AN12380 Antenna design guide for NTAG 5 link and NTAG 5 switch
amighri
In AN12380 Application Note is mentionned that we can download a zip file where there is a matching circuit clculation excel sheet. Where can I find this Zip.File ?
danielchen
Hi @amighri
Please see below picture.
I hope it helps.
danielchen
Hi @amighri
I hope it helps.
amighri
Hi @danielchen ,
I have another question to one of the attachement in AN12342
One of the DXF attached files should be for a rectangular coil. But both files are for a circular coil. Where can I find the file for the rectangular shaped aMifare Card.
Thanks in advance.
danielchen
I will attached it here if I get it.
amighri
Thank you
danielchen
Hi @amighri :
I sent the DXF drawing file to your email address.  Next, we will update the Application note.  Thank you for reporting this issue.
