Hello NXP Experts,
Hi, I want to interface an ESP8266 Wi-Fi module with my LPC865 customized board. I'm new to working with Wi-Fi. Initially, I plan to interface the USART using the polling method. Can anyone provide guidance on how to interface the ESP8266 Wi-Fi module with my controller, along with any example code?
Hello, my name is Pavel, and I will be supporting your case, I recommend use the SDK example to review how the communication is done.
Select Board | MCUXpresso SDK Builder (nxp.com)
Best regard,
Pavel
hi @Pavel_Hernandez i already have LPCXpresso860MAX SDK. where is the example driver?
can you show me that?
Hello, need to select one and then click finish.
Maybe the fist is what you are looking for, only need to modify for your application.
Pavel
@Pavel_Hernandez Sorry for my late reply. I've been working on another project. Why did you relate the loopback example to the driver? I'm actually working with the ESP8266 Wi-Fi Module. Could you please explain the initial steps I need to take and what the most relevant examples are?
Hello, I based the recommendation on this comment "I plan to interface the USART using the polling method." I suggest use the example below, because the polling method is blocking mode.
Pavel
