Coordinator can not read attribute of thermostat cluster ID 0x0202
yuboli
I have a thermostat that receives a read response when the coordinator reads the attribute whose cluster ID is 0x0201, but when I read the attribute whose cluster ID is 0x0202, I can't receive a read response, but the packet can grab a read response. Why is this? This is because the coordinator does not support cluster ID 0x0202. How can I modify it?
This is a read response to reading the attribute whose cluster ID is 0x0201:
This is the property that reads cluster ID 0x0202, and no read response is received:
thank you!
Sebastian_Del_Rio
Hello Daniel, I hope you're doing well!
Could you please show me the contents of the "Fan Control: Read Attributes Response" in your sniffer log?
Sebastian
