i.MX8 Mini EVK + a K32W0x1 USB dongle as Radio CoProcessor (RCP). I modified the setup script as per advised:
#!/bin/sh
sleep 5
udhcpc -i mlan0
sleep 5
modprobe btnxpuart
hciconfig hci0 up
#thread
otbr-agent -I wpan0 -B mlan0 'spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=1000000' &
otbr-web &
sleep 2
sleep 1
sleep 1
ot-ctl ifconfig up
sleep 1
ot-ctl thread start
And continue to run the setup process with the attached putty-1.log.
It still show the previously mentioned error, and the K32W End node's LED state D2 is
  • Short Flash On (50ms on/950ms off) — The device is in an unprovisioned (unpaired) state and is waiting for a commissioning application to connect.
Subsequently i tried to form thread network with OTBR Web interface
and I run the following command again:
root@imx8mmevk-matter:~# ot-ctl dataset active -x
0e08000000000001000035060004001fffe00708fd373fbfaeb7e88f0c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234
Done
root@imx8mmevk-matter:~# chip-tool pairing ble-thread 8888 hex:0e08000000000001000035060004001fffe00708fd373fbfaeb7e88f0c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234 20202021 3840
And the output log is attached at putty-2.log
This time round the  K32W End node's LED state D2 is
  • Short Flash Off (950ms on/50ms off) — The device is full provisioned, but does not yet have full network (Thread) or service connectivity.
1,438件の閲覧回数
mihai_ignat
Can you also confirm the used binary for the RCP on the K32W0x1 USB dongle? It should be the one from the Matter SDK's third_party/nxp/k32w0_sdk_repo/core/tools/wireless/ot-rcp/ot-rcp-uart-no-fc-usb.bin
Also, a factory reset from the lighting app on the K32W061DK and on the i.MX8 should be done:
  • on the K32W061DK:
Button SW2 can be used to reset the device to a default state. A short Press Button SW2 initiates a factory reset. After an initial period of 3 seconds, LED2 D2 and D3 will flash in unison to signal the pending reset. After 6 seconds will cause the device to reset its persistent configuration and initiate a reboot. The reset action can be cancelled by press SW2 button at any point before the 6 second limit.
  • on the i.MX8:
sudo rm -rf /tmp/chip*
We are trying to replicate on our side and will come back with feedback.
BR,
Mihai
1,390件の閲覧回数
mihai_ignat
Hello.
I confirm that we are not seeing the issue on our side, using i.MX8 Mini with the imx-matter_2023-q4_imx8mmevk-matter image and the k32w0 USB RCP with ot-rcp-uart-no-fc-usb firmware.
Do you have any development on your side?
BR,
Mihai
1,383件の閲覧回数
seah
My full configurations are following
i.MX8M MINI EVK Imageimx-matter_2023-q4_imx8mmevk-matter.zip
USB Thread RCP HardwareOM15080-K32W
USB Thread RCP Firmware~/nxp-mcu-sdk-2.6.14/tools/wireless/ot-rcp$ ls
ot-rcp-uart-no-fc-usb.axf ot-rcp-uart-no-fc-usb.bin
Lighting APP Firmware Builduser01@user01-VirtualBox:~/connectedhomeip/examples/lighting-app/nxp/k32w/k32w0$ gn gen out/debug --args="k32w0_sdk_root=\"${NXP_K32W0_SDK_ROOT}\" chip_with_OM15082=1 chip_with_ot_cli=0 is_debug=false chip_crypto=\"platform\" chip_with_se05x=0 chip_pw_tokenizer_logging=true"
device: K32W061
board: k32w061dk6
ntag: 0
increased TX power: 0
FRO32k: 0
low power: 0
OTA default firmware processor: 1
OTA default factory data processor: 0
PDM Encryption: 1
Antenna Diversity enabled: 0
ECC crypto lib: NXP-Ultrafast-P256
chip_with_sdk_package: 1
Done. Made 3667 targets from 305 files in 552ms
Can you identify any differences between my setup and your setup?
Since there are multiple versions of demo setup documentations on Github & NXP website, maybe you can share the exact steps that you did so that i can do the same?
1,379件の閲覧回数
seah
Thanks for your advice. It is working after  I reset device to default state with SW2.
LED toggling command is working fine
root@imx8mmevk-matter:~# chip-tool onoff toggle 8888 1
1,369件の閲覧回数
mihai_ignat
Glad to hear. If you are satisfied with the results, you can mark the relevant post as resolution.
Have a nice day!
Mihai
