JLink mini DK board QN8020 connection failure
tonymakkiel
       Is there anything I need to do to establish JLink connection with the DK board? Attached is a screenshot of the error I get.
I have not changed the jumper settings. At present
J11 connected 2 and 3
J12  connected 1 and 2
J13  connected 1 and 2
mario_castaneda
Hi Tony,
No, you do not need anything else.
Could you please press the reset button when you try to connect the device?
Also, press button 1 to wake up the device.
Mario
mario_castaneda
Hi Tony,
Mario
tonymakkiel
Thank you Mario. That worked. On more quick question, please. What is the difference between "9020 D9M8K" and "9020 105PJ" ?
tonymakkiel
I found those numbers written on the QN9020 chips. So am guessing they are different versions of the same chip. But am wondering what are the difference?
mario_castaneda
Hi Tony,
That numbers are the lote number and also the date that was made.
Mario
tonymakkiel
Thank you Mario
