Hi all:
I have encountered the same problem, how do you solve it?
if APP_vFactoryResetRecords(void) no
// clear out the stack
// ZPS_vDefaultStack();
BDB_vSetKeys();
this device to join the coordinator again,but no join the other coordinator;
I want the FactoryReset node to join all the coordinator,how to do?
Hi, same issue as repeat Find and Join with Factory Reset, the test result not join any more,
I found the BDB return fail to join, the test information were stack apply event "ZPS_EVENT_NWK_FAILED_TO_JOIN" on Node and status code is " ZPS_APL_APS_E_SECURITY_FAIL", so it is security check failed.
NOTES: I also check InFrameCounter and OutFrameCounter both match documents , no any report "Bad Frame Counter" from STACK.
Hi, please refer to JN-UG-3113, Appendix B.3 Clearing Stack Context Data Before a Rejoin.
Before factory resetting the Node, please do a Device Leave / ZPS_eAplZdoLeaveNetwork before factory reset to notify Coordinator of changes.
I have two devices, a coordinator, an end node, can be successful, but when I re-programmed the node again (the EEPROM erase), the node can not join the coordinator, the coordinator must also erase Once the EEPROM, the terminal node can join the coordinator again.
Know why? Help me think about it
If a MAC address of 01 equipment to join a coordinator,
And then erase the EEPROM with the MAC address 01 device
MAC address of 01 this device to join the coordinator again, the network can not be successful. The The Why is this the case?
