Hi all,
Is there a way to control the application from a command line, i.e., select channel and adapter? We'd like to use the application in automated testing framework to capture 802.15.4 traffic.
Kind regards,
Wojtek
Sorry for the late reply and the inconvenience this might cause you but unfortunately it is not possible to configure those characteristics through a command, the only thing available it’s the GUI you are using it.
Estephania
