End node device will automatically sleep, how to remove this sleep in AN1229.
Do you wan to remove the functionality completely ?
In this case you are using an application note with a sleeping end device configuration, if you are not interested in this feature, have you consider using the JN-AN-1219 instead or the JN-AN-1217 ?
Estephania
