Hi All,
The chip I use is JN5189. Now I want to be able to run Green Power functions, including GPD, GPP and GPS. Could you please tell me which routine can directly run Green Power functions?
BR,
Viki
Hi @Viki,
Please look at the 1.4 Green Power Concepts. The device needs a translation table in RAM, also needs to keep the sink table or proxy table.
The GPD must be a router or coordinator in the case that it wants to send a groupcast command.
Mario
Hi @Viki,
I hope you are doing great.
Some our examples implements the green power profile that could help you, also for a better reference you could look at the user guide.
https://www.nxp.com/docs/en/user-guide/JN-UG-3095.pdf
Please look at the define CLD_GREENPOWER to enable the green power.
Mario
Thank you very much for your answer.
In addition, I would like to know whether the GPD device must be a enddevice in the ZigBee network before it can be paired with GPS?(That is, the module has joined the ZigBee network before GPD pairing)
BR,
Viki
