JN5189
SDK: 2.6.5
JN-AN-1244.v:2006
When I enabled OTA = 1 and finished compiling, the device could not perform OTA upgrade. I checked Vlog and found that OTA initialization was abnormal.
Initialization exception returned:eAllocateEndpointOTASpace returned error 0x1
Can you help me analyze the reason? thank you
Hello Linklai,
Could you please confirm that you followed the JN-AN-1244, Chapter 6: Over-The-Air (OTA) Upgrade? Also, please take a look at the JN-UG-3132 Cluster Library (inside JN5189 SDK folder > docs > wireless > Zigbee), Chapter 49: OTA Upgrade Cluster.
Just to confirm the behavior that your application presents, could you please try the building using OTA=0?
Eduardo.
