JN5169 Unable to enter debugging status
699件の閲覧回数
298487317
When JTAG is used to debug JN5169, a DEBUG will give the following tips. What is the reason? JTAG tools adopt ST-LINK V2,Thank you!
Error with command: ba-elf-gdb.exe --version
Cannot run program "ba-elf-gdb.exe": Launching failed
タグ(1)
588件の閲覧回数
mario_castaneda
Hi Anjy,
Did you install the JN-SW-4165 SDK? The debugger is looking for exe files that are included in this SDK.
JenNet-IP
Please look at the JN516x JTAG Debugging in BeyondStudio
Mario
