HI All.
I User the Application Note"JN-AN-1172 JN516x Customer Module Evaluation Tool"for Tx Power Test,max Tx Power about 10dBm,but i can't control the Tx Power adjust to 8dBm.
Maybe it doesn't do much in the use,but it important for FCC certification.
As you know, the JN-AN-1172 has by default only 5 TX power. You can modify that value, also taking as reference the
IEEE 802.15.4 Stack User Guide v2.6 3.8.1 Transmission Power
CustomerModuleEvalTool.c
uint8 u8MaxTxPower = 5;
uint8 u8MaxTxPowerFine = 47;
Hope it helps and please let me know your findings.
Mario
