How to deal with the problem that KW45 get RSSI only once with Scanning Mode ?
391件の閲覧回数
ilgfcyl
Modified on the KW45's digital key car anchor routine. Constant scanning during the connection process to get the RSSI value of the phone? If the mobile phone keeps broadcasting, the RSSI value can only be obtained once; If the broadcast is reopened after the broadcast is stopped, the RSSI value will be updated once? What should I do to be able to continuously get RSSI values while broadcasting on my phone?
タグ(1)
370件の閲覧回数
EduardoZamora
Hello @ilgfcyl
Hope you are doing well.
Could you please help us with a few more details? What SDK version are you using?
What modifications did you make to the base source code? Are you using our KW45B41Z Evaluation Kit?
Any additional information is greatly appreciated.
Eduardo.
