Dear Sirs,
I follow the JN-AN-1186 to inlucde libRecal_JN5169.a, as below:
INCCFLAGS += -I$(COMPONENTS_BASE_DIR)/HardwareApi/Include/
INCCFLAGS += -I$(COMPONENTS_BASE_DIR)/Recal/Include/
LDLIBS += libRecal_${JENNIC_CHIP}.a
Also, I duplicate the file "libRecal_JN516x.a" to as an new file "libRecal_JN5169.a".
However, my project JN-AN-1172 for JN5168 was compiled failed due to "cannot find -llibRecal_JN5169.a".
How to fix this kind of compiling issue?
Thanks!
Solved! Go to Solution.
Hi Alan,
Is it possible that you could change the code as below?
makefile
# Specify additional Component libraries
LDLIBS += JPT_${JENNIC_CHIP}
LDLIBS += Recal_JN516x
CustomerModuleEvalTool.c
PUBLIC void AppColdStart(void)
u32JPT_RadioModes = u32JPT_RadioModesAvailable(); /* Get the Modes supported by this device */
u32AHI_Init(); /* initialise hardware API */
//bAHI_PeriodicRecalInit(20,20);
eAHI_AttemptCalibration();
#ifndef JENNIC_CHIP_FAMILY_JN516x
for(n=0;n<100000;n++); // wait for JN516X to move onto 32MHz Crystal
#endif
Note: this is selecting a specific device.
Mario
Hi Alan,
makefile
#endif
Mario
Dear Mario,
After modified the code as your suggestions, the firmware got stuck in "eAHI_AttemptCalibration()" while run on carrier board DR1174.
Could you please help to figure out how to correctly run the calibration?
Thanks!
Hi Alan,
I will get back to you in the other community post.
https://community.nxp.com/thread/530763
Mario
Hi Mario,
After download the firmware to carrier board (DR1174 + DR1175), the routine was stuck in
What is this kind of situation?
Thanks!
