I'm trying to quickly spin up an application where one KW41Z freedom board continuously transmits beacons to another KW41Z freedom that is connected to a PC. I want to be able to read and process the payload received by the second board that is connected to the PC. Right now, I'm of the understanding that I can modify the Beacon example project as well as the HCI Black Box example project to accomplish this. Before going down this route, I just wanted to check if there's another quicker way to get this done.
You might also want to check the Test tool application, it might help you during your development
https://community.nxp.com/docs/DOC-340477
Estephania
