[JN5189] Size of a flash memory page
Johnny9
hello
It seems that the flash page size for the JN5189 is 512 bytes, as defined in the SDK's app_flash.h file with '#define APP_FLASH_PAGE_SIZE 512'.
Is it possible to modify this part to change the unit for writing to flash to 256 bytes?
I tested by changing only APP_FLASH_PAGE_SIZE and it seems to read but not write.
Do I need further modifications?
Is changing the page size not supported originally?
Could you guide me on the best approach to take?
Thank you.
Jonny9.
Ricardo_Zamora
Thank you for the confirmation.
The Page size is something related to the internal flash of the MCU and not should be changed.
Ricardo
Ricardo_Zamora
Hope you are doing well. Could you please clarify what SDK version are you using?
Ricardo
Johnny9
I am using version 2.6.10.
Jonny9
Ricardo_Zamora
Could you please confirm #define you are using? I could not find it on SDK.
Ricardo
Johnny9
I made a mistake.
The name I used for #define was FLASH_PAGE_SIZE, not APP_FLASH_PAGE_SIZE.
For your reference, the base code is 'jn5189dk6_zigbee_ed_rx_on_bm'.
That part is located in 'fsl_flash.h'.
I apologize for any confusion this may have caused.
Jonny9
Ricardo_Zamora
Ricardo
