How to setup KW36 FlexCAN multiple mailbox?
950件の閲覧回数
frankxu
Can any NXP engineer help me?
KW36 can set receive MASK to receive data by different mailbox by this funciton.
FLEXCAN_SetRxMbGlobalMask(HMI_CAN, FLEXCAN_RX_MB_STD_MASK(rxIdentifier, 0, 0));
by  this function, only setup one mailbox. I have two RX ID , how to initial/setup?
and how to get the data by flexcan_callback() function?
static void flexcan_callback(CAN_Type *base, flexcan_handle_t *handle, status_t status, uint32_t result, void *userData)
    switch (status)
       case kStatus_FLEXCAN_RxIdle:
          if (RX_MESSAGE_BUFFER_NUM == result)
             rxComplete = true;
       break;
       case kStatus_FLEXCAN_TxIdle:
       if (TX_MESSAGE_BUFFER_NUM == result)
          txComplete = true;
      break;
      default:
      break;
Could you please give me one demo code to show how to work?
773件の閲覧回数
FelipeGarcia
Hello Frank,
Please check my answers below:
1. Please check the following links as reference. I believe they could be useful.
https://community.nxp.com/thread/484816
https://community.nxp.com/thread/475008
https://community.nxp.com/thread/453975
2. In SDK examples flexcan_callback is only used to set flags such as rxComplete or txComplete. If you want to get the received or transmitted data I recommend you to use rxXfer.framefd and txXfer.framefd if you are using CAN FD or rxXfer.frame and txXfer.frame if you are using CAN.
Also, I recommend you to check chapter 37.3.2.5 of the reference manual.
I hope this helps!
Felipe
