How to obtain the download command specifications for 88W8987
625 次查看
KonTetsu
Hi all,
We are considering running the 88W8987 on a non-OS for future product development.
First of all, I need to download the firmware via UART, but I cannot find the command specifications for that firmware download.
Where can I get the firmware download command specifications?
5 回复数
611 次查看
Christine_Li
Hi, @KonTetsu
Thanks for creating case to us and hope you are doing well.
1.May I ask what is your host platform? Is it Linux or Android? RTOS?
2.For Android platform you can refer to :
Getting Started with NXP-based Wireless Modules on i.MX 8M Quad EVK Running Android 13 OS – User man...
For RTOS platform you can refer to:
Getting Started with NXP-based Wireless Modules on i.MX RT Platforms Running RTOS - User manual
For Linux platform, you can refer to:
Getting Started with NXP-based Wireless Modules on i.MX 8M Quad EVK Running Linux OS - User manual
Also, you can find more guides on our 88W8987 link according to your different requirements.
Christine.
标记 (1)
606 次查看
KonTetsu
Hi, @Christine_Li
Thank you for your reply.
We don't use Android, Linux, or RTOS.
We are trying to implement it in a way that does not use any OS.
Since the driver source is public, it is possible to infer the commands from there and implement them, but I would like to check the commands in the specifications and implement them.
600 次查看
Christine_Li
Hi, @KonTetsu
Thanks for your feedback.
Sorry for my limited knowledge, as I know 88W8987 is a host reliable Wi-Fi chip.
Without OS, I could not imagine it can work well.
We also have wireless microcontroller hostless products, such as: RW612  RW610
You might be think about them.
If you insist to use 88W8987, then you might be refer to above 3 links I provided to you on different platform, then implement it by yourself.
Sorry for the inconvenience.
Christine.
标记 (1)
595 次查看
KonTetsu
Hi, @Christine_Li
Thank you for your quick reply.
I will try implementing it based on the materials you provided.
584 次查看
Christine_Li
Hi, @KonTetsu
Sure, thank you for your quick reply.
Have a nice day~
Christine.
标记 (1)
