Failure in SVD test cases while WiFi Certification.
6,317件の閲覧回数
Abhijeet_Therokar
Hello NXP team,
We are performing WiFi certification for W8897 chipset having driver release package
SD-WLAN-SD-BT-8897-AO_LINUX_4_9_70-BG4CT-W15.68.19.p59-15.26.19.p59-C4X15698_B0B1-GPL.zip running on Android 11 OS.
While performing QTT test cases mentioned below:
CT_Security_WPA2Personal_STA_4wayHandshakeVulnerability-EncryptedM3Retransmission_10002_2
WFA lab reported 'The percentage of ARP packets received from the STAUT is not as expected' in case of SVD tests.
Kindly help us to identify the issue.
Attached are the log files of the failed test items.
BR,
Abhijeet Therokar
ラベル(3)
47 返答(返信)
3,147件の閲覧回数
nandan-khant
Hello @weidong_sun,
The SVD test case is passed with the test binary.
Can you please share the official release package?
What is the timeline for the official release package?
We have the following requirement for the firmware binary:
The firmware binary should have only the changes related to the fix that was provided.
The base binary of the firmware should remain the same.
So, in summary:
Official latest released firmware binary = Base firmware binary we are using which has the issue + only fix of the issue.
Make sure nothing extra is to be added in firmware.
Thanks and Regards,
Nandan Khant
3,140件の閲覧回数
weidong_sun
Dear @nandan-khant ,
OK, Thanks for your feedback.
I will share your feedback with internal team at once.
weidong
3,084件の閲覧回数
nandan-khant
Hello @weidong_sun,
Can you please help to share the timeline or expected date for the official release?
Thanks and Regards,
Nandan Khant
3,070件の閲覧回数
weidong_sun
Hello @nandan-khant ,
Below is the feedback I got , check it, please!
Let us analyze the details and check on the requested details with the internal team. We will revert with further details.
weidong
3,047件の閲覧回数
nandan-khant
Hello @weidong_sun,
The customer is anxious for the official release as they have their customer following up for the certified product release.
Can you please help to get the timeline for the release as soon as possible?
Thanks and Regards,
Nandan Khant
3,013件の閲覧回数
weidong_sun
Understand your meaning!
shared your situations with internal team and I am also waiting for their feedback.
weidong
2,914件の閲覧回数
nandan-khant
Hello @weidong_sun,
Can you please check with internal team if there are any updates on the timeline for the official release?
Thanks and Regards,
Nandan Khant
2,857件の閲覧回数
weidong_sun
I got timeline from internale team, see feedback below, please!
We have checked with the team regarding the release and the official release will be available on 30th January 2023.
You konw my personal email address, you can send email to me , asking situation about the release on 30th of this month.
weidong
2,829件の閲覧回数
nandan-khant
Hello @weidong_sun,
Thank you for sharing the updates.
The customer has used the firmware release W15.68.19.p59 for the certification which is almost completed/passed all the test cases except the current issue in the SVD test case.
The client is using 3rd Party lab to perform the testing. It is very critical for the client to have the FW release on top of the FW version W15.68.19.p59 so that the 3rd party lab need not have to repeat the entire test case for certification.
This would save cost and time for the customer. Also, due to the Chinese New Year holidays, the client is insisting on FW release from NXP by 16/Jan/2023 or latest by 18/Jan/2023.
Can you please confirm that the official release will be provided on version W15.68.19.p59?
Thanks and Regards,
Nandan Khant
2,893件の閲覧回数
nandan-khant
Hello @weidong_sun,
Can you please connect with the internal team and ask them to expedite and provide the date for the official release?
The customer is using the firmware release version W15.68.19.p59, so expecting the new release on top of the same before 16/Jan/2023.
Also, kindly take note that the customer is insisting to resolve this before they go on Chinese new year vacation i.e before 20/Jan/2023 (the last working day before the new year).
Awaiting response from you, Thanks in advance.
Nandan Khant
2,786件の閲覧回数
weidong_sun
See below, please!
Regarding the request for the release before 20th Jan 2023, We are in the process to check with the internal team. We will keep updating you.
Yes, The official release will be on Top of SD-WLAN-SD-BT-8897-AO_LINUX_4_9_70-BG4CT-W15.68.19.p59-15.26.19.p59-C4X15698_B0B1-GPL release
weidong
2,707件の閲覧回数
nandan-khant
Hello @weidong_sun,
Any updates from the internal team regarding the release dates? Can you please check?
The customer needs to complete the certification before the 20th of January.
To achieve that, the customer is aggressively requesting the official release on or before 18th January.
Thanks and Regards,
Nandan Khant
2,683件の閲覧回数
weidong_sun
Got feedback from internal team, see below, please!
The testing for the release is already in progress but it will take time to complete the QA cycle.
We had internal discussion and official release will be available by 24th January.
weidong
2,492件の閲覧回数
nandan-khant
Hello @weidong_sun,
Can you please confirm if the official release package will be available on nxp.com or it will be shared to us over e-mail?
Thanks and Regards,
Nandan Khant
2,449件の閲覧回数
weidong_sun
you know internal team gave me feedback last time.
timeline for the release is 24th of Jan.
weidong
2,443件の閲覧回数
nandan-khant
Hello @weidong_sun,
The release will be available on 24th January. My query is as follows:
-> Will the release posted on NXP.com?
-> Will the release shared with us over e-mail?
Thanks and Regards,
Nandan Khant
2,199件の閲覧回数
weidong_sun
I got information from internal team.
The release is available at nxp.com. Please help to share the release with the customer.
SD-WLAN-SD-BT-8897-AO_LINUX_4_9_70-BG4CT-W15.68.19.p59.1-15.26.19.p59.1-CS4X15698.P1_B0B1-GPL
So I will close the case now.
weidong
2,182件の閲覧回数
nandan-khant
Hello @weidong_sun,
The customer is on vacation to celebrate the Chinese new year.
We will resume the testing and provide feedback once the customer is back.
Please wait and don't close the ticket.
Thanks and Regards,
Nandan Khant
2,394件の閲覧回数
weidong_sun
Confirmed it again.
On 24/Jan/2023, offical release will be avilable.
weidong
2,406件の閲覧回数
weidong_sun
Below is the latest feedback I got, check it, please!
We are still in communication with the internal team for the official release availability before 18th January. We will keep updating you.
[Correct it ]
Sorry! Confirm it with internal team again.
We are checking if availability of release possible before 20th. QA testing is still in progress. So above timeline is not correct.
weidong
