Hi sir,
We are planning to design the automotive IVI including RSE. Is there any bluetooth solution that can connect with 3 passengers' bluetooth earphone, and I can use audio application to stream 3 different audio streams to these earphones. E.X. music 1 to earphone 1, music 2 to earphone 2, music 3 to earphone 3. Then every passenger can listen to their own music.
Jack
解決済! 解決策の投稿を見る。
Hi @chen_jackcw ,
Thanks for contacting NXP support.
NXP has a BLE audio device NXH3675 supporting Multi-Stream Audio feature. it support up to 7 audio streams in different unicast and broadcast topologies.
Here you can find some details: NXH3675: Ultra-Low Power, Low Latency LE Audio Solution | NXP Semiconductors
Gavin
Hi Gavin,
I have another question about LE audio.
If it can support multiple audio sources and sinks, each source can unicast it stream to dedicated sink.
for example. 4 smartphone and 4 earphone, audio stream from phone 1 is to earphone 1, phone 2 is to earphone 2 etc.
Jack
Hi @chen_jackcw ,
Gavin
