Sorry for the late reply, there was an issue but the problem it’s solved and the SDK’s are available.
Estephania
I have the same issue as well. I think this is very bad for NXP not having its servers under control. I also asked them to send me the SDK but they don't answer my question. Maybe changing to a different manufacturer with better support will solve our problems.
Okay, I did some more research and found this topic: https://community.nxp.com/message/808537?commentID=808537#comment-808537
Someone says that the software is restricted, is this still the case?
I have same issue!
