JN5168 sleep mode
JN5168 sleep mode
29603655
Hello:
  I use the function vAHI_Sleep(E_AHI_SLEEP_OSCON_RAMON) to let MCU enter sleep mode, but it always enter program mode when it wakeup. I check that because I use the SPIMISO pin as button, when JN5168 wakeup and the button press at the same time it will enter program mode.
  So how to disable JN5168 wake up from boot phase.
mario_castaneda
Hi Liang,
To avoid programming mode: leave pin floating high during reset to avoid entering UART.
If that specific pin is used for a button, you could try to connect to high.
Please let me know your findings.
Mario
